      12-05-2012, 07:35 PM   #1
sochermit
Drives: 2003 325i, 2012 135i
Washer Fluid
Can I use 50/50 mixture of vinegar and water for the window washing fluid?
      12-05-2012, 10:18 PM   #2
bmw1racer
bimmerphile, technogeek
bmw1racer's Avatar
Drives: 2012 E82 6MT Sport
I'd be a little bit leery about having an acid (albeit a weak one) sitting in my washer reservoir: Any metal plumbing in that washer fluid path could get corroded.
      12-06-2012, 05:35 AM   #3
sochermit
good point
Thank you, that is a good point. I guess than any auto window washer fluid would be alright? I think the BMW fluid is rather expensive. Does it have anything special in it, that you may know of?
      12-06-2012, 08:51 AM   #4
bmw1racer
bmw1racer's Avatar
Not sure about the BMW fluid, but I think all washer fluids have some kind of alcohol/antifreeze component in it so that it doesn't freeze in the winter months.
Being in SoCal, I don't really worry about freezing, so I just use distilled water and a couple of drops of car wash soap (for better cleaning action)... And it won't damage the paint like an alcohol-based fluid possibly could.
      12-06-2012, 12:47 PM   #5
JimD
JimD's Avatar
368
Drives: 128i convertible
The one thing the Performance Center missed in my delivery is filling the washer fluid resovor. I didn't notice it until I got home. I had a gallon of generic washer fluid from Walmart on hand so I just filled it up. I didn't know at the time BMW has their own kind. It works fine for me. That was over 3 years ago and I don't think it has ever had BMW fluid.
I wouldn't use vinegar either. It is not real agressive but it also might support growth of something - it is organic.
Jim
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09
      12-08-2012, 05:12 AM   #6
sochermit
Thanks for the responses.
      12-10-2012, 03:34 PM   #7
shodanusmc
21
Drives: 09 135 Vert
Have used generic washer fluid in all my cars for the past 40+ years in Chicago winters. Never a problem. I also would not mix vinegar into the equation.
      12-23-2012, 05:34 PM   #8
Newby
1Mtech
Drives: BMW
There is no metal lines in washer system, still don't use vinegar. You can even just mix in some house hold window cleaner. You dont actually need to add much cleaner, the BMW bottle would ony be about 150-200ml or so.
      12-23-2012, 09:03 PM   #9
RWD4Life
RWD4Life's Avatar
Drives: 2018 M2 (MG 6MT)
What's the point of you going through the hassle of mixing water with vinegar when you can get a gallon of good washer fluid for less than 5 bucks?? Just go to your local auto parts store and you'll be all set.
      12-24-2012, 01:49 AM   #10
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
Vinegar... Imagine the smell...
      12-24-2012, 05:10 AM   #11
sochermit
Thank you for all your helpful comments. I think I have the idea and will only use normal store bought window washing fluid.
