ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      11-08-2012, 10:41 AM   #1
zBone
Megatron
zBone's Avatar
Drives: 2007 IB Z4MC
Winter Tire Questions
Hey guys - couple of quick questions.
I'm looking for a winter tire/wheel setup. This is what I'm ready to purchase from TireRack:
2x 17x7.5 Sport Edition F5 Silver Painted Front (20mm offset)
2x 17x7.5 Sport Edition F5 Silver Painted Rear (+40mm offset)
4x 225/45R17 Bridgestone Blizzak WS70
Total, with shipping, is about $1,300.
First, is 17x7.5 (I'm going to confirm that these will fit over the stock rotors on the M) better than, say, an 18x8 square setup? I chose 17 because the tires are cheaper and more widely available.
Second,I keep getting warning messages about TPMS sensors being required for installation. Is this an actual requirement, or is it just a liability thing? Will most tire places install without? If not... any recommendations on where to get a cheap set?
Thanks all!
      11-08-2012, 01:27 PM   #2
EenyBear
Accidentally in BMW
EenyBear's Avatar
15
Drives: Z4MC & R1200S
2003-2008 Z4 BMW Z4 2.5i Z4 3.0i Z4 3.0si Z4 M Roadster M Coupe
P# 36 23 6 781 847
http://oewheelsllc.com/TPMS-Sensors_...ressure-Sensor
and these on ebay may be OK:
http://www.ebay.ca/itm/Standard-Moto...e374db&vxp=mtr
      11-08-2012, 02:02 PM   #3
ncnmra
ncnmra's Avatar
39
Drives: 2006 M Roadster
Apparently not all Z4Ms have TPMS. Not sure how to really verify that though?
      11-08-2012, 02:56 PM   #4
zBone
Megatron
zBone's Avatar
I believe in 2006 they didn't; 2007+ they did.
      11-08-2012, 03:00 PM   #5
zBone
Megatron
zBone's Avatar
P# 36 23 6 781 847
Thanks. Ugh. I really don't want to shell out ANOTHER $200 for these stupid lil things. I check my tire pressure every other fill up.
      11-08-2012, 03:48 PM   #6
RADRACR
RADRACR's Avatar
Drives: '08 Z4 M Coupé // '09 X5 d
Your offsets look off. 20mm in front is aggressive but may still work, 40mm in rear with 7.5" wheels is going to look... bad.
Never heard of the TPMS requirement or the liability reasoning. Then again, I get my mounting done at mom & pops.
'08 Z4 ///M Coupé (#1765/1815) — 1 of 68 Sepang Bronze / Black Nappa / Madeira Wood / 1 of 1 this combo
19" Advan RS / AP Racing / Bridgestone RE-11 / Autosolutions SSK / R.E. Diablo / R.E. trans mounts
'09 X5 35dSpace Grey / Saddle Brown
20" Forgestar F14 / SCR Delete
      11-08-2012, 04:42 PM   #7
WAMz4
WAMz4's Avatar
Drives: 2006 Z4 3.0si Roady
As of 2007 all passenger vehicles sold in the U.S. are required to have TPMS installed. Most manufacturers were in compliance in 2006.
The Internet said it. I believe it. That settles it!
      11-08-2012, 06:54 PM   #8
Huz-Z
Huz-Z's Avatar
851
Drives: Z4 3.0si, 328 XDrive, X5 35i
2006 Z4s have the feature, but it works by measuring differences in rotational speeds through the ABS system, not through those little devices on the wheels of 2007 and later cars.
Huz-Z
BMW Z4 3.0si Roadster. Montego Blue Metallic. Premium and Sport Package.
      11-08-2012, 07:09 PM   #9
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
65
Drives: 2006 Z4MC Interlagos
Correct - 2006 TPWS off ABS sensors.
2006 Z4MC - #LL93158
SS Race Cans, RE X Pipe, DKF Sec 1, Fabspeed Headers, OE STB, AS Shifter, Dave Z CDV, GC Coil Overs, Stoptech lines, Hawk DTC Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, Poly FCAB & RTAB, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM
      11-09-2012, 08:18 AM   #10
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
zBone, can you hold out for a few more weeks? I'm expecting to buy a set of used wheels/tires with TPMS in the next few weeks, to use for winter. I have an 06 though, and was planning on pulling the TPMS out.
If you're interested, I'd be willing to sell you the TPMS sensors for $90 shipped (again, once I have the wheels/tires and pull them out).
      11-09-2012, 09:30 AM   #11
ANUSTART
ANUSTART's Avatar
35
Drives: Z4
I've heard about the liability issue. If you are supposed to have TPMS and don't and then get into an accident that is your fault and could have been prevented by proper tire inflation. You could get smacked. Up to the owner, but, probably very, very unlikely. But it's out there.
      11-09-2012, 10:26 AM   #12
zBone
Megatron
zBone's Avatar
That sounds great - and I should be able to hold out a few weeks. I walk to work, and I don't drive much. If you don't mind me asking... what's the winter setup you're buying?
      11-09-2012, 10:26 AM   #13
zBone
Megatron
zBone's Avatar
I didn't even think about that. Makes sense, but wow is that a PITA. Just another part to break.
      11-09-2012, 10:37 AM   #14
jophish17
jophish17's Avatar
58
Drives: Z4MC
Along the same lines... Do you have to step down to 17s to run winter tires? I may be moving up north soon, and was considering just slapping them on my OEMs - will the bigger tires have clearance issues?
      11-09-2012, 10:42 AM   #15
zBone
Megatron
zBone's Avatar
Well, the only issue with stepping down to 17's, from the research I've done, is that only some will fit over the stock rotors. Additionally, with winter tires, narrower = better traction; so an 8 or 7.5" setup is more ideal than the stock width. PLUS, with the tires being larger, having more sidewall is your friend in areas that get snow, since snow = potholes. PLUS, I wanted a square setup - being able to rotate the tires when necessary, resale, etc.
BTW - anyone have opinions on the blizzak studless ice/snow tires (WS70) versus the blizzak 'performance winter' tires (LM60)?
      11-09-2012, 11:38 AM   #16
RADRACR
RADRACR's Avatar
WS are for your hardcore ice/snow while sacrificing a little on dry. LM is better performance on dry while sacrificing a little on snow (it's like the "all-season" for winter tires). Personally, I prefer the extreme WS to save my ass if necessary because my car is my DD; I don't drive aggressively on dry when I have winter tires on.
      11-09-2012, 04:36 PM   #17
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
65
You can run 235/40/18 Winters on all 4 corners on the OE wheels.
      11-10-2012, 07:13 PM   #18
aerobod
Car Geek
aerobod's Avatar
3626
Drives: Caterham R500, M2-G87, Macan S
On the Z4M a good 17" winter setup (assuming the wheels fit over the rotors) would be 225/50-17 with about 40mm offset in the front and 20mm in the rear.
The 225/50-17 tyre size is closest in diameter to the OEM 225/45-18 front and 255/40-18 rear sizes.
For the past 5 winters I've been very happy with my 225/45-18 Sottozero setup on 18x8 OZ Ultraleggera wheels with 40/20mm F/R offsets.
      11-10-2012, 10:47 PM   #19
JB135MDCT
I'm just a cook
JB135MDCT's Avatar
Drives: 2011 135i DCT
booll shiet
      11-12-2012, 08:04 AM   #20
jdoublehcubed
Mechanical Engineer
About to pick up another set of OEM wheels with summer tires here on the forum, then use my current OEM wheels for the winter.
For tires, I'm pursing a couple of leads on some used LM-25s. I'm expecting to have the new set of wheels in 3-4 weeks; I'll pull the TPMS sensors immediately and have them ready to go for you.
zpost
