      11-01-2012, 07:04 PM   #1
trickcruiser
Drives: F80
Need Advice: Black Spark Plug #6 - Car is running really bad...
Background of my car: 08 135 Auto 40,000 - FBO + Meth + 4gal of E85/93 - tank down to about a 1/4 tank.
Took the car out this morning and it ran fine without any issue. Went to take it back out 5 minutes later and that is when my day took a nose dive... Started fine and drove fine for about 3 minutes and then started missing really bad...
I run the codes and got multiple misfires. I smell gas...
First thought was to fill the tank with 93 to see if that would help - fail
Next, I figured the plugs were most likely due so I went OEM Bosch.
Cylinder 6 was black and reeked of gas! I went ahead and changed it with a new plug. Fired it up and it was good for a minute and then the miss came back... Decided to drive the car and see how it would do with any load. The drives fine once you give it some gas and still has the good old kick that it always has had. But come to a stop and the fun stops... Backfire's etc.
Pulled the new plug in cylinder 6 and it is now black and stinks of gas.
My guess is that my injector 6 is stuck open or something along those lines.
Any thoughts???
      11-02-2012, 01:48 AM   #2
Järppä
Old fart
Järppä's Avatar
Finland
Drives: F48 X1 xdrive25 + E53 X5 V8
Bad coil if you have missfire. If new coil don't help then i would look at injector.
F48 X1 xdrive25 2020
E53 X5 4.4i V8 2001
      11-02-2012, 02:52 AM   #3
Dackelone
European Editor
Dackelone's Avatar
Germany
10539
Drives: N54 e82
Move your #6 coil pack to cylinder #5. IF cylinder #5 starts to act up... then you know its just your coil. But yea... I suspect its your #6 injector. You can also move injectors too.
You might check with your dealer IF your car ever had the injector update/check/recall. Give them your VIN. New injectors are only ~$104 each from Tischer or United. New injectors will need to be coded though.
      11-02-2012, 11:53 AM   #4
gio
50
Drives:
Probably bad injectors just like me. My car smelled like gas when my injectors went too. See my other threads in this forum.
Waiting on a 2015 M235
      11-02-2012, 01:03 PM   #5
dozr
Drives: 09 135i CPO
I have heard of others having injectors stick wide open to the point where gas was coming out of the exhaust pipe. Seems like a pretty common problem.
      11-02-2012, 01:14 PM   #6
gio
50
Drives:
Yup, that's what just happened to me
      11-05-2012, 07:23 PM   #7
1911A145
1911A145's Avatar
34
Drives: 135i
Every single day I start worrying about my car that much more... :/
      11-05-2012, 08:31 PM   #8
froop
froop's Avatar
Australia
171
Drives: 08 AW 6MT E82
      11-06-2012, 09:00 AM   #9
trickcruiser
Drives: F80
Ahhhhh I did not click instant notify and did not know that there were any responses on this forum...
Anyways, here is the update with references that hopefully help others get this done a bit easier.
XBox Fan's replacement DIY:
http://www.***********.com/showthrea...ector-swap-DIY
Vassil's Coding DIY:
http://www.***********.com/showthrea...oding-Via-INPA
      11-06-2012, 09:01 AM   #10
trickcruiser
Drives: F80
Replaced the injector on Friday night and it was really easy. The one tip that I would give is to use a rope to pull the injector. I actually used some spare speaker wire and looped it under the injector. Gave it a nice steady pull and it popped right out.
The only issue that I have right now is that the cable that I borrowed from a friend has the blue board. From what I understand the blue board is the sux and the reason that I am getting this error.
Other people having this issue with the blue board cable.
http://www.e90post.com/forums/showth...645844&page=16
I ordered this cable on Friday night and will let everyone know if it works or not.
http://www.one-stop-electronics.com/shop/
Right now the car is running great without issue. I will not be pushing it at all until I get my new cable though.
