12-09-2012, 09:22 PM | #1 |
83
Rep 954
Backseat removal question
I am trying to remove the backseat in preparation for the track day. I removed the bottom cushions, now in order to remove the backrest I need to remove the side cushions (pictured). I can't figure out how to get them out. COuld you guys help me out?
Thanks |
12-09-2012, 10:26 PM | #3 |
BimmerPost Supporting Vendor
8215
Rep 18,823
Drives: BMW
^^ pretty much. Grip just under the black cap and try to reach your fingers around the backside before pulling. Afterwards, it should simply lift out of place.
12-09-2012, 11:16 PM | #4 | |
83
Rep 954
Tom, if it doesn't rain, I'll show up on the 16th. |
12-10-2012, 12:06 AM | #5 | |
83
Rep 954
OK, I got through this part, the trick was to pull down as well. I unscrewed two star bolts on the left and the right, but what's the trick to undo the middle attachment (pictured)? |
12-10-2012, 01:16 AM | #7 |
78
Rep 684
You will have to keep the rear seat backs at a 45 degree angle or so from horizontal to have access to the two bolts holding the middle hinge. It's a PITA.
12-10-2012, 01:19 AM | #8 |
78
Rep 684
Here's a picture showing the position of the screws.
12-10-2012, 01:38 AM | #9 | |
IG: limited.slip
332
Rep 1,918
Basically at this point you just have to work the seat backs out and away from each other. Have them folded down and pull one side away from the other and toward the front. One of the seat backs has a stud and the other a receiving hole. Not completely dissimilar to the shift lever and the knob to give you an idea. You have to use a bit of force to separate them. That bracket that Richard mentioned I never removed to get the seats out. |
12-10-2012, 01:47 AM | #10 | |
78
Rep 684
12-10-2012, 09:07 AM | #11 |
39
Rep 1,590
Very easy. Fold one seat slightly forward and pop it out. If you look at it you'll see one seat has a peg that goes into a hole on the other which allows it to fold and move. Just give it some force and it'll pop out
12-10-2012, 03:32 PM | #13 |
83
Rep 954
Thanks guys for all the advice. In fact before posting here I got one of those bolts out, it was a royal pita. I'll try the separation method as I am not really looking forward to removing the second bolt... I'll report back
12-10-2012, 11:00 PM | #14 |
83
Rep 954
OK. Not that I enjoyed the process, but it is way easier when you actually know what you 're doing. It actually pulls right off, it's just this damn "bolt" is way too long (see the pic)
I just want to see for myself how much weight reduction helps and how much it can screw up the balance if it does affect it. With the recent install of a 36 lb battery at EAS, I shed over 150 lbs I think! The car feel alive |
12-12-2012, 12:15 AM | #17 |
83
Rep 954
OK, I weighed some parts on my home scale and ran some numbers. My car right now is 230 lbs lighter than stock. In addition to destroying the trim, I am running 35 lb MINI battery, full Akra Evo exhaust and 18" TE37SL.
I dynoed the car last week at EAS and it did 398 WHP! (Evolve tune, MS pulleys and MS Stage 2 Intake in addition to Akra). After all this the car feels video of the dyno run http://www.youtube.com/watch?feature...&v=vRdIwoU4LHU Last edited by thorny; 12-12-2012 at 12:26 AM.. |
12-12-2012, 09:57 AM | #22 |
Havin' a blast!
125
Rep 4,847
BRP 1:56 | CVR 2:01 | ACS 1:53 | WSIR 1:34
