      11-04-2012, 11:54 AM   #1
shemeld_135
shemeld_135's Avatar
Drives: 2020 SO - M2C
2020 BMW M2C  [0.00]
2016 BMW M2  [10.00]
Flex Fuel help in PA
hey all - anyone in PA, King of Prussia area have experience with flex fuel or run with it? PM me!
      11-05-2012, 10:29 PM   #2
MuNkY6913
The Crowing
MuNkY6913's Avatar
Drives: BMW 135i
2009 135i  [8.00]
Are you talking about E85?
2009 135i : BMS JB4 G5 ISO,CXRacing FMIC Kit,Injen Cold Air Intake,Evolution Raceworks Charge Pipe,Walboro Inline Fuel Pump, E85 BMS Backend Flash w/ 60% E85,BMS Meth injection (trunkmount),BMS dual meth nozzles,Spec stage 2+ clutch w/ steel SWFW,BMS Catless Downpipes,Berk Tech Race Axleback
      11-06-2012, 09:00 AM   #3
shemeld_135
2020 BMW M2C  [0.00]
2016 BMW M2  [10.00]
yeah man!
      11-07-2012, 06:37 PM   #4
MuNkY6913
The Crowing
MuNkY6913's Avatar
Drives: BMW 135i
2009 135i  [8.00]
i cant really offer any technical advice about E85 but i ran it from the gas station in milroy and they only had 92 octane gas so it wasnt mixed with 93. it felt like a little more power. i did 3 gallons and the rest 92 octane. i used it on the way down to bimmerfest in maryland. i know it really brought down the mpg.
      11-08-2012, 08:37 AM   #5
shemeld_135
2020 BMW M2C  [0.00]
2016 BMW M2  [10.00]
thanks for the info.. did you have any after effects from it on cold starts or anything?
      11-08-2012, 09:17 AM   #6
Snertz
H O O N
Snertz's Avatar
Drives: ein M!
What kind of info are you looking for? I've been running an E85 mix for about 10k now.
      11-08-2012, 09:21 AM   #7
shemeld_135
2020 BMW M2C  [0.00]
2016 BMW M2  [10.00]
just trying to learn more about it. I just picked up a jvb4 n55 w/ flex fuel wires attached. so i just want to learn about it. I really only been looking in to it for a week now.
have you had any issues with the car? is it a lot of keep-up like meth? I understand that the jbv4 on map 5 will auto tune to it or turn it off when it doesnt detect it.. do i have to do anything else?
      11-09-2012, 10:22 AM   #8
Snertz
H O O N
Snertz's Avatar
Drives: ein M!
Since you're running a JB4 it's a little easier than the Cobb AP I'm using, depending on the mix you chose you might need to adjust the fuel pressure settings in the firmware; or eventually get the backend fueling flash that they offer. But off the bat you should be fine as-is just by running map 5.
It's a piece of cake, no real upkeep besides making sure you're running the right mix for the fueling scalar set in the tune. Easy way to do that is use the trip meter vs mile left in tank, assuming you reset the trip meter each time you fill up; add the two together, then divide the trip meter mileage by the total. Multiply that result by the gallon mix you're running, i.e. 50/50 mix on our cars would be 7gal, and that will give you the amount of E85 you need to put in; After adding E85 just fill up the remainder like normal with 93 or whatever highest octane you have access to.
There shouldn't be any additional wires to run E85, this is all handled within the firmware on the JB4. Most likely those wires are either for the SLD or NLS.
On an otherwise stock car you'll see gains up until about a 50/50 mix. Beyond that we won't see any benefits as we hit the upper limits of the stock turbos. Personally I'm running the equivalent of a 64/36 mix of gas/E85 (5gal of E85 to 9gal of 93), been having really good results so far, been able to throw a bit more timing and boost at it but haven't found the upper limit for the mix yet. Only reason I'm running this mix level is because I carry a 5gal jug of E85 with me at all times in case I need to fill at a station that doesn't have E85 (most don't carry it around where I live)
      11-09-2012, 10:56 AM   #9
shemeld_135
2020 BMW M2C  [0.00]
2016 BMW M2  [10.00]
hey thanks man for the info it was a big help to get me started!
      11-11-2012, 01:40 AM   #10
MuNkY6913
The Crowing
MuNkY6913's Avatar
Drives: BMW 135i
2009 135i  [8.00]
There's a pretty informative post on n54tech forums about using e85. I read that pretty carefully before putting it in my car. Go make an account there and search for e85.
