ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      12-16-2012, 04:05 PM   #1
3002 tii
3002 tii's Avatar
2286
Drives: Z4 M, X5, GX460
In the middle of Installing Brake Ducts, Can Anyone Identify this Part?
I'm in the middle of installing a brake duct kit on my non-M coupe. I've cut a hole through this side plastic trim to route the hose. However it appears I need more slack because the tube currently bends too much and forces the oe grills to pop out (too much tension in the tube and oe lower grill clips suck a$$). I know I could keep cutting but it would seem much simpler if I could remove this piece all together.
Does anyone know what the p/n is for the circled red piece? It's definitely plastic although the bar right above with the bolts are metal
Follow for latest mods
      12-16-2012, 04:09 PM   #2
3002 tii
3002 tii's Avatar
2286
Bump
      12-17-2012, 10:18 AM   #3
v3.2mc
Not a New Member
v3.2mc's Avatar
Drives: with both hands and both feet
2007 ///M Coupé  [10.00]
should be the 90* splash shield in front of the wheel liner.
51717168995 = left
51717168996 = right
here is a pic of the material that can likely be removed (in red)...
#1498E86 | Sepang Bronze | Dark Sepang Leather | Carbon Leather Trim
      12-18-2012, 09:00 AM   #4
v3.2mc
Not a New Member
v3.2mc's Avatar
how about something like this? there should be more than enough room between the condenser/radiator assy and the 90* shield for the hose.
      12-18-2012, 09:04 AM   #5
3002 tii
3002 tii's Avatar
2286
Attachment 797641
EDIT:
I see what you're saying, hmm... maybe if I get a 3" flange that might work. I just don't recall if that flap area you've cut out actually has space between the trim and radiator or if it sits directly flush, in front of the radiator, which in that case there's no space to squeeze a hose in between.
Btw, your MS Paint skills are quite impressive.
      12-18-2012, 10:43 AM   #6
v3.2mc
Not a New Member
v3.2mc's Avatar
sometimes, i feel like it's my ONLY skill.
i'll go practice some more...
zpost
