BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      10-30-2012, 02:22 AM   #1
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
Question Guys who Track, How's Your Aftermarket Suspension Holding Up?
Just wanted to start a thread and collect some feedback on the durability and performance of various aftermarket suspension kits.
Some questions to consider:
0. Which kit do you have?
1. When was the kit installed?
2. How often do you track?
3. Run group?
4. Any major issues? Rebuilds?
5. Other minor issues?
6. Would you recommend it to others?
      10-30-2012, 09:20 AM   #2
Porschefile
Porschefile's Avatar
59
Drives: E92 M3
0. Which kit do you have? KW Clubsport
1. When was the kit installed? 2-3 years old (10k miles PO, 5k miles me)
2. How often do you track? 1-2 per month (has seen 30-40 track days)
3. Run group? Instructor
4. Any major issues? Rebuilds? Not yet. I will rebuild when R/C adjustments no longer work the way I want them to.
5. Other minor issues? No.
6. Would you recommend it to others? Yes, I like them a lot. Awesome on track and not too rough for me on the street. The damping adjustments make a noticeable difference.
      10-30-2012, 12:05 PM   #3
bigjae1976
bigjae1976's Avatar
1571
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
E90
0. Which kit do you have? Dinan Stage II w/ GC camber plates
1. When was the kit installed? Mid April 2012
2. How often do you track? 5 days so far
3. Run group? advanced
4. Any major issues? Yes. GC bolt plates failed during initial installation, fixed.
5. Other minor issues? None
6. Would you recommend it to others? Depends. For looks and warranty purposes, yes. Performance upgrade...meh. The springs didn't do much. The front bar, plates and square tires killed the low speed understeer...probably did too good of a job if you ask me.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      10-31-2012, 12:38 AM   #4
NRBRNG
NRBRNG's Avatar
Drives: '09 E92, SG & '89 635 CSi
[QUOTE=RLDZHAO;12913326]Just wanted to start a thread and collect some feedback on the durability and performance of various aftermarket suspension kits.
0. Which kit do you have? KW Clubsports
1. When was the kit installed? April 11
2. How often do you track? They have seen about 30 days
3. Run group? Advanced
4. Any major issues? Rebuilds? No. Canary chirp on rough roads only.
5. Other minor issues? None really, except as speeds and times get better, the tires are starting to take the strain more and their life is pretty short these days...Yoko slicks. Might need to go MCS for next season...
6. Would you recommend it to others? definately for moderate towards heavy tracking.
DCT. Custom Cantrell MS cage. Fire, SCCA, dedicated track. Diffs-online 3.62, diff cooler, MCS 2-ways, SPL arms, TMS solid SF/Diff bushings, RD sway, DO88 Coolers (DCT, RAD, PS, OIL) Akra catless GT4, BPM tune, Hans Recaro, AP Pro 5000R, Cobalt XR2/4 race pads, BBS E88's, Yoko A005 slicks, RKP GT4 Splitter, GT4 canards, APR GT250 Wing, CFK Hood, Flossman CFK fenders, BW carbon doors, Dinan R toe links, Mini battery.
      10-31-2012, 08:24 AM   #5
paradocs98
paradocs98's Avatar
Drives: M2C
0. Which kit do you have? Dinan Stage III
1. When was the kit installed? April 2011
2. How often do you track? Approx 10 events/yr--so far around 20 events or around 25 total track days
3. Run group? High intermediate
4. Any major issues? Rebuilds? none so far
5. Other minor issues? none
6. Would you recommend it to others? For a good street/track compromise that maintains EDC function and matching warranty, yes. For faster, more advanced track drivers willing to give up EDC, I would probably look at something like Moton or JRZ coilovers instead
Good thread idea
Past: E46 330Ci, E60 545i, E60 M5, E90 M3
Present: 2020 M2 Competition, 2022 GT3
      10-31-2012, 10:38 AM   #6
VSmotorsports
VSmotorsports's Avatar
157
Drives: e92 M3
0. Which kit do you have? - Motion Control 3 Way Adjustable
1. When was the kit installed? - March 2012
2. How often do you track? - Often, this is our race car setup
3. Run group? - NASA GTS-4
4. Any major issues? Rebuilds? - None
5. Other minor issues? - None
6. Would you recommend it to others? - Yes, MCS makes a great setup (Props to Lex)
      10-31-2012, 11:52 AM   #7
klammer
97
Drives: 11 spc gry m3 e90, 19 X5
0. Which kit do you have? Dinan stg. 3
1. When was the kit installed? fall 2010
2. How often do you track? pretty often, looking at over 50 events on this setup.
4. Any major issues? Rebuilds? nope
5. Other minor issues? nope
6. Would you recommend it to others? Yes, but only as a compromise setup. In retrospect would have gone with a full coil-over.
mods: track ready stuff
      10-31-2012, 12:09 PM   #8
PrimeBMW
PrimeBMW's Avatar
662
Drives: E46 M3+S62, E92 M3
[QUOTE=NRBRNG;12918283]
You know you want the MCS......you know you need the MCS!
      10-31-2012, 07:49 PM   #9
CBS
CBS's Avatar
Drives: F10535, E90M3, E30M3, E28M5
2017 Alpina B6 GC  [0.00]
2014 535xi M Sport  [0.00]
2014 X3 3.5 M Sport  [0.00]
2011 M3 E90  [9.74]
2007 Z4 M Coupe  [7.00]
1990 M3  [9.50]
1988 M5  [10.00]
ESS VT-1 550 | M24 Oil Cooler | Fall Line Half Cage | RaceTech 4009W | 6 pt Harness | Lifeline Zero 360 Fire Suppression | Rear Seat Delete | Motion Control DA Dampers w/remote reservoirs | 900/650 Hyperco Springs | RD Sport Sway Bars | Brembo 380 BBK | GC Camber Plates | Hoosier R7 | Eisenmann Sport | Stack Gauges | Painted Challenge Front Lip | Painted ZCP Rear Spoiler | Xpel Ultimate Film | LuxAngelEyes
      11-01-2012, 06:25 AM   #10
dawgdog
148
Drives: 2015 M3, 2016 GT3
I had several setups in my M3. First lowering springs, then Ground Control using stock dampers, then AST 5220 and finally AST 4200.
The AST suspensions transformed the car but the 5220 were problematic including several leaking dampers. I finally switched to the AST 4200s and used them for about 25 track days with the only issues being replacing faulty lower bearings on the rear dampers.
As far as the car was concerned it was a new car with the suspension and was easy to dial in, both the 5220 and 4200. The 4200 are, with a few clicks of the rebound setting, very comfortable on the street. On the 4200s I used 550 lb springs in front and 790 in the rear.
2015 f80 M3, 2016 GT3
      11-01-2012, 11:15 AM   #11
FrenchBoy
FrenchBoy's Avatar
France
234
Drives: '16 F80 M3
Great thread. Thanks for starting it. I will be in the market for an updated suspension at some point in the future so this is great info.
Here are my answers
Ground Control Coilover kit, with GC camber plates. 600 in.lb rear springs, 440 in.lb front springs
March 2011
10/12 times a year. Kit has seen about 24 track days
3. Run group?
Advanced
No
Creaking noise after initial install. A quick call to Ground Control identify an incorrect install. There needs to be a small space between the endlink sleeve and the spring lower threaded perch. Corrected install. Not issue since.
Definitely. It is a nice system for a combination street/track use that maintains the stock EDC shocks. It does not perform as well as a real setup (like dawgdog's above which I can confirm changed the character of the car) but nice nonetheless.
Current: 2016 F80 M3 6-Speed | SO | AB XT1 | ZCP | M Performance Suspension | GC Camber Plates
Previous: 2009 E90 M3
      11-01-2012, 11:53 AM   #12
Jaypod
Jaypod's Avatar
125
Drives: Frozen M3, AM V8V, 991 GT3
Past: On previous '08 E90
0. Which kit do you have? Moton Street Sport (Version 2)
1. When was the kit installed? 3 years ago, on Car for 2 years
2. How often do you track? 15-20 days per year
3. Run group? Advanced\Instructor
5. Other minor issues? Endlink Tab broke, apparently I am only one to experience this. Part was replaced quickly and easy fix. Only other complaint would be that "clicks" are not as positive as i would have liked (really had to pay attention, especially when shock was cold)
6. Would you recommend it to others? Definitely, loved this kit and still miss it. Although there are more options available today so would also consider MCS and AST if I was to go to a full coilover kit again.
Current: '12 E92 with EDC(DDC)
I currently have the Dinan Coilover kit (really a Sleeve Over). Have run it for 1 track day and so far am impressed. Not issues so far and ride is very compliant on and off the track. Went with this kit to retain EDC as already have a deposit on another car and dont plan to keep this car long term. Will further update when appropriate.
      11-01-2012, 09:00 PM   #13
CJ421
CJ421's Avatar
1559
Drives: BMW M3
I'll chime in here. I have a complete M3 suspension conversion including M3 style rear dampers.
0. Which kit do you have? - JRZ RS1 fixed-height with AC Schnitzer M3 springs, Ground Control M3 camber plates, track alignment, BFG R1 tires.
1. When was the kit installed? - June 2012
2. How often do you track? 10-15 days/year (15 days on the JRZs)
3. Run group? BMW CCA Green/Advanced
4. Any major issues? Rebuilds? No issues. Solid performance through and through, I am thinking about upping the gas pressure on the damper at some point.
5. Other minor issues? - N/A
6. Would you recommend it to others? - For track junkies yes, these will transform the car. I thought they felt good driving home after I got them installed but when I got to the track I said "wow". Always a smile on my face. I know exactly what the tire's contact patch is doing on the track. Just fantastic damping.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT
      11-13-2012, 04:10 PM   #14
Raucky2000
Raucky2000's Avatar
22
Drives: SGM E90 M3 dct
Thanks for all the good info, now I just have to buy something...
m3post
