11-27-2012, 01:56 AM | #1 |
Essayons
45
Rep 424
Constant high speeds
Just curious if driving at 140+ for extended periods of time would cause more oil blow thru, or help burn off the carbon that may build up on the intake valves on a N55 motor?
/ 135i - M-Sport / 6-Speed / BMW Performance Exhaust / BMS Intake / JB4 Stage 2 ISO + Flex Fuel Wires / BMS 3.5in Down Pipe / CP-E Charge Pipe / Walbro 255 in-line fuel pump / BMS H8 AE / BMS SSK / APEX EC-7's with Nitto NT05's / COBB Tuning Sport Springs / Koni Yellows / Wagner Evo 1 / Blacklines / iCarbon Rear Diffuser / BMW Performance shift knob/boot / BMW Performance Steering Wheel /
11-27-2012, 06:55 AM | #2 | |
53
Rep 941
have a BMS one now and still no oil caught.. lol. but im in states now and drive 65 max.. lmao.. boooooring..
JB4, DCI, Digi boost, CSL eyelids, 5% tint, KW v2's. Bastuck 85mm quad w/ berk resonated mids, LED int ltg, Perf SSK, CF int trim, 19" SF-71 rims, CDV mod, BMS OCC, ER+tial charge pipe. AR DP's, Helix IC,meth, drilled slotted rotors
11-27-2012, 08:31 AM | #3 |
66
Rep 1,267
Drives: AW 135i
Its more the engine rpm you are running than what speed you are going, the speed is irrelevant. If you are running at a higher rpm than normal there is gonna be more blow by yes. Its probably not gonna help burn carbon off in any way...
