BMW M3 Forum (E90 E92)
BPM
      01-14-2013, 07:42 PM   #1
Trevor .:R
Drives: 13 ZCP DCT
11 M3  [10.00]
E90 wheel spacing
Hey guys i have yet to find a thread with a e90 m3 with 18mm spacers front and 15mm rear... i have them from my e92 and i want to see how aggressive it looks on an e90 with a slight drop probably springs, i think it will rub but i am curious..
Current: 2013 E92 M3 AW DCT
Past: 2011 E90 M3 AW DCT, 2011 E92 M3 MR 6MT, 2008 E92 M3 AW 6MT
      01-14-2013, 07:48 PM   #2
Crazy Bimmer
The Jesal
Crazy Bimmer's Avatar
Drives: E90 M3
2009 BMW M3  [0.00]
Here you go. Lowered on H&R springs at the time.
It did not rub at all.
2009 E90 M3 - SOLD
      01-15-2013, 01:21 AM   #3
Trevor .:R
Drives: 13 ZCP DCT
11 M3  [10.00]
18 front 15 rear?
      01-15-2013, 08:16 AM   #4
THE TECH
BimmerPost Supporting Vendor
THE TECH's Avatar
307
Drives: BPMsport 2012 E92 M3
Looks good.
      02-11-2013, 11:34 AM   #5
DFDubM3
Drives: 08 E90 M3
I run15's front and 18's rear and dropped on H&R Springs and have no issues
      02-16-2013, 04:18 PM   #6
SUBFRAMERIPPER
SUBFRAMERIPPER's Avatar
Drives: 2009 E90
Looks good! Any more pics? Maybe different angles?
      02-16-2013, 07:23 PM   #7
Malek@MRF
Malek@MRF's Avatar
Drives: E92 M3, E46 M3, G82 M4
It does not rub (depending on the tires on the wheels) and is the most ideal look for OEM wheels. I personally prefer it over the 15/12mm spacer combination.
      02-18-2013, 07:28 AM   #8
Car54
36
Drives: 2014 M-Sport Wagon - EBII
Some of these aggressive spacer setups work in most scenarios but what happens when you get a couple dudes in the back seat or take it on a road (or track) that increases suspension compression?
+1 for more pics of the IB E90
      02-18-2013, 09:54 AM   #9
marksae
marksae's Avatar
36
Drives: ///M
On my '09 E90 w/ 220 wheels, I ended up rubbing the plastic liner in the rear w/ Turner 12.5mm rear spacers. I just trimmed the liner, and all was good.
In front, I have a 15mm spacer. The tire rubs the liner when the wheels are steered to the right, almost near the lock.
04 E46 M3 6MT - AW / Cinn
93 FD RX-7 Base Manual - BB / Blk
IG: @gearheadtwins
      02-22-2013, 09:34 AM   #10
AlteredBe4st
First Pride
AlteredBe4st's Avatar
110
Drives: M4
I ran 15mm front and 15mm rear lowered on H&R springs and had rubbing in the rear due to the tires (AD08). I then changed the rear to 12mm and have no problems now. So it depends on your choice in tires and size.
Modded M4
m3post
