BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      10-19-2012, 03:49 PM   #1
Protocav
Drives: 2008 E90 M3
Nitto NT-01 Break-in?
About to start my first set of NT-01's, and was wondering if anyone has experience with them as far as break in? Will a 20 mile drive to the track be good enough, or do they really need to be scrubbed-in well?
Any info regarding these tires is helpful.
      10-19-2012, 04:58 PM   #2
CanAutM3
CanAutM3's Avatar
21117
Drives: 2021 911 turbo
The NT01 do not require any break-in or heat cycling.
If you go out for the first time on a brand new set, they will be little bit greasy for the first couple of laps. After that, the more you wear them down, the more they grip .
      10-19-2012, 07:56 PM   #3
Car54
36
Drives: 2014 M-Sport Wagon - EBII
Broke a new set in at Daytona last weekend. Took about 1-2 laps and they were stick. They rose 11psi which surprised me...they were real squirmy in the braking zone when too high of pressure.
      10-19-2012, 11:36 PM   #4
paradocs98
paradocs98's Avatar
Drives: M2C
The first few laps on a new set can be pretty wiggly and uncomfortable, but then they do well. I'm well into my second set and really like them. Good grip, and good wear/longevity.
When they're new and have tread blocks, they are okay in the wet if necessary. When they've been worn down and are faster in dry conditions, they are NOT to be used in rain.
I typically start the day with them around 31psi, and the pressures will climb to the high 30s/low 40s after each session. I try to keep them around 39psi hot.
Past: E46 330Ci, E60 545i, E60 M5, E90 M3
Present: 2020 M2 Competition, 2022 GT3
      10-20-2012, 04:43 PM   #5
arter
collecting toys
arter's Avatar
41
Drives: M3 MCB
the easiest way to set up Nt-01's is to drive them to the track or around town a little when fresh
Otherwise just take the first part of the first session easy
2011 e92 M3 Monte Carlo Blue ESS 535 - gone but not forgotten
2015 cayman GTS - new toy
2006 SLK 55 AMG sold
      10-20-2012, 05:31 PM   #6
Protocav
Drives: 2008 E90 M3
Thanks guys. All very helpful information.
      10-23-2012, 03:25 PM   #7
GTM_Challenge
GTM_Challenge's Avatar
Drives: E46 M3, E90 M3
You'll love the NT01s. First set of R Comps?
      10-23-2012, 06:21 PM   #8
admranger
Retired Curmudgeon
admranger's Avatar
Drives: ‘19 X3M40i, ‘18 m550i
This.
Fastest lap should be the lap before they cord.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS
      10-25-2012, 10:21 PM   #9
Sleeper519
Sleeper519's Avatar
Drives: 08 E92 M3 DCT
Originally Posted by admranger View Post
This.
Do they ever heat cycle out before they cord?
I love mine, have 9 track days on them so far, still have the tread depth dimples visible but definitely wearing down here.
2008 M3 Coupe / DCT // StopTech BBK 380/355 / Pagid RS29 / Motul / Apex Arc-8 / BFG R1S / Ground Control / MS filter / Performance spoiler / BPM tune // Road Atlanta 1:39.70 / VIR Full 2:10.87 / Barber 1:42.20
      10-25-2012, 10:25 PM   #10
sleepless
sleepless's Avatar
Drives: 11 E90 M3
They get grippier as they wear; no heat cycle issues.
      10-25-2012, 11:46 PM   #11
Protocav
Drives: 2008 E90 M3
Yes, I drove around with them tonight and could tell how sticky they are. I tried to upset the car on long sweeping freeway on ramps with a heavy right foot and it just stuck. I suspect that my wheel bearings are going to hate these tires.
Can't wait to get them to a DE.
      10-26-2012, 10:32 AM   #12
Car54
36
I understand them to be identical to the Toyo RA-1 widely recognized as the most budget friendly R-comp tire. The RA-1 are also good to the cords and since they maintain good grip to the cords...when you get to the cord it's pretty obvious. I've seen guys cord a left, then throw it on the right for another session...moving the corded tire around!
      10-26-2012, 04:09 PM   #13
CanAutM3
CanAutM3's Avatar
21117
They are far from identical.
I was told both use the same (or very similar) rubber compound, but the thread patterns and tire structures are very different. The NT01s are designed for heavier cars, with much bigger thread blocks and a stiffer carcass compared to the RA1s.
This is also true for the NT01s, I have run corded tires for several sessions and still had plenty of grip
      10-26-2012, 04:16 PM   #14
CanAutM3
CanAutM3's Avatar
21117
+1 Same experience for me on 5 sets so far
      10-26-2012, 09:57 PM   #15
arter
collecting toys
arter's Avatar
41
Drives: M3 MCB
Have 16 days on my current set.
Took them for 2 days at Mid Ohio and thought that would finish them, but they are unchanged in appearance. Have another new set waiting in my garage, but they grip so well when the tread is gone to switch them before their time.
Maybe another track event this fall after the Frankenstorm is gone
      10-27-2012, 09:34 AM   #16
Car54
36
I should have clarified...I meant compound not construction. The RA1's came with 8/32 and should be shaved for dry use on a heavy car. The NT01's are good from sticker.
      11-01-2012, 01:03 AM   #17
dapopa9
dapopa9's Avatar
68
Drives: F80 M3
NT01's are sticky until they cord as the others said. However not sure how others got 9 & 16 days out of them. Mine last about 4-5 days! haha guess the others are driving like grandma's with them : )
      11-01-2012, 01:32 AM   #18
kaiv
IG: limited.slip
Drives: E46 M3 in a 325i Touring body!
My thoughts exactly ahah
m3post
