BMW M3 Forum (E90 E92)
      02-02-2013, 06:38 PM   #1
Wendall
***Major MammelToe
Wendall's Avatar
Drives: E92 M3 SG coupe
KW CS installed - Eibach vs KW CS
Before with Eibachs:
E92 M3 SG DCT - AA Filter, Verstraβe Paddles, ECS SS, MH race stud, Stoptech BBK, MR Exhaust,RE Pulley, BPM Tune,Euro bumper and GTS lip, Euro MDM & DCT, KW CS, Recaro PP, TMS Soild Diff Mounts, MRF solid subframe mounts, GTS aero, RPM track built motor.
      02-02-2013, 06:39 PM   #2
Wendall
***Major MammelToe
Wendall's Avatar
With KW CS
      02-02-2013, 06:42 PM   #3
m3p40
Drives: M3 E92
Stance looks sick.
Is the performance upgrade as crazy as everyone says?
      02-02-2013, 06:51 PM   #4
w00tw00t
w00tw00t's Avatar
Drives: 2016 MW M4
Nice but its funny. Did you just buy these for looks and lowering?
      02-02-2013, 06:52 PM   #5
Wendall
***Major MammelToe
Wendall's Avatar
Thanks to Baan Velgen and MRF Engineering!
Review:
Malek did an amazing job installing and aligning the KW CS. The front is about a one skinny finger gap and the rear is tire is tucked about a centimeter.
Comfort:
These feel like the Eibachs, maybe a tad bit stiffer. I'm not sure what setting Malek put the bound and rebound to, but I just told him to work his magic and It will be primarily a street car.
I was hesitant to buy this suspension because of some of the threads I have read about it being stiff and for track only. People have told me to go JRZ, TCK or MCS if i want a streetable comfort level.
I have to say, these are awesome. They absorb fast bumps just as well as stock and over slow/large bumps its feels like its on rails. It follows the bump smoothly. Whereas the stock and eibach set up would be floaty.
From what I hear about the JRZ's, these feel the same. Or atleast I would have the same description.
Weight:
I thought the KW CS would be heavier since they are inox stainless steel. They box they came in said they weighed ~ 45lbs from USPS.
Malek packed my Eibach and OEM struts in to a KW CS box for me to use if I ever need a back up. After lifting these out of the trunk, I noticed that they were much heavier than the KW CS setup. They feel about 10lbs heavier than the KW CS. I think the major weight savings is in the coils. From what I have heard, Eibachs are Hi Ten steel (very heavy) and KW CS are light Alloy.
Handling:
I have only put ~ 100 miles on them so far but it feels super flat now. Braking feels better - less rear to front weight transfer. These feel really stiff when you need them yet supple when you are cruising. In fact, when I drive into my driveway, it feels so stiff that one wheel seems to lift off the ground when i enter the ramp sideways.
      02-02-2013, 06:53 PM   #6
Wendall
***Major MammelToe
Wendall's Avatar
Yes im a poser. I admit it. I have never been to the track. However, I am changing my ways and I will be attending my first track event this month at california speedway. Some of my buddies are track junkies and are trying to get me hooked.
      02-02-2013, 06:56 PM   #7
2000gsr
2000gsr's Avatar
18
Drives: 2018 M4
How much did the front and rear actually drop? I'm assuming you are on max height on the rears. Stance looks wicked!
      02-02-2013, 06:58 PM   #8
Wendall
***Major MammelToe
Wendall's Avatar
I think the front is a one inch drop and the rears are 1/2inch from max height.
Thanks for the complement!
      02-02-2013, 07:08 PM   #9
2000gsr
2000gsr's Avatar
18
Drives: 2018 M4
No problem, this post has pushed me even closer to pulling the trigger on these!
      02-02-2013, 07:11 PM   #10
Wendall
***Major MammelToe
Wendall's Avatar
Another thing to note is that I clear ramps and bumps easier. Since the springs are stiff my chin doesnt dip at all like the oem suspension.
      02-02-2013, 07:21 PM   #11
w00tw00t
w00tw00t's Avatar
Drives: 2016 MW M4
Once you get hooked on, you will wonder why you waited so long.
      02-02-2013, 08:17 PM   #12
ms372
White Shark
ms372's Avatar
88
Drives: AW E92 m3 6MT
looks good !
ESS | Challenge x-pipe | Akrapovic | Stoptech BBK (380/355) |Ohlins R&T | Dinan | Vorsteiner | Downforce USA | Varis Diffuser | Gintani | UUC | BMW Performance | Macht Schnell | Forgestar F14's SDC 19x9.5F 19x11R | 255.35 295.30
      02-02-2013, 11:05 PM   #13
sensi09
30
Drives: .
Looks good, but if you're mainly after looks, then how did you decide on the clubsports?
      02-02-2013, 11:48 PM   #14
REDBULL
REDBULL's Avatar
Drives: '12 SG M3/Fox Red
looks awesome man! just got my clubsports in as well (i also have a space grey M3 but silver comp wheels). will be puttin up pictures next week after install. what setting are your clubsports? i am also going to put 12mm spacers from 10mm rear
12 E92 M3 SG/Fox Red - ESS VT2-650 | Mode Carbon | KW Clubsports | IPE | Challenge Race X pipe
10 E92 M3 MR/Black - rod bearing failure
      02-03-2013, 01:16 AM   #15
bobs619
bobs619's Avatar
Drives: 2014 Saphire Black F10 M5
Looks good. Plan on running spacers?
      02-03-2013, 06:19 AM   #16
MilehighM3
MilehighM3's Avatar
Drives: Harrop E90 M3
2009 E90 M3  [6.50]
Looks great, except for the Prius in the background!
      02-03-2013, 06:43 AM   #17
Wendall
***Major MammelToe
Wendall's Avatar
I love that piece of $hit!
      02-03-2013, 03:28 PM   #18
Malek@MRF
BimmerPost Supporting Vendor
Malek@MRF's Avatar
Drives: E92 M3, E46 M3, G82 M4
Steven,
I am glad you are enjoying and gradually warming up the KW Clubsports. They are amazing suspension pieces and defintely worth every penny. It absolutely transforms the car. As you get more seat time with the car, this will become more evident.
Malek
      02-05-2013, 09:52 AM   #19
2000gsr
2000gsr's Avatar
18
Drives: 2018 M4
Do you remember the settings you used?
      02-05-2013, 10:05 AM   #20
Wendall
***Major MammelToe
Wendall's Avatar
I have been tinkering with the settings a bit. At first it was 8/9rebound and 5/4bump
It rodes really well and turn in was sharp. However, It got a little to stiff at times driving down the 405 fwy near LAX. That fwy strip is really bumpy.
So, I backed it off to 6/9 Rebound and 6/6 bump and it feels just like my eibachs. Slightly stiffer than OEM but 10x the control. No more floatiness on bumps.
      02-07-2013, 03:48 PM   #21
2000gsr
2000gsr's Avatar
18
Drives: 2018 M4
So you are at kw recommended settings right now. What are your camber settings at?
      02-07-2013, 03:51 PM   #22
THE TECH
THE TECH's Avatar
307
Drives: BPMsport 2012 E92 M3
Looks good.
m3post
