M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Wheels | Tires | Suspension | Brakes | Chassis
      03-21-2013, 12:15 PM   #1
pochesq
pochesq's Avatar
Drives: 2013 M5
What tire size for 21" Wheels
I'm debating whether to go 305/25/21 or 295/25/21 in the rear. My concern is a combination of asthetics, ride quality, and performance. I know some members on this board are running 295s and some 305s. With an H&R drop, what are your thoughts on the size of the tires? Thanks in advance.
      03-21-2013, 12:19 PM   #2
Poleposition
Poleposition's Avatar
Drives: very well
Depends heavily on your offsets and type of tire you plan to run.
2022 Individual M5 Comp
Venetian Violet
2021 X6M Comp
2024 i4 M50 on order
IG @purpleM5Comp_NY
      03-21-2013, 12:30 PM   #3
pochesq
pochesq's Avatar
Drives: 2013 M5
Still haven't decided on the wheel, but maybe HRE or DPE (I don't know the offsets). The tires would be either Michelin, Pirelli or Falken. Thanks.
      03-21-2013, 12:37 PM   #4
mwlmd
mwlmd's Avatar
Drives: Porsche 991 TTS
Michelin has the 305/25/21 PSS listed as a smaller total diameter than than the 295/25/21. Is that possible?
CURRENT:
His: Porsche 991 Turbo S
Carrera white/Black
Hers: BMW X3MC
BSM/Black
      03-21-2013, 01:31 PM   #5
johntomferg
Drives: Formerly drove a 13 F10 M5
You need to be careful to not under rate the weight capacity of the tires. I think the ones you are looking at do not have the minimum capacity of the stock tire sizes:
Link to Tire Rack: http://www.tirerack.com/tires/tires....5&autoModClar=
This could also play a role in determining tire diameter based on deflection.
      03-21-2013, 02:09 PM   #6
pochesq
pochesq's Avatar
Drives: 2013 M5
I know many people who have 21" wheels are driving 265s in front and 295 or 305s in the rear. Would there be an issue if I have a set-up of 255/295? Thanks again. Some posts were way too technical for me. I'm a lawyer and not an engineer. hahaha Thanks and keep them coming.
      03-26-2013, 05:58 AM   #7
Charlie Brown
Charlie Brown's Avatar
Drives: F10 M5 Azurite Black
Mathematically speaking, no it's not possible. 295/25-21= 26.8" (680.9mm) diameter. 305/25-21= 27" (685.9mm) diameter. I believe the chart has a typo or misprint.
      10-26-2014, 12:34 PM   #8
tony.m6
Drives: M6, CTS-V, F10 M5, TURBO-S
I can't decide on wheels to buy 20" or 21" ???
I'm scared if I go with 21" I might lose performance.... What do you guys think ????
If you have 21" wheels please leave you feedback on your experiences
      10-26-2014, 05:40 PM   #9
double trouble
11
Drives: E60 m5
Is this a toyo T1R you're referencing? Be careful because they're not XL load rated, which is a factory spec.
I have been trying for months to get a 305/25/21 setup, but Michelin discontinued them, and Tire Rack is reporting that Pirelli is on back order until Feb 2015.
I'm currently looking for other options too, but I just can't find any.
Ben
      05-02-2015, 03:02 PM   #10
Igor_M5
Igor_M5's Avatar
Drives: Many, BMW.
Anyone ever ran or seen 305/30/21 or 295/30/21 on a 11.5"? Any fitment issues?
      05-16-2015, 09:31 AM   #11
mrainv23
mrainv23
mrainv23's Avatar
Drives: 2014 BMW M6 Gran Coupe F06
The load rating is significantly under when you run 255s and 295s on a 21" wheel. Curb weight is fine but when driving aggressively the weight shifts and can cause a blow out. I recently ran into this issue on my M6 and was fortunate to locate a set of michelin pss 265/30zr 21 and 305/25zr 21 setup. I confirmed this with BMW, tire rack, and discount tire. They would not mount the pirellis on my car due to liability.
2014 BMW M6 Gran Coupe F06/M Performance Black Grille/20% Tint/ Exec Package/ Driver Assist Plus/ Black on Black
Sold-BMW 550i F10/Dinan S3/ Eisenmann Race Exhaust/ Vossen CV3s
      05-22-2015, 07:44 PM   #12
vividracing
vividracing's Avatar
Drives: E90 M3, F30 335i, F80 M3
We ran the 255/30 front and 295/25 rear in a Yokohama Advan Sport tire, and the fitment was pretty dead on, with our particular offset the 305 wouldve definitely had issues.
The main problem right now in these sizes is availability, Michelin has been on a national backorder for a while now.
Travis Williams
Shop ALL BMW G80 | G82 Parts Here!
480.966.3040 ext 318 Travisw@vividracing.com
PM, Email, or Call Directly for aggressive BMW Member Pricing
      05-23-2015, 10:45 AM   #13
MCarsFan
MCarsFan's Avatar
Drives: 2014 BMW M5 F10 CP
2014 BMW F10 M5  [10.00]
I'm running 305s on stock 343M wheels.. Hope this is okay because the traction has been amazing! If not, I'll just switch back.
2014 BMW F10 M5 ZCP | SSII / Black | MSR Stage III | MSR Intakes | RPi GTM Exhaust | RPi Catless Downpipes |RW Carbon Front Lip | RW Carbon Diffuser | RW Carbon Trunk Spoiler |
      05-23-2015, 12:33 PM   #14
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
What he is referring to is load rating. I think yours must be 99 or 101 right?
If that's the case then you should be fine. The only concern about your setup is the 305 mm tire on 10" rims that we already discussed, but I recall you mentioned that you emailed them and they gave you green light...
Current : 2020 F92 Black Sapphire M8 - ZF8
Gone : 2018 F80 Mineral Gray M3 - 6MT
Gone : 2016 F82 Austin Yellow M4 - 6MT
Gone : 2013 F13 Sakhir Orange M6 -7DCT
Gone: 2013 F13 Alpine White 650i -ZF8
      05-23-2015, 07:27 PM   #15
MCarsFan
MCarsFan's Avatar
Thanks for clarifying for me..
      05-30-2015, 08:24 AM   #16
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Originally Posted by vividracing View Post
the wheel just compliments the overall aesthetics of the rotors and calipers!
      12-23-2015, 02:01 PM   #17
Mr_M5Guy
59
Drives: e60 M5
Could you run 275/30/21 up front. 265's are really hard to find
      12-29-2015, 09:01 PM   #18
Mr_M5Guy
59
Drives: e60 M5
Bump.
I purchased some Morr 10.2 21" wheels. 9.5f/11r.
My car has an ecu tune, dps, and intake, so I'm looking for the best combination to gain traction. Could I run 275/315 setup?
