03-10-2013, 08:53 AM | #1 |
33
Rep 117
down pipe studs
does anybody know the part number for the studs in the 1M down pipe that the mid pipe nuts go onto, i cant find any in the parts diagrams,do these knock out or are they part of down pipe
03-10-2013, 09:23 AM | #2 |
Moderator
29651
Rep 13,137
Sure the diagrams referenced below don't feature what you're looking for ?
http://realoem.com/bmw/showparts.do?...81&hg=18&fg=10 (downpipes - precatalyst) http://realoem.com/bmw/showparts.do?...86&hg=18&fg=10 (downpipes - lambda probe fixings) http://realoem.com/bmw/showparts.do?...70&hg=18&fg=10 (midpipe)
///M is art ↔ Artemis
03-10-2013, 10:01 AM | #3 |
33
Rep 117
looking at the downpipes - precatalyst diagram no7 nut goes onto it,but no part number for the stud,hope this is not part of the down pipe or this could be a problem when these cars get older & stud corrodes
03-10-2013, 12:18 PM | #4 |
H O O N
86
Rep 694
IIRC the studs themselves are not available separately, they are a part of the DP's. Are you planning on having to take it apart often? Worse case scenario you could cut the stud out, drill out the backing and replace it with a bolt and nut like those found on aftermarket DP's.
03-10-2013, 01:01 PM | #5 | |
34
Rep 770
I wouldn't worry too much about it, unless you fell like changing them out with bolts and nuts, that you will in turn change out every so often again to prevent corrosion. It will take many years to get THAT bad. |
03-10-2013, 01:55 PM | #6 | |
33
Rep 117
03-10-2013, 02:17 PM | #7 | |
European Editor
10604
Rep 22,992
RealOEM.com says the nut is a M8. So the stud threads are probably M8 x 1.50 thread pitch. It could be M8 by 1.25 as well, but I think its 1.50. I believe I used a 13mm socket for the M8 nut. I coated the threads with some high temp copper anti seize... just to make life easier next time I go in there.
03-13-2013, 01:25 PM | #10 |
36
Rep 103
I fitted an N55 mid pipe this last weekend, luckily I'd purchased 4 new flanged nuts.
The lower two nuts were pretty much seized after 11K miles and 14 months. We ended up chiseling them off. The thread looked to be M8 X 1.0 or 1.25 (didn't need a die so didn't establish exactly what it was) The top two nuts which hadn't been exposed to road salt and water, came off with no problems. The studs will be a press fit into the downpipe itself (and hence aren't listed as separate part no) possibly with a straight knurl to make them an interference fit. Last edited by Dirk Van Driver; 03-13-2013 at 01:30 PM.. |
