BMW M3 Forum (E90 E92)
BPM
      01-17-2013, 07:43 PM   #1
Car54
36
Drives: 2014 M-Sport Wagon - EBII
Titanium Shims | Good or Bad?
What do you guys think about break pad shims? I recently shot through a set of PFC08 endurance pads in 3 track days. This is much faster than normal for me and the only major change was the titanium plates. I wonder if they keep the heat in the pads and not allow the heat to dissipate.
Thoughts?
      01-17-2013, 10:22 PM   #2
Zoli007
Professional lurker
Zoli007's Avatar
129
Drives: 2011 135i, 2016 MCB M3 sold =(
You went through the pads quicker due to the titanium shims? Interesting. I've always wondered about them.
      01-17-2013, 10:33 PM   #3
AxisMagi
AxisMagi's Avatar
11
Drives: 2011 E90 Lemans Blue
I didn't have much luck with them on stock brakes.
_____________________________
2001 E46 Race Car - S54 Swap - Moton Suspension - CAE Shifter
2011 E90 M3 - ESS VT2-625 Supercharger - Stoptech Trophy BBK - Ohlins Road & Track - MP Exhaust
      01-17-2013, 10:36 PM   #4
TXmtrhed
TXmtrhed's Avatar
37
Drives: VO 1M
In my opinion the shims work great in reducing the heat transfer to the calipers and most especially the brake fluid. They have so far eliminated the soft brake pedal I used to get at the end of a session.
So though the piston side pad may run a little hotter the outer pad temp should not be affected (I only run shims on the piston side). I haven't noticed any difference in wear rates from before and after shims.
Were you running at the same track as before? Same session length?
      01-17-2013, 10:46 PM   #5
Vic311
Drives: 2011 e92 M3
Consider brake silicone grease instead?
interesting theory on heat dissapation with the shims. I would think they would act as a heat sink drawing heat away from the calipers/pads
      01-17-2013, 11:17 PM   #6
Brian@MWP
Drives: BMW
What brand shims did you buy?
      01-18-2013, 10:35 AM   #7
TXmtrhed
TXmtrhed's Avatar
37
Drives: VO 1M
Bought mine from Hardbrakes.com. The kit for the OE M3 brakes consists of four shims in the shape of the front pads (no kit avail for the rear). I mounted two up front and reshaped the other two to use in the rear.
In addition to keeping my brake fluid temps down it should help preserve the caliper boots.
      01-18-2013, 10:33 PM   #8
Porschefile
Porschefile's Avatar
59
Drives: E92 M3
I always ran them on the stock calipers. It increases pad temp and therefore pad wear, but I'd rather run through PFC's faster (they can take the heat) than boil brake fluid. YMMV.
      01-19-2013, 01:16 AM   #9
Superfly_M3
72
Drives: 2011 M3
Interesting to know, thanks for the info
      01-19-2013, 12:09 PM   #10
bigjae1976
bigjae1976's Avatar
1571
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
The only reason that's tested is that the shims keep your pretty fixed calipers from changing colors.
I had the shims with my first set of pads and they lasted a long time. The second set of pads went pretty fast and I did not have the shims. Both pads were PF01s.
I also want to test the theory that PFC may have some consistency issues with their pads. I've never really gotten an consistent wear rate. I'm trying some pagids and stoptech pads so I can compare.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      01-19-2013, 12:45 PM   #11
Car54
36
Hardbrakes as well.
      01-20-2013, 09:27 PM   #12
Brian@MWP
Drives: BMW
Thanks for the info guys!
m3post
