BMW M3 Forum (E90 E92)
Mporium BMW
      01-11-2013, 06:40 PM   #1
uplusd
uplusd's Avatar
Drives: 2013 E92 M3
Corner weight balancing
Quick, and possibly silly, question about CWB. I'm wondering if which wheels you have effects the balance? Like for example if I corner weight balance my car with one set of wheels, and then put on another set, does it throw off the balance?
      01-11-2013, 06:51 PM   #2
bigjae1976
bigjae1976's Avatar
1571
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
I would say no. Maybe if you have staggered wheels that are significantly different in weight for a weird reason. Even then I think the difference will be negligble.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      01-11-2013, 06:54 PM   #3
Snertz
H O O N
Snertz's Avatar
Drives: ein M!
Since CWB takes into account the wheel weight, I think it does though to a very minimal effect since changing wheels results in perhaps <10lb total change per corner.
      01-11-2013, 07:00 PM   #4
bigjae1976
bigjae1976's Avatar
1571
2004 BMW M3  [4.50]
The key is the cross weights and the proportional weight at each corner. So if you put wheels that are all 2lbs heavier at all 4 corners, it has no effect on those numbers.
      01-11-2013, 09:04 PM   #5
Raucky2000
Raucky2000's Avatar
22
Drives: SGM E90 M3 dct
Not a big enough difference for you to notice IMHO, one set to another.
      01-17-2013, 10:47 AM   #6
Techevo
Evo Junkie
35
Drives: E91 325D M-Sport, Evo 6
No, changing wheels makes no difference to corner weighting adjustments.
Corner weighting is done to adjust suspension lengths so that they give an even cross corner footprint. Think of it as adjusting a tables leg lengths so that the table doesn't wobble due to one or two legs being too short.
In adjusting the lengths, you are trying to obtain equal cross corner weights (as said by bigjae) so the front left and rear right weights added together equal the front right and rear left.
The only way to change weight distribution is by physically moving weight around, and cannot be done by corner weighting.
      02-24-2013, 10:03 AM   #7
ortho281
ortho281's Avatar
Drives: 2011 E92 M3 6MT
^This. I used my street wheels/tires to do my corner-balancing because they were relatively new and the track tires were un-evenly worn!
Akra GT4 / MS Stage 2 / MS UDP / BPM Tune / KW CS / H&R Sways / TMS Delrin / ST 380/355 BBK / Cantrell 2.5" Ducts / SR34 Pads / Apex Arc-8 / Hoosier R7's / Mode GT4 Splitter / GT4 Canards / APR GT-250 Wing / Cantrell Half Cage / Recaro Pro Racer / Schroth Profi II-6 / BMW Alcantera Wheel / Cool Shirt / ESS Fire Supp / Solo DL
      02-24-2013, 11:25 AM   #8
Superfly_M3
72
Drives: 2011 M3
Does CWB have that of a drastic effect on the way the car handles?
      02-24-2013, 09:45 PM   #9
bigjae1976
bigjae1976's Avatar
1571
2004 BMW M3  [4.50]
Depends how far off it is. If your close is pretty close to stock is should already be close. If you've got the full interior...unnecessary. Since you did put on TCKlines...as long as your car has a similar height ratio from side to side and front to back as the stock suspension...it should be close optimal.
IMO, corner balancing is only necessary when you've added a lot of weight or took some off. Otherwise its a very fine tuning detail step.
I have removed about 300 lbs from my track car...so I will corner balance it.
m3post
