BMW M3 Forum (E90 E92)
EXXEL Distributions
      04-07-2013, 02:41 AM   #1
johnsim
Drives: 2010 M3 Sedan
2010 e90 M3  [0.00]
Cantrell Motorsports Ducts / Stock Brakes
I just had a Cantrell Motorsports brake duct kit installed on my 2010 e90 M3 with stock brakes. Griffin Motorwerke in Berkley did the work and took some great pics:
No info on how the kit works yet. I won't have it to the track until next weekend.
      04-07-2013, 03:17 PM   #2
Transfer
Transfer's Avatar
5254
Drives: Bronco Wildtrak, Tesla MYP
Very nice. I'll be interested in your assessment at the track. What sort of brake issues did you experience in the past that prompted this upgrade?
      04-07-2013, 05:30 PM   #3
dex37
dex37's Avatar
12
Drives: E92 M3
Is there any rub? What wheels are you running?
      04-07-2013, 05:33 PM   #4
johnsim
2010 e90 M3  [0.00]
Stock 19's on the car. There's no rubbing or at least none that I'm able to notice.
      04-07-2013, 05:39 PM   #5
dex37
dex37's Avatar
12
Drives: E92 M3
Is it plug and play or du you need to cut anything (except for the hole in the fron obviously)? What material is the backing plate made from?
      04-07-2013, 05:40 PM   #6
johnsim
2010 e90 M3  [0.00]
Unfortunately I won't have a point of comparison with a specific brake problem. No track time pre-upgrade. I just got the car and was adding Pagids and SS lines. Decided to do the ducting at the same time.
      04-07-2013, 06:36 PM   #7
johnsim
2010 e90 M3  [0.00]
I didn't do it myself. These pics were taken by Griffin Motorwerke while they did the install. There is some cutting involved. There's another thread on a self install of this kit with a BBK: http://www.m3post.com/forums/showthread.php?t=705850
      04-07-2013, 06:56 PM   #8
dex37
dex37's Avatar
12
Drives: E92 M3
Thank you for the info!
      04-10-2013, 05:44 PM   #9
FrenchBoy
FrenchBoy's Avatar
France
234
Drives: '16 F80 M3
I have the same kit and it's very well made. The tires rubbing against the ducting at full lock has been an issue reported by many. Cantrell actually updated their recommended duct routing and did it on my car last week. It involves routing it under the lower control arm, changing the section locally to an oblong shape and securing it with zip-ties.
I would be really surprised if you don't rub with a non secured duct routing as you have it on the pics.
Cheers
Current: 2016 F80 M3 6-Speed | SO | AB XT1 | ZCP | M Performance Suspension | GC Camber Plates
Previous: 2009 E90 M3
      04-13-2013, 10:27 PM   #10
johnsim
2010 e90 M3  [0.00]
Hmm... I haven't tried going full lock to lock. So far just normal driving and no issues. I'll try out with the wheel fully turned and let you know.
      04-17-2013, 09:23 PM   #11
johnsim
2010 e90 M3  [0.00]
I finally got out to the track last weekend. I was slamming the brakes pretty hard. No problems with fade at all. I'm really impressed with how they held up.
Since this was my first time at the track with the car I can't really say how much the ducting helped. Anyone else have experience with Pagid RS19's and stock rotors at the track? Any fade?
It does rub a little, but only on one side and only when the wheel is all the way to the lock. Strange that it doesn't happen on the other side. I'll have to take a look and see why.
      04-17-2013, 09:33 PM   #12
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
rs19s on stock rotors with ducting, ss lines and proper fluid works pretty well. thats what i was using for couple years with no issue. did boil the fluid a few times when using worse stuff but with castrol srf wasnt an issue.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs|
      04-21-2013, 01:21 PM   #13
snook
8
Drives: e90m3, 2500hd, 95ltw
nice
m3post
