      12-23-2012, 07:11 PM   #1
capri
Philippines
18
Drives: 2011 135i
3 lights on @ the same time:: help needed!
I was cruising @ normal speeds during the holidays and all of a sudden, three lights at the dashboard turned on. ABS, Dynamic traction control and tire pressure monitor system.
Engine seems to be running, all seems fine as i continued driving.
What does this mean when all of these 3 lights turn on @ the same time ?
I was able to drive home safely with all 3 lights on which was roughly around 50 kilometers long.
The BMW dealer is on holidays so no one was there to help me.
Somewhat disappointed as the car is a 2011 with only 7000 kilometers in the odometer.
Please advice and is this possible to continue driving ?
Thanks in advance.
Capri
      12-25-2012, 01:18 PM   #2
Tom K.
Tom K.'s Avatar
Drives: '07 328iT, '13 Boxster
Sounds like there is a fault with the traction control & ABS systems - or with a sensor. If you don't have individual wheel sensors, that would cause a fault with the TPM as well. I would make certain the tire pressures are correct and drive carefully until you can get to the dealer.
Tom
      12-25-2012, 02:04 PM   #3
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
I think your ABS/DTC block/pump just took a dump. There have been a few of these threads before.
Here is a company that can repair them. BMW wants a small fortune for a new one.
http://www.tachopix.de/controlunit/n.../pagetype.iav/
      12-25-2012, 02:39 PM   #4
135IS
33
Drives: 09 LMB 135I / AW 1M
2009 135i  [7.00]
Shouldnt that be fixed under warranty?
LMB 135i: Gone
AW 1M: Current #211 of 220
      12-25-2012, 04:33 PM   #5
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Yes, it should.
