12-18-2012, 11:48 PM | #1 |
10
Rep 71
Ground Control to springs??
Has anyone gone from ground control sleeve kit to H&R sport springs (lowering springs period)? I purchase an used e92 M3 that had ground control sleeves and the ride is pretty harsh, but it could just be the streets of houston.
If I was to switch would there be any parts that were thrown away from the install of the GC sleeves that would be necessary for springs install? Thanks for the input! |
12-19-2012, 12:27 AM | #2 | |
721
Rep 3,964
Dave
2020 Ford Mustang GT 6MT PP1 444rwhp
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk |
12-19-2012, 12:11 PM | #3 |
2739
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
I would contact GC and discuss softer springs with them. You can pick your spring spec based on your needs. Plus you can adjust the ride height to add more suspension travel for more comfort. Far better option than going to H & R springs.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
12-19-2012, 05:12 PM | #4 |
36
Rep 927
You might be too low and using a lot of your bump stop. Peek in the front wheel well and see how much of the rod you see.
If the PO didn't put shorter bump stops in there, that would cause the problem as well.
Craig Brickner
Click to Join: BMWCCA # 366493 |
12-19-2012, 06:43 PM | #5 |
10
Rep 71
Thanks .. I'll try and check it out maybe I'll need to raise it a bit. I think it was only a 20mm drop.
12-22-2012, 08:30 AM | #6 |
2164
Rep 5,548
I agree with everyone that's saying stick with the GC sleeve-over kit rather than switching to lowering springs. Contact GC and swap out the current spring rates for softer F and R rates
