BMW M3 Forum (E90 E92)
      04-01-2013, 07:49 PM   #1
jkim723
jkim723's Avatar
Drives: E92 M3
Suspension noob needing help
I just attempted to install the RD chassis kit. The front install went fine, then I did the drivers side rear and something just doesn't seem right. Refer to photo:
While lifted...
lowered the jack...
Did I miss or forget something?
      04-03-2013, 12:32 AM   #2
skiborsy
skiborsy's Avatar
10
Drives: 2011 Le Mans Blue E90 M3
Wild guess...did you use a non-EDC kit on an EDC car? I understand the shock shaft stem (as described in these threads http://www.m3post.com/forums/showthread.php?t=621537 http://www.m3post.com/forums/showthread.php?t=621751) is skinnier on non-EDC cars and you can retrofit the other shock mount, if necessary.
      04-03-2013, 11:32 PM   #3
jkim723
jkim723's Avatar
Drives: E92 M3
I appreciate the info, and yes I have EDC and the kit is for non EDC so this was exactly the reason the shock shaft wasn't fitting correctly.
      04-03-2013, 11:59 PM   #4
jkim723
jkim723's Avatar
Drives: E92 M3
I was actually thinking about just not installing the rear, doesn't look too bad. I'm guessing it'll throw off the handling so probably not a good idea.
Just the fronts installed
Before, HATE the huge wheel gap.
Will post better pictures with the rear installed.
m3post
