BMW M3 Forum (E90 E92)
      02-14-2013, 11:05 AM   #1
i001947
i001947's Avatar
26
Drives: '13 E92 M3
Brake Dust On Rims, Really?
I seriously cann't believe that BMW have not yet developed a way to prevent brake dust from accumulating on their great looking 19's rims by now.
Nothing pisses me off than looking at my new M3 wheels and noticing how dirty they get just after 25 miles of stop and go driving. I've tried rim wax and sprays to prevent the built up of brake dust and nothing stops it.
I remember having this same problem with all of my BMWs (320i, 325i, 525i and 740i). And I do recall buying some brake shields for my 325i. They worked to prevent the dust from building up. But they made the rims heat up more a and they really didn't make the rims look nice at all.
      02-14-2013, 11:19 AM   #2
ApexM3
ApexM3's Avatar
Drives: '16 M3
16 BMW M3  [0.00]
Thats just the way it is. Its a high performance vehicle and the dust has to go somewhere. All you can do is keep up with them. Avoid using chemicals and waxes to try and prevent it. The chemicals in a way end up being magnets for the dust. Use nothing but soap and water to clean the wheels.
Current: 2019 F90 M5 Competition
Previous: 2016 F80 M3
Past: 2013 E92 M3
Past: 2011 E92 335Xi
      02-14-2013, 11:22 AM   #3
ERinEC
54
Drives: '11 AW E92 M3
I have the same gripe as well. I know all pads will produce dust, but the OEM ones seem to produce an excessive amount. When they're due for replacement, I definitely be looking at non-OEM options to reduce the dust build up.
      02-14-2013, 11:23 AM   #4
Redline Bandit
Redline Bandit's Avatar
Drives: 2008 E92 M3 Melbourne Red 6MT
Yep, it's all about brake lining selection. There is a tradeoff for high Mu linings = brake dust. You can always look to switch to a ceramic pad :
http://zeckhausen.com/BMW/E92_M3.htm
      02-14-2013, 11:24 AM   #5
THE TECH
BimmerPost Supporting Vendor
THE TECH's Avatar
307
Drives: BPMsport 2012 E92 M3
      02-14-2013, 11:27 AM   #6
Vic311
Drives: 2011 e92 M3
Prevent brake dust?..interesting.. Do you also want to prevent braking?
Brake dust is an integral by-product of braking..not much can be done about it.
FYI lower brake dust pads = lesser friction and braking power
      02-14-2013, 11:30 AM   #7
highyo
Drives: M3, X5
can't tell if serious. if so
http://www.armorall.com/products/vie...?product_id=33
pretty decent
      02-14-2013, 11:32 AM   #8
///M3THOD
///M3THOD's Avatar
Drives: 991.2 GTS
I've used Hawk HPS pads on my CTS-V. They had much less brake dust than the OEM pads and I thought they performed better.
There are low dust pads available aftermarket. OEM ones are quite dusty.
      02-14-2013, 11:38 AM   #9
i001947
i001947's Avatar
26
Drives: '13 E92 M3
pretty decent
Thanks, I'll give it a try.
      02-14-2013, 11:40 AM   #10
///Matthew
///Matthew's Avatar
196
Drives: 2013 M3, 1999 M3
Originally Posted by THE TECH View Post
Looks good.
2013 Santorini Blue M3
1999 Estoril Blue M3
mfatuation.com
      02-14-2013, 11:50 AM   #11
apecush
30
Drives: 2008 E90 M3
first world problem?
yes, it takes effort to keep a car clean. deal with it.
      02-14-2013, 11:53 AM   #12
Malek@MRF
Malek@MRF's Avatar
Drives: E92 M3, E46 M3, G82 M4
If your M3 is being mainly used on the street with very light track usage, I suggest you switch over to the Akebono EURO Ceramic brake pads. They are pretty much dustless and perform very well for a street vehicle which sees some light track duty.
If the car is going to be consistently used at the track, then brake pads, lines, and fluid are in order for you.
Let me know, I can help you out a ton.
Malek
      02-14-2013, 12:08 PM   #13
ERinEC
54
I used the same on my Audi S4 and was very happy with the results.
      02-14-2013, 12:17 PM   #14
phrozen06
phrozen06's Avatar
229
Drives: 328it, RIP M3, E46 Sold
go with AKEBONO
      02-14-2013, 01:18 PM   #15
m3an
m3an's Avatar
39
Drives: M3
it's the pads. Change the pads and it'll be 90% less dusty
      02-15-2013, 08:27 AM   #16
klammer
97
Drives: 11 spc gry m3 e90, 19 X5
Or just buy wheels that are the color of brake dust, problem solved
mods: track ready stuff
      02-15-2013, 09:02 AM   #17
Wendall
***Major MammelToe
Wendall's Avatar
Drives: E92 M3 SG coupe
Malek
Dang I need these on for my next set.
E92 M3 SG DCT - AA Filter, Verstraβe Paddles, ECS SS, MH race stud, Stoptech BBK, MR Exhaust,RE Pulley, BPM Tune,Euro bumper and GTS lip, Euro MDM & DCT, KW CS, Recaro PP, TMS Soild Diff Mounts, MRF solid subframe mounts, GTS aero, RPM track built motor.
      02-15-2013, 10:36 AM   #18
STi_traitor
106
Drives: BTG 2014 - 3 Laps
Originally Posted by Team Plutonium View Post
Put tire-shine on your brake pads.
WD-40 if tire-shine doesn't work........
      02-15-2013, 10:45 AM   #19
j2m
j2m's Avatar
180
Drives: '11 E92 M3 DCT
2011 BMW E92 M3  [10.00]
That shit works! I also put on the tread on my tires to keep them from squeaking
11' E92 M3 Space Grey | DCT | ESS VT2- 625 | Gintani Race (valved) + Quad Res Catless X-Pipe | KW Sleeve's | GC Camber Plates|Arkym Diffuser | Vorsteiner VRS Lip | P3 Boost Guage | Stud Conversion
PHOTO's: Click Here ESS VT2 625 PHOTOS: Click Here
      02-15-2013, 11:52 AM   #20
Redline Bandit
I work for Akebono!
Originally Posted by phrozen06 View Post
go with AKEBONO
      02-15-2013, 02:19 PM   #21
phrozen06
phrozen06's Avatar
229
Originally Posted by Redline Bandit View Post
I work for Akebono!
I have had 2 sets of Akebono's on my E46 and have had almost ZERO brake dust.
      02-15-2013, 06:49 PM   #22
bradleyland
TIM YOYO
Drives: 2013 M3
pretty decent
+1
It's about $12 a can, but it's totally worth it. This stuff keeps the brake dust off for weeks. Some tips for using this:
* Clean the wheel extremely well before applying and DO NOT touch the wheel with your hands before applying; the slightest amount of oil from your fingers will keep it from working right
* Apply liberally, but slowly; take your time like you're painting the wheel
* Once you've applied it well, you can wash the wheels with soap and water (no wheel cleaner) and re-apply a little less liberally to safe the product
His: 2019 R1250GS - Black
Hers: 2013 X3 28i - N20 Mineral Silver / Sand Beige / Premium, Tech
Past: 2013 ///M3 - Interlagos Blue Black M-DCT
Past: 2010 135i - TiAg Coral Red 6MT ///M-Sport
m3post
