ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      11-03-2012, 03:43 AM   #1
Mtxzptlk
Driving Dog
Mtxzptlk's Avatar
871
Drives: 635/1815, X3M Comp
Replacing Dash Trim
Hi Guys,
I was able to pick up a dash trim set recently and am in the process of taking out my current trim before I can put in the new one.
I removed the vents and the headunit and am currently trying to get the dash piece out. I read from a Z4forum thread that there are clips that secure the dash trim to the dash in addition to the screws on the headunit / vent area. I haven't seen them but I can feel these when I reach in behind the dash itself.
Does anyone know how to take these off?
Thanks in advance
Below is a pic from the z4forums thread of these clips
      11-03-2012, 09:28 AM   #2
Chamberlin
Green Beemers
Chamberlin's Avatar
Drives: 27 BMWs...and counting
the one pictured is the type of clip that stays on. and you pull the trim straight out with force. HOWEVER, there is a special clip on the far right of the dash piece that you need to remove (kinda like a hand grenade pin) before you do anything else. Curved needle nose pliers and an inspection mirror will do the trick.
      11-03-2012, 09:30 AM   #3
psygnosis
psygnosis's Avatar
23
Drives: '04 Z4 3.0i Sport
yep only the two places you have to remove stuff before you just start pulling
The screws around the vent/radio and the pin next to the passenger cup holder
Straightaways are for fast cars, Corners are for fast drivers.
      11-03-2012, 06:01 PM   #4
Mtxzptlk
Driving Dog
Mtxzptlk's Avatar
871
Thanks guys!
How about the trim that surrounds the turn knob that controls the headlights?
Is that suppose to just pop off w/out needing any pins to be taken off?
      11-05-2012, 09:02 AM   #5
WestCDA
7
Drives: 2006 Z4R 3.0si
Yes, it just pulls off - there are two pins/legs, one at top left and one at bottom right.
zpost
