ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      11-02-2012, 07:25 AM   #1
krusty
krusty's Avatar
24
Drives: Z4 coupé
iPad mini in the Z4
Did a paper cutout (200mm x 135mm) to see where the iPad mini will fit (when it arrives).
Looks like the iPad mini will fit snugly into:
a) the cubby-hole between the 2 seats: top slot, above the multi-stack CD ... pretty cool location
b) the main cubby-hole
Also think that there might be a wonderful possibility to replace the satnav screen with an iPad mini, and make it pop-up on demand in the coolest way possible. Alas, I don't have satnav, so can't check the dimensions.
      11-02-2012, 09:38 AM   #2
rsutoratosu
114
Drives: Z4 3.0i
Im assuming you're talking about cutting a hole in where the navigation sits ? I thought about that, some after market radio installer have done it. I just never went through with it because I couldnt find a good gps at the time.. now it might be worth revisiting it.
like getting this piece cut out and fitting the mini in it ?
http://www.ebay.com/itm/BMW-Z4-Navig...e7fb6c&vxp=mtr
-Roranji
      11-02-2012, 09:40 AM   #3
rsutoratosu
114
Drives: Z4 3.0i
http://dl.dropbox.com/u/11703726/BMW...20Retrofit.pdf
heres the retrofit manual, you can definitely "borrow" the template and cut your own hole on the navigation area
So I know the z4 does not have a dummy dash storage area, the x3 has a similar one. it may or may not fit
http://www.ecstuning.com/BMW-E83-X3-...board/ES82115/
-Roranji
      11-02-2012, 10:55 AM   #4
rsutoratosu
114
Drives: Z4 3.0i
we dont have the room but someone retrofit one in the car
-Roranji
      11-29-2012, 09:16 AM   #5
krusty
krusty's Avatar
24
Drives: Z4 coupé
iPad mini has arrived
Here it is in the cubby hole ... beautiful fit:
      11-29-2012, 09:22 AM   #6
krusty
krusty's Avatar
24
Drives: Z4 coupé
And here is iPad mini in the centre console (between the seats) -- almost looks like the compartment was designed just big enough to hold it ... And the lip of the iPad mini just hangs out over the ledge, so you can grab it nicely with your thumb ... and the door closes perfectly without touching it
      11-30-2012, 12:14 AM   #7
pyo
Drives: 2022 X3MC
Are all cubby holes the same? I swear mine is a lot smaller than that. I cant even fit my manual in there.
'00 328i // Sold
'04 Z4 3.0i // Sold
'22 X3MC LCI
zpost
