BMW M3 Forum (E90 E92)
BPM
      03-14-2013, 09:44 PM   #1
yz490
Drives: 08 E90
Too much rear toe?
I recently upgraded to a 275/35/18 square setup, and just had the car aligned today. I had them pull the pins, and asked them (At Speed Motorsports, Baltimore MD) to give the car as much negative camber as possible and set it up with neutral toe. The car is now at -1.5 up front on both sides with 0.00 degrees toe, and -1.6 both rear, but with A total rear toe of 0.40 degrees, 0.20 per side.
Looking at about a million posts in the last hour, it seems that I might have been a bit hasty in thinking that neutral rear toe was the way to go: perhaps a tiny bit of toe-in might keep me from killing myself, and my shop may have simply assumed as much. But is 0.40 degrees total rear too much? Will this hamper turn-in or the ability to rotate the car?
Thoughts?
      03-18-2013, 02:22 AM   #2
HP Autosport
Supreme Allied Commander
Drives: F80 M3
A little rear toe-in can help generate slip angle and thus cornering force. However, too much rear toe-in can cause some instability in corner entry and may cause the rear to slide.
      03-18-2013, 08:48 AM   #3
yz490
Drives: 08 E90
So is 0.20 degrees to in both sides too much for this car?
      03-18-2013, 11:43 AM   #4
HP Autosport
Drives: F80 M3
On E9x M3, 0.20 each side is too much, you should be at no more than 0.20 total toe-in.
m3post
