BMW M3 Forum (E90 E92)
BPM
      11-24-2012, 02:19 PM   #1
M4Now!
292
Drives: MG / SO F83
Cleaning cross-drilled rotors?
I couldn't find this in a search, and it's an odd question: the cross-drilled openings in my rotors are full of brake pad dust - some are completely closed, others are half-full. Is this normal?
I understand the purpose of cross-drilling, and this doesn't seem optimal? I cleaned them out, just wondering if a) this is normal and b) requires maintenance?
Thanks!
Bye bye E93 M3 - Hello F83 M4!
      11-24-2012, 03:23 PM   #2
C|3R1C
So Kewl Guy
C|3R1C's Avatar
49
Drives: 2010 E93 M3 DCT
Happened on my OEM ones constantly. I believe it's normal. I just used a hose with pressure to clean them out each time.
2010 E93 M3 / MS Catless X-Pipe / AA Catback / Vorsteiner Vented Hood and Bootlid E93 Trunk / ADV1 7.1 Wheels GB / LS3 LED Lights / Harrop Supercharger
      11-24-2012, 05:25 PM   #3
dex37
dex37's Avatar
12
Drives: E92 M3
You can also use screwdriver or something similar.
      11-24-2012, 08:48 PM   #4
Car54
36
Drives: 2014 M-Sport Wagon - EBII
Would compressed air do the trick?
      11-24-2012, 08:56 PM   #5
Richbot
2760
Drives: Jerez Black E90
4mm allen t-handle
      11-24-2012, 09:57 PM   #6
Amri215
Amri215's Avatar
12
Drives: 2012 Alpine White M3
What bad advice being given here..do not "gauge" at the holes with any tools. Try washing and spraying with a hose
      11-24-2012, 10:53 PM   #7
C|3R1C
So Kewl Guy
C|3R1C's Avatar
49
What he said.
Just a hose or compressed air works. The dust doesn't fuse itself in. It's relatively easy to remove and comes off with gentle force. If you wash your car yourself, just aim the water on each hole directly and the dust breaks free and your done. Proceed with the rest of the car.
      11-25-2012, 12:55 AM   #8
M4Now!
292
Drives: MG / SO F83
Bueno - partially cleaned them out with a bamboo skewer (bbq), will wash them out fully while washing tomorrow.
Cheers
      11-25-2012, 08:01 PM   #9
Richbot
2760
. i think you mean "gouge" but you aren't going to hurt a steel rotor that sees 1200+ degrees and thousands of lb-ft of torque sticking something in the holes to clear them. You know the inboard face of the rotor has holes in it too, right? How well does spraying water clean the inboard side? What happens when a clod of wet brake dust gets stuck in a vane? It turns to cement as soon as it dries.
      11-25-2012, 09:04 PM   #10
Amri215
Amri215's Avatar
12
Yes I meant gouge..and yes you can damage the OEM galvanized coating on the surface of the rotor. It has nothing to do with the rotor's thermal capacity
If you have plugged up brake rotor holes you are simply not washing the car enough..as others have said simple hose will take care of it..nothing turns to cement.
On the inboard side it wouldnt matter as you cant see it..we are talking only aesthetics here.
      11-25-2012, 10:02 PM   #11
Richbot
2760
Galvanized!? No. The floating rotor is bare iron. Look at photos of oxidation inside the holes and inner radius on used rotors for proof, or just know what a zinc coated part looks like and realize they aren't coated...
      11-26-2012, 08:37 AM   #12
Porschefile
Porschefile's Avatar
59
Drives: E92 M3
I used q tips with Brakleen on my Cayman, I don't think it does anything other than improves looks though. They would get full of stuff again in like 1 track day.
      11-26-2012, 04:28 PM   #13
Richbot
2760
It's probably about 30g of unsprung rotating weight! -0.5 seconds! +50hp!
      11-27-2012, 11:28 AM   #14
M4Now!
292
Drives: MG / SO F83
LOL
m3post
