04-07-2013, 10:03 PM | #1 |
41
Rep 398
n55 JB4 Stage 2 vibration?
Hey guys,
My friend had JB Stage 1 in my car for about 5 months, just upgraded to Stage 2 the other day. The car is completely stock other than the Stage 2 box. After installing it, if he put the car in what only seems to be 5th or 6th gear, and floor it at low rpms, let's say around 40mph and 1500-2000 rpms, right as boost builds, it feels like his driveshaft gets a vibration. That's the best I can describe it. Almost sounds like a very mild version of driving over the wake-up strips if you veer out of your lane. Either way it has raised some concerns of course. If he runs the stock map, it doesn't do it. Is this a slight 'miss' or something perhaps? Any one else encounter this? Last edited by 135iMike; 06-18-2013 at 08:38 AM.. |
04-07-2013, 11:15 PM | #3 |
2020 Z4 M40i - 2022 M4C Convt
3131
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Expect you should not be lugging the engine in 5th or 6th @ 1500rpm. Look up "lugging the engine" if you don't understand.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
04-07-2013, 11:28 PM | #4 |
41
Rep 398
I'm aware of what lugging is. I just wouldn't have considered 1500-2000rpms 'lugging' especially in these low-rpm ft/lb cars; as it pulls just fine. Either way, why does it cause a vibration? And why is it only doing it with the tune active? Doesn't seem to add up.
04-08-2013, 04:12 AM | #5 |
Coding ECU's remotely
448
Rep 1,179
my N54 did does the same thing, its the extra torque on the drive train causing the vibration. Just change down or apply less throttle till you get past 2000rpms.
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube |
04-08-2013, 04:12 AM | #6 |
448
Rep 1,179
my N54 does the same thing, its the extra torque on the drive train causing the vibration. Just change down or apply less throttle till you get past 2000rpms.
04-08-2013, 06:43 PM | #7 |
1Addict
3239
Rep 7,905
These guys covered it, assuming you're driving a manual of course. Too much torque at too low revs is a bad thing for your drive train.
04-08-2013, 08:33 PM | #8 |
41
Rep 398
Word. I happened to change back to my summer tires the day I did the tune (thought I could have knocked something out of balance) so I just wanted to make sure this was 'normal'... Thanks guys.
