03-29-2013, 02:33 PM | #1 |
14
Rep 217
Fuse Location For Convertible Top
I just put a new tune on my Z4 and had it plugged into a charger I think I might have pooped a fuse...that is my only thought. Top worked fin a week ago, installed new shocks and struts and a tune, wentto dro pthe top today and nothing. The light yellow bottom light by the button lights up when I push the top down button but the windows do not drop and I do not hear anything at all no humming buzzing clicking, just silence.
Any other ideas besides a fuse? Car is garaged and motor was fine so I do not think it is the motor. Thanks |
03-29-2013, 02:49 PM | #3 |
14
Rep 217
I located the fuses and checked all three of them, they were all fine. Now I am more confused than before, top goes up but does not go down, switch lights up when I hit the top down button but top will not go down. Could the switch still be bad even though it is lighting up? Is there another relay or switch that I need to check? Any other ideas?
03-29-2013, 02:49 PM | #4 |
80
Rep 1,663
It's probably your shelf sensor, especially because to access the rear shocks they probably had to remove the shelf.
Make sure the shelf is in the down position, if it already is, then move it up and try to toggle the little switch in the center manually.
03-29-2013, 03:26 PM | #5 | |
14
Rep 217
Now I am going to enjoy this 60 degree spring day. |
03-29-2013, 06:24 PM | #6 |
80
Rep 1,663
Glad to hear it worked out for you, time to enjoy spring!
03-29-2013, 06:31 PM | #7 | |
132
Rep 832
On a different note, I was panicking today when I went to drop the top for the first time this spring and no go. With flashbacks to replacing the motor in my 3.0i last year, my heart begun to flutter, then I looked at the shelf position... Whew! |
03-29-2013, 08:18 PM | #8 |
14
Rep 217
05-04-2015, 02:08 PM | #9 |
Rep 28
Sorry to drag up an old thread. I was trying to find someinformation on the top "shelf" and didn't find much....was hoping one of you gentlemen could assist.
As far as the shelf goes, is it supposed to move up and down with the top? What is it's purpose? |
05-04-2015, 02:35 PM | #10 |
84
Rep 924
Drives: '08 Z4 M Coupé // '09 X5 d
Don't worry, us Floridians laugh at Californians
'08 Z4 ///M Coupé (#1765/1815) — 1 of 68 Sepang Bronze / Black Nappa / Madeira Wood / 1 of 1 this combo
19" Advan RS / AP Racing / Bridgestone RE-11 / Autosolutions SSK / R.E. Diablo / R.E. trans mounts '09 X5 35d — Space Grey / Saddle Brown 20" Forgestar F14 / SCR Delete |
05-04-2015, 02:42 PM | #11 | |
Rep 34
With the shelf in the up position a switch will prevent the top from being lowered. Hope that helps. |
05-04-2015, 02:43 PM | #12 | |
40
Rep 525
As for me, I never raise the shelf, as it only provides a few more inches of clearance in an otherwise spacious trunk (for a two seat roadster).
05-04-2015, 02:43 PM | #13 |
157
Rep 1,107
The shelf's purpose is to enable you to manually (via the two knobs) gain some vertical space when the top is up. A novel idea, unfortunately the microswitch is so unreliable that using this feature in practice means that you'd have a 50/50 chance of the top lowering whenever you pressed the button!
05-05-2015, 08:35 AM | #14 |
124
Rep 904
There's no rain in CA. Doesn't it rain a lot in FL?
I was coming out of Panera the other day, put my top down and drove 50 feet to the street exit. It started raining, so I had to put my top back up. By the time I got home 10 min later, it was sunny again. That's the sh!t we have to put up with here in MA on a daily basis in spring/fall |
05-05-2015, 08:50 AM | #15 |
84
Rep 924
No rain in CA is a good thing?
We're in rainy season in FL, yeah. The rest of the year is mostly sunshine. After spending 7 years in Seattle, off/on rain is a hell of a lot better than 100% overcast/rain.
05-05-2015, 09:10 AM | #16 |
124
Rep 904
I thought we're talking about being able to put the top down. SoCal is top-down all year round. But yeah, Seattle, Chicago and Boston are probably the worst major cities for top down weather. Which makes those few months per year very special
