04-07-2013, 07:07 PM | #1 |
8
Rep 104
Radiator Fan Fuse?
Car basically shut itself down yesterday, saying high engine temperature. I guess it cuts the fuel supply as a safety precaution? Anyways...I opened the hood, checked the fan to see that it would freely rotate (it does), and then started the car to see if the fan rotated (it doesn't). I don't really know the duty cycle of the fan, but I'd think it should be rotating if the engine temperature is high. The other option I guess could be the water pump...
Anyway, I pulled the fuse panel guide out, but am not sure which one(s) is for the radiator fan (these pictures don't hep much. I initially think it could be 28, 33, 92, or 88) Also, the forceps/pullers....can't find it. Is it not easy to find? IT's possible the previous owner lost it I guess. Just as a backstory, I just got back from a deployment. I disconnected the main lead and 2 accessory leads from the battery before I left. I guess it's possible that I accidently blew the fuse when the lead hit the frame of the car....hoping it's just a fuse at least. Thanks
2008 E82 - 6 speed - CP-E Downpipes - Berk Mids - Hartge axleback - BMS DCI - Cobb Stage 2+ - Helix FMIC - Modified CDV
04-13-2013, 09:51 PM | #3 |
8
Rep 104
Nope....I checked the fueses I listed up in the first post and all were good. Car is currently at the Tacoma dealership. Should be covered under the CPO warrenty....haven't heard anything yet.
04-14-2013, 08:43 AM | #4 |
22
Rep 277
Did you find the tweezers? I can't find mine either, maybe mine fell into the same spot if you found yours.
Do we have a picture of where they are even supposed to be?
2010 N54 135i - Alpine White - 6MT - M-Sport - LCI Blacklines - 1M Mirrors - PSS - Powdercoated Black 261M
SELLING MY CAR |
04-19-2013, 05:57 PM | #5 |
8
Rep 104
Never found the pullers....ended up pulling them by hand to check. The problem turned out to be the water pump....and some fuse part on the battery that they needed to replace. I also had the battery cable recall done too. Glad to have her back though.
04-20-2013, 05:54 AM | #6 |
28
Rep 439
Drives: 2009 BMW 135i
Yup. This happened to me. It was the water pump. They go out without warning.
2009 BSM 135i 6MT
04-20-2013, 06:26 AM | #7 | |
European Editor
10589
Rep 22,992
God have mercy on your soul... (if you need to change a fuse)... http://www.1addicts.com/forums/showthread.php?t=760024
04-20-2013, 06:50 AM | #8 |
22
Rep 277
Holy crap, I would need tweezers to get to their tweezers! haha
The one time I opened mine up it was dark and I didn't have a flashlight so its possible mine are in there.
SELLING MY CAR |
04-20-2013, 07:05 AM | #9 | |
European Editor
10589
Rep 22,992
Now... imagine you have to remove that fuse box and inspect the battery cables for being loose and burnt up. That is what our battery cable recall is all about! I pity the tech who gotta do that job.
