BMW M3 Forum (E90 E92)
Mporium BMW
      01-03-2013, 03:30 AM   #1
Richard@M-World
Richard@M-World's Avatar
Drives: NASA TTA #92 M3
Arrow BBK - Wheel Fitment Compatibility Database
I thought this may be helpful for those shopping for a BBK and wheels. Let's focus on 18" wheels because 19" wheels should clear most BBK on the market for M3. Also, rear kits other than the ones listed below should work on 18" wheels.
Please respond with your BBK and wheel specs. I will compile everyone's input and update this post as often as I can.
Disclaimer: many variables can affect BBK - wheel fitment compatibility. Always check the clearance after installing new components. When in doubt, consult with your supplier and/or manufacturer. Use information below at your own risk.
Alcon 384 F
Volk Racing TE37SL 18x9.5 ET15
Alcon 370 R
Volk Racing TE37SL 18x10.5 ET20
AP 368 Front
Yes
Apex EC-7 18x10 ET25
Apex EC-7 18x9.5 ET22
No
Brembo 380 Front
Yes
Volk Racing TE37 18x9.5 ET22
BBS FI 18x9.5 ET20
No
OEM 18x8.5 ET29
OEM 18x9.5 ET23
Brembo 365 Front
Yes
OEM 219M 18x8.5 ET29 (need low profile weights or 10 mm spacer)
OEM 219M 18x9.5 ET23
TRMotorsport 18x10 ET25
Apex ARC-8 18x9.5 ET22
Apex ARC-8 18x10 ET25
No
Brembo 380 Rear
Yes
Apex ARC-8 18x10.5 ET27
Apex EC-7 18x10.5 ET27
Apex EC-7 18x11 ET25
BBS FI 18x10.5 ET25
No
OEM 18x9.5 ET23
PF 372 Front
Yes
HRE R40 18x9.5 ET23
HRE R43 18x9.5 ET2118x10et22 R
PF 371 Rear
Yes
HRE R40 18x10 ET25
HRE R43 18x10 ET22
StopTech 380 Front
Yes
OEM 219M 18x8.5 ET29 (need 10 mm spacer)
OEM 219M 18x9.5 ET23 (double check wheel weights)
BMW Motorsport GT4 18x9.5 ET25
HRE R43 18x9.5 ET22
StopTech 355 Front
Yes
Apex ARC8 17x10 ET25
Authorized AiM Dealer - Solo/Solo DL | SmartyCam HD | www.m-world.us
      01-03-2013, 04:18 AM   #2
mlhj83
Scythe-Meister
mlhj83's Avatar
United Kingdom
90
Drives: '11 E92 M3 ZCP | F80 M3 CS
Nice one. Probably best to also differentiate OEM 219M and 260M.
      01-03-2013, 07:31 AM   #3
M3SQRD
M3SQRD's Avatar
2164
Drives: E92 M3,G20 330ix,F22 240iX,F82
PFC 372/371 BBK fits under the stock 18" 219M wheels (no spacers required)
Also, it easily fits behind HRE R40 18x9.5et23 F and 18x10et25 R, and HRE R43 18x9.5et21 F and 18x10et22 R wheels
      01-03-2013, 11:38 AM   #4
mlhj83
Scythe-Meister
mlhj83's Avatar
United Kingdom
90
Do you have any pictures of the clearance between the calipers and front 219Ms? Cheers.
      01-03-2013, 12:26 PM   #5
M3SQRD
M3SQRD's Avatar
2164
No pics. No longer have my stock wheels so I can't take pics either. However, this kit was designed to work with the stock 219M wheels - if you don't believe me contact James at BimmerWorld because his e92 M3 with 219M wheels was used to develop this kit...
      01-03-2013, 12:47 PM   #6
mlhj83
Scythe-Meister
mlhj83's Avatar
United Kingdom
90
That's ok. Do you have a picture or can you point me to the right picture showing the floating mechanism of the discs? I've googled, but there are a number of variations and I don't know which one the M3 kit uses. Thanks.
      01-03-2013, 12:54 PM   #7
mlhj83
Scythe-Meister
mlhj83's Avatar
United Kingdom
90
Found it, is this the same as the one on the M3 kit?
      01-03-2013, 12:58 PM   #8
M3SQRD
M3SQRD's Avatar
2164
It uses their direct drive V2 floating rotor design:
http://www.performancefriction.com/m...ake-discs.aspx
http://store.bimmerworld.com/perform...kit-p1823.aspx
      01-03-2013, 01:00 PM   #9
M3SQRD
M3SQRD's Avatar
2164
Yes it is (this looks like it's the rear rotor from the e9x M3 BBK) - V2 direct drive floating rotor
      01-03-2013, 01:09 PM   #10
LiM3y
LiM3y's Avatar
United Kingdom
70
Drives: 2008 E90 M3
Any data on 18x10 Apex ARC-8s? Or if they fit OEM, they will fit ARC-8's?
      01-03-2013, 01:11 PM   #11
mlhj83
Scythe-Meister
mlhj83's Avatar
United Kingdom
90
      01-03-2013, 02:08 PM   #12
Richard@M-World
Updated. Keep them coming guys!
      01-03-2013, 04:50 PM   #13
M3PO
M3PO's Avatar
84
Drives: '08 IB E92
edit: The previous owner has informed me that the grooves were caused by pebbles getting jammed between the caliper and the barrel NOT the brakes themselves!
I have a set of Advan TCIIIs (18x10.5 +25) that belonged to another member who had 380mm Brembos all around. Three wheels have shallow grooves from the brakes (the bolts on the calipers I guess) rubbing the barrels. Presumably during heavy use when everything has expanded. Not sure what category they belong in considering that.
2008 IB E92 M3| BBS | KW | Arkym | Platte Forme A.G. | Active Autowerke | K&N | Fabspeed | Dinan | Evolve-R
      01-03-2013, 05:39 PM   #14
surlynkid
surlynkid's Avatar
115
Drives: 2013 E92 M3
my 380mm front stoptechs clear the Apex EC-7 18x10 ET25 with ease. there is a ton of clearance.
      01-03-2013, 07:38 PM   #15
klammer
97
Drives: 11 spc gry m3 e90, 19 X5
From what i've seen, my Alcons clear the TC-III's, TE37(SL), HRE R40's, BBS FI's (actually test fitted) and EC-7's. Might be others, but those are off the top of my head. Oh, and the Alcons have 384 front rotors
mods: track ready stuff
      01-03-2013, 08:43 PM   #16
bigjae1976
bigjae1976's Avatar
1571
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
OEM 18 rears will clear 380mm stoptechs...no spacers. Just have to make sure you put the wheel weights on the inside or the outside of the inner barrel.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      01-04-2013, 07:51 PM   #17
Expert@ApexWheels
BimmerPost Supporting Vendor
Expert@ApexWheels's Avatar
3530
Drives: M3
The EC-7s in 18x9.5" ET22 and 18x10" ET25 will clear the Brembo 6 piston 380mm BBK and the Stoptech 6 piston 380mm BBK up front on an e9x M3, along with the AP Racing 368mm BBK and Brembo 365mm BBK. These same wheels will also clear the 380mm rear BBKs from Stoptech and Brembo also.
The ARC-8s in 18x9.5" ET22 and 18x10" ET25 will clear the Brembo 6 piston 365mm BBK, but not the 380mm version for the fronts. The 18x10.5" ET27 ARC-8s & EC-7s as well as the 18x11" ET25 EC-7s will work in the rear with a 380mm Brembo or Stoptech BBK.
Volk Racing TE37s in 18x9.5" ET22 also clears the Stoptech and Brembo 6 piston 380mm BBK in front of an e9x M3:
We will try to get brake templates for the PFC and Alcon kits to test against both the EC-7s and ARC-8s as well, but usually Brembo utilizes the largest calipers in our experience, so wheels that clear the Brembo 380mm BBK should clear the others as well with the same or smaller rotor sizes.
      01-05-2013, 01:55 AM   #18
Richard@M-World
I would just leave your comment as is so that people can see it and judge on themselves.
Could you please provide the specs for the wheels you mentioned?
      01-05-2013, 06:52 AM   #19
w00tw00t
w00tw00t's Avatar
Drives: 2016 MW M4
Richard thank you for yet another super-useful thread on m3post.com
      01-05-2013, 09:39 PM   #20
Checkcaptain
Germany
549
Drives: BMW M4 GTS
Brembo 380th front and rear clear BBS FI 18" in 9.5x18ET20 front and 10.5x18ET25 rear.
      01-06-2013, 12:05 PM   #21
slicer
slicer's Avatar
2739
Drives: 'E46 M3 Race Car, '23 X7
See the link below for thread with similar content in the wheel / tire section. It would be great to merge the threads...
http://www.m3post.com/forums/showthr...ghlight=18+bbk
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc.
INSTAGRAM - @Slicer_M
      01-06-2013, 09:20 PM   #22
klammer
97
Don't have specs, but from what I've gathered, anything that fits the brembo 380, fits the alcons.
m3post
