      01-04-2013, 09:06 AM   #1
Tee-Dub
Tee-Dub's Avatar
Drives: 2008 135i
Question Valve cleaning possible without media blasting?
I found a local indy shop that comes very recommended, specialize in BMW, yadda yadda yadda. He and I have spoken a few times via email, and I asked him about doing the intake valve cleaning for DI motors and he stated that he does them and has done quite a few on BMW, Mini, and Audi. I called him the other day to ask about installing DP's, and remembered to ask about the intake valve cleaning and what he charges. He said its called an "Induction Service" and it is $179! Said they don't remove the manifold and media blast, that would be insanely expensive. He claims his induction service sees results and he's done quite a few of them.
Now, I'm feeling skeptical of this shop. Whats the general consensus? Has anyone heard of such a thing working using chemicals instead of physically getting in there and cleaning the stuff?
      01-04-2013, 10:14 AM   #2
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
I bet they use something like this...
BG makes some good products... but I am not so sure it really addresses our carbon buildup problem on the N54/N55 motors. Also... BG is not sold in stores, but only thru repair shops. They have a "kickback" program: everyone from the parts and service manager, to the SA down to the tech gets a kickback. I have always found that kind of fishy to me.
      01-04-2013, 10:30 AM   #3
lastMleft
lastMleft's Avatar
Drives: e92 M3
If you need a good indy shop across the bridge in PO off of Powell (PacificMotorsport) 503-232-5545, they perform the wallnut blast cleaning and are also reasonable priced for all other services
      01-04-2013, 11:03 AM   #4
Tee-Dub
Tee-Dub's Avatar
Drives: 2008 135i
Thanks for the heads up Rukuss! I bought the car from Luxeautohaus and they had it serviced by ProTek auto, which is in the same building. I had them put new plugs in. They said they'd install DP's, for $350 but they don't do the walnut blast cleaning.
      01-04-2013, 02:43 PM   #5
Tee-Dub
Tee-Dub's Avatar
Drives: 2008 135i
Called them today. They aren't completely set up to do the process yet, but should be by next week. Said they'll do an intro price of $399 and need the car for half the day. He is supposed to call me next week.
      01-04-2013, 03:21 PM   #6
lastMleft
lastMleft's Avatar
Drives: e92 M3
Sweet they installed a CDV delete and a short shift kit on my car, and also they worked on my 335i back in the day, I have nothing bad to say about them, they are honest and fair priced
      01-04-2013, 03:24 PM   #7
Tee-Dub
Tee-Dub's Avatar
Drives: 2008 135i
Now to decide who is going to install my DP's and my intercooler when they come in!
      01-04-2013, 03:26 PM   #8
lastMleft
lastMleft's Avatar
Drives: e92 M3
Did you run this by them?
      01-04-2013, 03:30 PM   #9
Tee-Dub
Tee-Dub's Avatar
Drives: 2008 135i
Briefly mentioned it and they said they do performance stuff, but didn't give me a price. Getting the car over there and getting back is an issue for me. Since the intake cleaning takes "half a day" as they said, I'd probably have to do the DP's and FMIC later, unless they can do it all at once. Doubtful since the car has to be on a lift for the DP/FMIC install and on the ground for the valve cleaning.
      01-04-2013, 03:37 PM   #10
lastMleft
lastMleft's Avatar
Drives: e92 M3
They might give you a discount for all three, worth a mention
      01-06-2013, 01:36 PM   #11
FIRST1
Drives: '15 M235i Melbourne Red
I am very interested in getting my intake valves cleaned, I'm coming up on 50K miles, so let me know if you get this done, and if you do, see if they can take pics!
      01-06-2013, 02:21 PM   #12
john_w_lewis
Drives: 2008 E82 135i
Originally Posted by FIRST1 View Post
I am very interested in getting my intake valves cleaned, I'm coming up on 50K miles, so let me know if you get this done, and if you do, see i they can take pics!
Ditto
John Lewis
2008 BMW 135i | Sedona Red | 6MT
      01-08-2013, 02:26 PM   #13
FIRST1
This thread needs more attention! This could be a breakthrough!...
      01-08-2013, 03:09 PM   #14
1911A145
1911A145's Avatar
34
Drives: 135i
An induction service wont do anything to rid the DI system of its carbon buildup. This has been discussed in many, many other threads. The BG stuff is good stuff, but for the right application its intended for....
I have a friend who owns his own shop and uses BG products. Ive bought a bottle of the 44k for about 15 bucks I think. These shops are charging you labor mostly, not for the chemicals that make up some of these ridiculous repair bills. 180 for fuel induction service = seafoam or similar induction that cost them under 2o bucks in shop fees and straight profit on the labor....
Stay away from those who promote the induction service and find yourself someone who can do the media blasting on the valves. Can you clean the carbon off the valves without the walnut media blaster? Of course... It's done daily all over with the same process of removing the intake manifold, but the mechanic is taking more time and using chemicals the dissolve the deposits and using brushes and picks to scrape away all the gunk. The walnut blasting was designed to be faster and more efficient than the chemical scrub for DI engines and if you can find someone who can do it for under 600 than go for it. it's worth it.
      01-31-2013, 10:20 PM   #15
mineo77
mineo77's Avatar
Drives: 2010 135i,1989 PRO3,2001 530i
2010 135i coupe  [7.56]
having mine walnut blasted as we speak. Tried a fuel injection cleaner and that didnt do much of anything.
best shop in Portland for the N54 IMO is Rhom Innovations.
      02-24-2013, 04:44 PM   #16
mineo77
mineo77's Avatar
Car runs like new after walnut blasting...it was amazing the difference
      02-24-2013, 05:13 PM   #17
BMW86
Australia
398
Drives: RS3 Sedan / Macan S
I really need to do this!
      02-24-2013, 06:37 PM   #18
shah269
Drives: 2009
christ on a cracker....and they could have prevented all this shit by installing an extra set of cheap low pressure injectors on the other side of the intake valve to wash the freaking things on start up....WTF!
      03-21-2013, 04:10 PM   #19
JDelphiki
Drives: 2009 TSM 135i
A buddy of mine owns a tuning shop in SA, TX. He removed the carbon build up on my 60k mile 2009 135i.
He didn't want to do the media blasting method, but instead opted for the soaking method. He did my 60k maintenance at the same time as the intake valvle cleaning and had it all done the car back to me in 2 days. The price I paid for 60k maintenance and valve cleaning was great.
My intake valves had severe carbon build up. We're gonna do another valve cleaning before I get a meth kit on the car to see what kind of difference we see after 20k more miles.
He's actually looking for a 135i for himself if anyone is looking to sell theirs; he recently tuned a 135i for someone and was so impressed with the gains that he wants to tune his own.
Here's his contact info if anyone wants to get a hold of him for any reason.
William
Precision R
210-829-8200
