BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      10-26-2012, 02:00 AM   #1
Richard@M-World
Richard@M-World's Avatar
Drives: NASA TTA #92 M3
Arrow AiM Solo/Solo DL 'How Tos,' Tricks & FAQ
As we wrap up the track season, please share what kind of tricks you've learned on your AiM Solo in the past season
Note: the latest firmware version is 46.03.08. Please ensure that Solo/Solo DL is up-to-date. http://aim-sportline.com/eng/download/firmware.htm
HOW TOs
Enable Display of Multiple Fields (lap time, RPM, brake pressure, etc) on the Same Screen
Getting There
Menu>
Display Setup>
Page Setup>
Custom Page Setup>
Configure>
Options
Page - You can configure up to 4 custom screens
Data Field - Choose 1-4 fields of data on the same screen
Configure - Enter to configure your custom screen
Using Solo for Autocross, Hill Climb (non-circuit courses)
Getting There
Menu>
Race Mode Setup>
Options
Race Mode - Choose Speed
Track - Choose Point to Point
Display Lap Times for a Longer (or Shorter) Period of Time after Passing the Start/Finish Line
Getting There
Menu>
Race Mode Setup>
Options
Laptime Vis: Choose 3-30 seconds
Enable Display of Rolling Lap Times (like a stopwatch)
Getting There
Menu>
Display Setup>
Page Setup>
Enable/Disable Pages>
Options
Page - Choose Lap Time
Enabled - Yes
Lap Time - Change from Static to Rolling
Enable Predictive Lap Timing: Display Time Delta +/- from Previous Best Lap
Getting There
Menu>
Display Setup>
Page Setup>
Options
Page - Choose Predictive
Enabled - Yes
Lap Time - Change to +/- Best
FAQ
Q: What is the difference between AiM Solo and AiM Solo DL?
A: AiM Solo DL is an upgraded version of AiM Solo that can integrate with ECUs to download additional racing data.
Q: Can AiM Solo be upgraded to AiM Solo DL?
A: No. They are completely separate units.
Q: In terms of hardware, what is the difference between AiM Solo DL CAN and AiM Solo DL OBDII?
A: The main unit is the same, only the harness is different.
Q: Can AiM Solo DL connect to a camera such as GoPro?
A: No. AiM Solo DL only supports integration with SmartyCam HD.
Q: Which racing mode should be used?
A: For circuit tracks (i.e. oval and road course) and autocross (point-to-point), select Speed. For drag race, select Performance.
Q: If my track is not in the GPS Manager database, what should I do?
A: Check with the race track's safety personnel to make sure that you can safely access the start/finish line. Next, bring your Solo/Solo DL to the desired start/finish line. Then, allow the unit to discover GPS signal. Scroll through the main display screen to "OK: Start GPS Marker." Finally, press OK.
Authorized AiM Dealer - Solo/Solo DL | SmartyCam HD | www.m-world.us
      11-13-2012, 04:13 PM   #2
Raucky2000
Raucky2000's Avatar
22
Drives: SGM E90 M3 dct
That's a cool little toy and would be helpful at my local autox events.
      12-07-2012, 11:18 PM   #3
mkPOTO
Mr. Nice Says Hello
mkPOTO's Avatar
636
Drives: BMW M3 | X5 xdrive 35i MSport
Awesome, just picked up a aim solo dl and this is good to know
      12-07-2012, 11:27 PM   #4
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
ive learned not to pay a bit of attention to it while driving. only look at the data later or in a low risk area.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs|
m3post
