ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      01-05-2013, 10:48 PM   #1
bluecobra
Drives: 2006 Z4M Coupe
Oil Level Question
Ok, I changed my oil and filter in my 2006 M Coupe and I very carefully put 5.5 Liters of Castrol 10w60 back into it. Started it and checked for leaks, no problem, shut it off and waited for a minute to check the level.
Drove it to the gas station and back, checked it again.
5.5 liters puts the oil level right at the low mark on my dipstick. Is this where I leave it?? My car does not use any oil between changes so that is not a concern but in my mind the car is low on oil at that level on the dipstick.
Opinions???
      01-06-2013, 06:49 AM   #2
inTgr8r
inTgr8r's Avatar
2432
Drives: M2 Comp
Something is odd, it should be at least half way with 5.5
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold)
'13 E92 M3 Santorini Blue (sold)
'07 Z4 M Coupe Alpine White (sold)
      01-06-2013, 07:45 AM   #3
boydgti
boydgti's Avatar
10
Drives: 2007 z4m
Did u wait for the oil to settle before u checked it again
      01-06-2013, 07:45 AM   #4
gghg
Drives: 06 M Coupe
Confirm the oil was bottled in liters and not quarts, as a quart is less than a liter.
      01-06-2013, 08:23 AM   #5
Geauxkart
Geauxkart's Avatar
13
Drives: 2007 Z4 M Coupe Sepang
That was my thought.
      01-06-2013, 12:25 PM   #6
jmillet
jmillet's Avatar
64
Drives: 2023 Hyundai IONIQ 6 SEL AWD
Castrol TWS 10W-60 is packaged in one liter containers not quarts.
S54 engine oil capacity and level chacking procedures found here:
http://www.bimmerfest.com/forums/showthread.php?t=41599
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      01-06-2013, 02:33 PM   #7
pungo
pungo's Avatar
Drives: Z4MC-X3-35i-525i, Corrado G60
My guess is the oil jugs were not completely full. Add some more oil to bring it up to the full mark.
      01-06-2013, 02:45 PM   #8
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
65
Drives: 2006 Z4MC Interlagos
You mean the half (mark)
2006 Z4MC - #LL93158
SS Race Cans, RE X Pipe, DKF Sec 1, Fabspeed Headers, OE STB, AS Shifter, Dave Z CDV, GC Coil Overs, Stoptech lines, Hawk DTC Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, Poly FCAB & RTAB, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM
      01-06-2013, 03:31 PM   #9
pungo
pungo's Avatar
What ever than manual says, I don't have the luxury of a dip stick, so don't know. I keep my cars with a dip stick near the full mark.
      01-06-2013, 05:25 PM   #10
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
65
S54 level is half. Most BMW techs overfill our cars...
      01-06-2013, 09:23 PM   #11
bluecobra
Yes, Castrol 10/60 is bottled in liters, not quarts, but I double checked anyway.
I started checking the oil 45 seconds after shutdown and continued checking it until about 2 minutes and it is right at the bottom mark on the dipstick.
The oil was brand new and all the bottles were filled to the same level.
According to the manual there is 1.3 - 1.4 liters between the bottom and top marks on the dipstick so if I fill it to the top mark that would mean 6.5 - 7.0 liters. Seems to be a bit much.
I know it has 5.5 liters in it so I guess I will just drive it at the low mark.....
      01-08-2013, 01:14 AM   #12
Finnegan
Dog Listener
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Unless you're checking the oil in incline I don't see why the oil level should be that low. Is there any chance that the temperature was really really cold, or things were a bit rushed, and there was a portion of oil left in each bottle that did not end up in the car? (Can't see how, but thinking out loud.)
In any case I might add another quarter bottle just bringing up a bit past the bottom fill line. IMO what matters is what can be measured with the dipstick.
      01-08-2013, 01:23 AM   #13
XMetal
XMetal's Avatar
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
What do you measured after letting it sit overnight? Mine usually measured on the low side even after 15-20 minutes of shutdown. However, it always measured near the middle when it has been left sitting overnight.
      01-08-2013, 01:52 AM   #14
Finnegan
Dog Listener
Finnegan's Avatar
^Good question.
      01-08-2013, 06:18 AM   #15
inTgr8r
inTgr8r's Avatar
2432
Drives: M2 Comp
That's why there is a sticker under the hood with the idle, then 60 second shutdown procedure.
      01-08-2013, 03:36 PM   #16
bluecobra
I will check it cold tonight as the car has been sitting in the garage for 2 days.
And I was checking the level with the car sitting in the garage, which is flat so there couldn't be any incline issue. It was around 55 degrees when I changed the oil so I doubt I left much in the container on the pour.
It is just weird because I never had this issue with either of my E46 M3s.
One other questions - I am not the original owner of the car - is there any aftermarket way to increase oil capacity?? The car has a lot of mods on it but other than the Dinan throttle bodies, Dinan software and a J&B liteweight flywheel, I haven't found any other engine mods, mostly only chassis/diff stuff.
      01-08-2013, 03:56 PM   #17
Finnegan
Dog Listener
Finnegan's Avatar
Upgraded (larger) oil cooler is the only one I can think of. That would add some capacity. Take a look, but I doubt it's going to be easy just looking w/o a comparison, gmd2003 has one.
After we've exhausted all the possibilities and run down things like temp, incline, start/stop procedure, etc., I still think what the dipstick says is ultimately what matters.
      01-08-2013, 09:41 PM   #18
aerobod
Car Geek
aerobod's Avatar
3626
Drives: Caterham R500, M2-G87, Macan S
If you are not measuring the oil level after following the proper procedure, then it can vary considerably (more than 0.5 litres) from the proper reading. Car should be fully warmed up (oil temp around 90°C / 195°F), then parked on level ground, idled for 15 seconds before shut-off, then wait for 1 minute before taking the measurement.
      01-09-2013, 09:06 AM   #19
bluecobra
I guess you didn't read any of the thread - I followed the "procedure" to the letter and, with 5.5 liters of oil put into the motor after the change, the level is AT the low mark on the dipstick.
I checked the level with the motor cold and it is about 1/3 above the low mark. I will add a little and drive it. The car has never used any oil so it should be fine.
I was mainly curious if anyone had experienced this before.
      01-09-2013, 04:55 PM   #20
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
65
5.5L should bring it to ~ halfway between the markings on the dip stick.
      01-09-2013, 08:50 PM   #21
aerobod
Car Geek
aerobod's Avatar
3626
I did read the thread, but when you said "Started it and checked for leaks, no problem, shut it off and waited for a minute to check the level", I didn't read any indication whether you had fully warmed it up, then idled it for 15 secs before shutdown, as this part of the procedure has an effect on the oil level. If it is run and shut off when the engine is cold, a lot less oil will drain back into the pan over a period of a few minutes compared when the oil is hot, giving a lower oil level. Also, 5.5 litres of engine oil at 10°C has a volume approximately 0.3 litres less than oil at 90°C.
      01-10-2013, 10:57 AM   #22
bluecobra
Yes, I also stated that I drove it to the gas station and back and checked again. But, thanks for your input.
zpost
