      11-11-2012, 11:39 AM   #1
Pablito1702
Pablo
Drives: 2009 135i
I was accelerating (with wide open throttle) on to a very long freeway access road when at around 4500-5000 rpms and climbing (probably in 3rd gear) my engine had a very sudden and immediate drop/cut in RPMs and power. It felt like something had " blown or popped" or almost like a switch had been thrown to cut engine power.
I immediately thought "there goes the charge pipe". The check engine light came on and the engine ran very rough at lower rpms while I limped off the freeway. Engine light turned off after a few miles and after a few more miles of cautious driving normal engine response returned. After a few days of driving everything seems normal and there are nor service codes or warnings. Any ideas of what may have caused this? It was such an extreme event and then to have no continuing driveability issues seems odd. (2009 N54 47K miles)
      11-11-2012, 03:20 PM   #2
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
Anyway inspect your charge pipe if it will be fine. Look for boost leak somewhere.
If you have possibility scan error codes I bet you will find boost leak.
      11-11-2012, 11:17 PM   #3
HIPSI
21
Drives: 08 135i
Ihad similar awhile back, not WOT but I did power out of a turn, car hicupped, check engine light came on, significant loss of power, poor idle etc. Pulled off into a parking lot, turned the car off, then back on, no change. Started to limp toward my dealer which was only a mile away and as I did it cleared up. Turned car off, then back on a second time, light was gone and the car has run normally ever since. This was propably two months and over 1000 miles ago. I figured it was some junk in an injector that caused a misfire but really don't know...
08 135 Coupe SGM/Terra
15 Porsche Macan S- Family Hauler
22 C8 Corvette 3LT HTC
      11-15-2012, 10:28 PM   #4
froop
froop's Avatar
Australia
171
Drives: 08 AW 6MT E82
It sounds to me like your HPFP is dying. I had mine fail at around 60,000km. It first started happening when I was overtaking or accelerating with WOT. After driving a bit or turning the car on/off it would be fine for a while. Eventually it started happening more frequently and with even less throttle. Took it into the dealership and they replaced it. Extremely common problem with the earlier N54s.
      11-15-2012, 10:37 PM   #5
Lester
295
Drives:
Vanos solonoid fail.
      11-19-2012, 01:03 PM   #6
Ammonia
Ammonia's Avatar
Drives: 440i GC
Did you ever find out what the issue was?
      12-16-2012, 02:14 PM   #7
Pablito1702
Pablo
Drives: 2009 135i
Was an isolated incident and car has run fine since.
BMW PPK V2, M3 26mm sway bar, M3 front control arm kit, M3 steering wheel, BMW 313 wheels w Michelin PSS
      01-13-2013, 10:04 AM   #8
Pablito1702
Pablo
Drives: 2009 135i
Reported event to dealer at most recent service this is what service ticket said: "faulty Low pressure fuel sensor. Performed short test on vehicle and found fault codes 29D1 CYL 5 misfire, 29F3 fuek low pressure electric, and 2A2D fuel low pressure system fuel pressure. Performed test plan for fault which advised to replace the sensor."
