XBimmers.com | BMW X6 Forum X5 Forum
TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > X6 Engine / Exhaust / Drivetrain Modification
      03-10-2013, 03:32 PM   #1
S00017064
Drives: x6m
X6m gear and ecu damage
Hi I have a2012 x6m with vorstainer body kit at design down pipes and eisenman race exhaust and ess software update the sad news that the car broke down after 15000 km from installing the ess soft wear . Talked to ess they said The ECU is for sure not damaged in any way. This is simply not possible and you can send it to us for testing and we can verify that it works normally if needed. To damage the transmission is possible with extreme driving and a lot of power, this is user error and abusive driving normally or manufacturing defect/low transmission oil level. Even on stock power it is possible to wear out the stock transmission if driven extremely hard. This is however not a common problem as these transmissions are very strong if used normally. Do not tow heavy loads at full power though.
So I want to ask you guys what might have caused the gear and ecu to get damaged put in mind that I don't race my car , but I do admit to pushing the m bottom everytime Iam in it
      03-23-2013, 09:35 PM   #2
330i zhp
Drives: X5M and SCd Touring
in for answer
      05-19-2013, 11:21 PM   #3
TimZ
TimZ's Avatar
Albania
33
Drives: X5M
Bump
Any answer? Did you get the problem fixed??
      05-20-2013, 04:33 AM   #4
titanle
titanle's Avatar
50
Drives: 2010 X6 Activehybrid
in for answer
      05-20-2013, 01:29 PM   #5
northern2020
northern2020's Avatar
44
Drives: '11 X5 M / '01 B5 S4/ 15 328d
What's the point of asking for help when you the OP goes mute after asking ?
| '10 Escalade ESV | '12 Audi S4 | '01 Audi S4 | '15 328d Xdrive M-Sportwagon |
xbimmers
