BMW M3 Forum (E90 E92)
BPM
      12-25-2012, 06:53 PM   #1
Tobbep
Tobbep's Avatar
Drives: 2022 BMW X6M Competition
KW Sleeve-Over adjustments
I'm trying to adjust my KW Sleeve over suspension. Looking over the instructions from KW, the key thing they recommend is that the "Wheel Hub to Fender edge be at the minimum 13". Looking at my setup (which is too low in my opinion) measures about 12.5" in the rear. What is the downside of having the suspension below 13" and what is the norm for most having installed the KW Sleeve Over? I'm just trying to find a balance between lowering the car and optimizing drivability. I'm really dissatisfied with how the car sits right now so I think it is time for me to fix it. Really don't have much experience with suspension adjustment so any input would be helpful.
Also, I have also heard that I will need a new alignment if I mess with the height. Is this true?
I will post some pictures of before and after tomorrow.
Thanks...
Alpine White/Black Leather
      12-25-2012, 08:11 PM   #2
schnite
16
Drives: E82 1M
ok and minimum 13" is inch ?or other unit
      12-25-2012, 08:14 PM   #3
Tobbep
Tobbep's Avatar
Minimum distances from wheel hub center to fender edge (according to KW) is supposed to be 13 inches or 330mm.
      12-25-2012, 08:37 PM   #4
schnite
16
Drives: E82 1M
thank you
      12-26-2012, 03:40 PM   #5
Tobbep
Tobbep's Avatar
Spent a couple of hours trying to adjust the KW sleeve over today. I'm not very pleased with the results as trying to adjust the height is a pain in the a**. You can only turn the damn thing a fraction at a time with no idea how much you are moving. On top of that the right and left sides are not even. Looking at the car from behind it looks like the right side is higher. But if you look at the wheels the right side is lower.
I talked to KW and they told me that you have to remove the spring for adjustment. Not sure how to proceed. I'm so feed up with this setup I'm really second guessing why I bought it.
Any suggestions on how to fix this damn suspension setup would be appreciated.
Thanks...
      02-24-2013, 12:11 PM   #6
ortho281
ortho281's Avatar
Drives: 2011 E92 M3 6MT
Take it to a shop (i.e. Driver Source in Houston) that does track-setups and have it corner-balanced at your desired ride height. IMO this is the only way to get adjustable springs perfectly level. If you also track your car (solo), you can do the corner balancing with driver's weight in the driver's seat.
http://www.m3post.com/forums/showthread.php?t=790817
http://www.m3post.com/forums/showthread.php?t=801352
      02-24-2013, 01:52 PM   #7
S65V8
*_*
Drives: ...
I'm now so tempted again to just get KW S/Os and deal with the rougher ride looks soooo good and you can corner balance and keep EDC. Really a nice in between option.
      02-25-2013, 12:57 PM   #8
Ervin87
Ervin87's Avatar
Drives: E92 M3 | B5 S4 | E30
The ride is not rough with the S/O kit, especially if you have e36 bumpstops and shortened top mounts.
      02-25-2013, 07:58 PM   #9
M3PO
M3PO's Avatar
84
Drives: '08 IB E92
If you set it low, it can be kind of harsh on bad roads. I can't use my EDC because on comfort mode, the shocks will bottom out (not hitting the bump stops). This is obviously very bad for the shocks. I don't mind keeping it on Sport Plus all of the time but that kind of defeats the purpose.
2008 IB E92 M3| BBS | KW | Arkym | Platte Forme A.G. | Active Autowerke | K&N | Fabspeed | Dinan | Evolve-R
      02-26-2013, 05:27 AM   #10
S65V8
*_*
Drives: ...
I know what you mean, I had these on my last car. Comfort Mode was ok, but eventually 5k miles later it became a bit harsh on bad roads. But damn lowering does look good.
Now that I'm back and on a ZCP car, I have a new found appreciation for the EDC functionality and how well it actually handles in ZCP form. Just wish the car was a tad lower for looks, but I guess you can't have it "all".
      02-26-2013, 09:55 AM   #11
j2m
j2m's Avatar
180
Drives: '11 E92 M3 DCT
2011 BMW E92 M3  [10.00]
I put mine on with about 3,000KM and they are set about 1/2" from lowest setting and I don't bottom out. I wonder if the shocks are wearing over time. I'm sure if I kept them on for several years, the same thing would likely happen
11' E92 M3 Space Grey | DCT | ESS VT2- 625 | Gintani Race (valved) + Quad Res Catless X-Pipe | KW Sleeve's | GC Camber Plates|Arkym Diffuser | Vorsteiner VRS Lip | P3 Boost Guage | Stud Conversion
PHOTO's: Click Here ESS VT2 625 PHOTOS: Click Here
      02-26-2013, 10:05 AM   #12
j2m
j2m's Avatar
180
Thanks...
When adjusting the rear you do have to drop the swing arm a bit, make your adjustment and put the bolt back in. The front are fully adjustable without removing the springs.
I wouldn't mess with trying to dial in height. Install the springs and take your car to get a good alignment/corner balancing. Just make sure the alignment shop knows that you will need some fine tuning of height and tell them how low you want it. It's easier for them to make adjustments when all 4 wheels are in the air
      02-26-2013, 05:47 PM   #13
M3PO
M3PO's Avatar
84
Drives: '08 IB E92
It's only an issue with the fronts and I have them down all the way. I'm not sure about shock wear. The shocks seem to function properly; the car rides and handles well. It does have 59K miles though.
      02-28-2013, 07:14 PM   #14
chris s
chris s's Avatar
1250
Drives: 2022 Dravit G80 M3
if you're at 59k with original shocks...chances are they're done or very close to it i would think.
2022 Dravit/Fiona M3cx - Dinan midpipe w/VC, NW Carbonhaus CF, AST Springs, FC Spacers...more to come!
2016 Indi F80 M3 - SMB|Amaro | Mode Carbon | ESS | Akra EVO | KW HAS...SOLD
2012 MR e92 M3 DCT, ESS SC, Brembo BBK, BBS FI... GONE but not forgotten!
2008 AW e92 M3 6MT, ESS SC, BBS LM's...SOLD!
m3post
