BMW M3 Forum (E90 E92)
      03-12-2013, 06:30 PM   #1
JMB
Drives: 2013 E92
2 Track days: Massive brake shutter
After only 2 track days(1 mild, 1 aggressive ) , my comp pkg M3 brakes shuttered and faded so bad I thought I had a tire going down. I've read a little about brake issues but I figured they would hold up better than this. Any solutions? Let me rephrase , any inexpensive solutions so my wife won't freak?
      03-12-2013, 06:34 PM   #2
LightWerkz
56
Drives: E90 M3
You just need some proper track pads, thats all. PFC 01 are the best, swap them in for the day or the weekend and just switch back when you get back. You probably transferred over pad material onto the rotor causing the shimmy.
      03-12-2013, 06:34 PM   #3
VCMpower
25
Drives: 2010 Dakar, 2013 Fire Orange
Track pads and SS lines. Keep your cross drilled holes in your rotors clean They pack up with the stock pads and create high spots on the rotors.
      03-12-2013, 06:34 PM   #4
CDM3DCT
CDM3DCT's Avatar
32
Drives: Jet Black M3 DCT
Used BBK or just tell your wife it's normal wear and tear... Either way- time for upgraded brakes IMHO.
      03-12-2013, 06:40 PM   #5
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
You can get a set of track pads and drive around for a day with them, maybe it will scrub off those deposits causing the judder. Re-bedding technique may also work to scrub those deposits off.
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
      03-12-2013, 06:43 PM   #6
FormulaMMM
FormulaMMM's Avatar
Drives: E90 M3
Pad deposits. I experienced the same on my old M5 and with the M3 until I smartened up.
If tracking is going to be a regular thing, strongly encourage you to get at least a front BBK and legitimate track pad (Pagid).
M4 GTS, GT3, C63 S | E90 M3s, E39 M5
      03-12-2013, 06:44 PM   #7
VCMpower
25
Understand what you are saying , but if the holes are plugged it will take more than "Re-bedding" to correct it. You may scrub off to flush with rotor but the holes will still be plugged.
      03-12-2013, 06:46 PM   #8
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Yes, may have to punch out the holes with something (carefully) before I guess. Damn, that's pretty bad ... stock pads?
      03-12-2013, 06:49 PM   #9
VCMpower
25
Yep. I experienced this once and did not want to have it again. Cantrell brake cooling kit works well also.
      03-12-2013, 06:53 PM   #10
LightWerkz
56
Drives: E90 M3
I run the stock calipers with the PFC and havent had any trouble yet. More than adequate for HPDE (20-25 mins sessions) if you are using the brakes properly. BBK would be nice, but not necessary.
      03-12-2013, 07:19 PM   #11
CBS
CBS's Avatar
Drives: F10535, E90M3, E30M3, E28M5
2017 Alpina B6 GC  [0.00]
2014 535xi M Sport  [0.00]
2014 X3 3.5 M Sport  [0.00]
2011 M3 E90  [9.74]
2007 Z4 M Coupe  [7.00]
1990 M3  [9.50]
1988 M5  [10.00]
+1 and I have a BBK.
Good set of pads, Motul 600 brake fluid (flushed regularly), SS lines and you should be set. No need for BBK unless you track hard and alot.
As the others have said the shuddering you are feeling is pad material on your rotors.
ESS VT-1 550 | M24 Oil Cooler | Fall Line Half Cage | RaceTech 4009W | 6 pt Harness | Lifeline Zero 360 Fire Suppression | Rear Seat Delete | Motion Control DA Dampers w/remote reservoirs | 900/650 Hyperco Springs | RD Sport Sway Bars | Brembo 380 BBK | GC Camber Plates | Hoosier R7 | Eisenmann Sport | Stack Gauges | Painted Challenge Front Lip | Painted ZCP Rear Spoiler | Xpel Ultimate Film | LuxAngelEyes
      03-12-2013, 07:24 PM   #12
///M Ryder
Grown Azz Man
///M Ryder's Avatar
Drives: GT4
+1.....Phil
2016 GT4.....Sapphire Blue Metallic, Platinum stitch Leather/Alcantara interior, Carbon Fiber Trim, PCM w/Nav, Guards Red Belts, 2 Zone Climate, Sport Chrono, LWB, Smokers Pack, Big Gas Tank, Light Design Pack, Bi-Xenon w/PDL, Auto Dim Mirror, Clear Side Markers, GTS Clear Taillights
      03-12-2013, 09:20 PM   #13
Longboarder
Longboarder's Avatar
3431
Drives: 2016 BMW i8
I feel your pain.
After 50 laps at Big Willow trying to haul the car down from 160mph to 90mph for turn 1, my stock brakes couldn't take it any longer. I don't think they were meant for that kind of abuse. I had mine machined twice and that's all they will take so I ordered some 380/365 StopTechs
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S
1979 Porsche 911 Turbo (930)
a couple others
IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w
      03-12-2013, 11:55 PM   #14
track_warrior
track_warrior's Avatar
Drives: F80 M3
Happened to me this weekend im on stock pads, fluid, and rotors for now. The shutter and vibration went away after driving it for a couple of days normally.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
      03-13-2013, 02:03 AM   #15
jacobe92
jacobe92's Avatar
Drives: 2016 Hell Rot F80 M3
Brakes
+ 1 When you decide to get a BBK and I know you will Don't get the 380 mm front and rear rotors because you're only limiting yourself to 18' wheel selections. Do 365 mm front and 345 mm rear rotors and you'll have a lot more 18' wheels to chose from. GL
2016 Hellrot F80 M3|JRZ RS Pro with Swift Springs 550/750 spring rates l AP Radical 5000R 9668/9449 lSpiegler SS LinesI DS1.11I Eisenmann DP|MPE Catback|18" Forgeline GS1R 18x10 et 22 and 18x11 et 44 NT01 275/35/18 and 305/35/18| Forgeline GTD1 18x10et43 SquarelM Performance Lip/Splitter|IND aesthetic mods|Dinan Toe Link|Fall Line mono ball conversion kit and upper link kit| Aim Solo 2DL Smarty Cam|Simpson Hybrid|Stilo Offshore helmet.
      03-13-2013, 02:46 AM   #16
Richard@M-World
Richard@M-World's Avatar
Drives: NASA TTA #92 M3
+1
If you will only do a handful of track days a year for fun, get some racing pads like Pagid, Hawk, or PFC. Also upgrade your fluid.
If you are going to be a track regular, go directly to a BBK.
Let me know if I may be of help.
Authorized AiM Dealer - Solo/Solo DL | SmartyCam HD | www.m-world.us
      03-13-2013, 12:04 PM   #17
ortho281
ortho281's Avatar
Drives: 2011 E92 M3 6MT
I had the exact issue after my first HPDE. Sounds like it was from pad transfer that eventually wore away. Get yourself a good set of track pads and continue driving them for a day after event to clean rotors. Then switch back to OEM pads. This will solve the problem. I like the PFC-06's because they last a long time and have almost the same amount of bite as the 01's.
Akra GT4 / MS Stage 2 / MS UDP / BPM Tune / KW CS / H&R Sways / TMS Delrin / ST 380/355 BBK / Cantrell 2.5" Ducts / SR34 Pads / Apex Arc-8 / Hoosier R7's / Mode GT4 Splitter / GT4 Canards / APR GT-250 Wing / Cantrell Half Cage / Recaro Pro Racer / Schroth Profi II-6 / BMW Alcantera Wheel / Cool Shirt / ESS Fire Supp / Solo DL
      03-13-2013, 02:20 PM   #18
AxisMagi
AxisMagi's Avatar
11
Drives: 2011 E90 Lemans Blue
After going through the same thing a few times with endless pads (boiled Motul 600 fluid as well)
I decided to just get the BBK and be done with it. It was a good decision and
well worth the extra cash for the improved stopping power and reliability. Another cheaper option might
be to install brake ducts to bring the temps down.
_____________________________
2001 E46 Race Car - S54 Swap - Moton Suspension - CAE Shifter
2011 E90 M3 - ESS VT2-625 Supercharger - Stoptech Trophy BBK - Ohlins Road & Track - MP Exhaust
      03-14-2013, 08:25 PM   #19
HP Autosport
Supreme Allied Commander
Drives: F80 M3
PFC01 is great, but if you are looking for a longer wear pad without giving up too much in performance, have a look at the PFC08.
      03-21-2013, 10:36 AM   #20
lcrain
56
Drives: e36 m3, TT-RS
After my last track day (stock 1M) I noticed similar vibration feedback in my steering wheel. I was concerned my rotors were warped, but my shop believes it was uneven pad deposit.
My car only has ~9800 miles on it so I really don't want to replace the rotors if they still have some life. I am about to bite the bullet on some track pads, stainless lines, and fluid. Wondering if I should just go ahead and buy new rotors too.
The car has seen ~6 track days and is low on miles. Are my rotors shot? Any insight would be great.
      03-21-2013, 12:24 PM   #21
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
BTW, if the OP can punch a bit out, a copper .357 mag brush on a long rod will work will for these holes, and the brushes are soft, non-damaging to the holes themselves.
      03-21-2013, 12:43 PM   #22
slicer
slicer's Avatar
2739
Drives: 'E46 M3 Race Car, '23 X7
Did you read the other posts in this thread? Most of them site pad deposits as the first place to look. Your shop thinks the same thing. What more do you want?
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc.
INSTAGRAM - @Slicer_M
m3post
