10-18-2012, 08:28 AM | #1 |
59
Rep 862
Drilling into aluminum trim
A local Z4 owner has a mint condtiion, brand new aluminum trim set he is looking to sell. Although financially it would be tough since I just did the aero side skirts, need tires and Inspection 1, I figured I could just sell my existing trim to make up the difference.
Two questions: 1. It doesn't have the cut out for the sport button. Would it be possible so drill the hole myself? Is there some sort of template? 2. What would you consider a fair price considering I have to take the chance myself to drill the hole? Thanks! |
10-18-2012, 08:58 AM | #2 |
127
Rep 1,772
Drives: 2007 Z4M Coupe
I think 500 is fair price for good cond AL trim. I have seen a few folks do it. Trick is start with smaller holes and work your way up. You can always go bigger if too small but never smaller if its too big!
How much you selling your beat up set for? I would like to get a set and wrap it
Gruppe M CAI / Euro Headers / Rogue Engineering X-pipe / RE Diablo Exhaust |
10-18-2012, 09:25 AM | #3 |
59
Rep 862
I heard that there may be a template or some sort of markings on the back side of the non-hole consoles? Is that true? Or would I have to make my own template?
Not sure I'm going to sell it yet. It's not beat up, its carbon leather, in good condition so it probably wouldn't be a good candidate to wrap. |
10-18-2012, 09:28 AM | #4 | |
2432
Rep 11,667
If it's in good condition you should get a good price for it.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
10-18-2012, 09:55 AM | #6 |
2432
Rep 11,667
Love my C.Leather as well.
It does make for a dark all black interior though. I have a couple of ideas to resolve that issue. (winter works project)
10-18-2012, 09:57 AM | #7 |
#buildnotbought
10859
Rep 4,893
I bought my (mint) aluminium trim set (in 2010) for 175 euro's ($230,-) on german ebay (shipping not included), so $500 seems a bit steep maybe. Go for 300
Why change to aluminium if you have carbon leather? |
10-18-2012, 09:59 AM | #8 |
55
Rep 1,224
Making your own template is quick and easy if you have a master (another car or console) to work from. IIRC another forumite did the conversion and posted some good info on the process. Might be worth a search.
If you can't take the time to teach a kid something good, someone will take the time to teach them something bad.
10-18-2012, 10:54 AM | #9 | |
59
Rep 862
I like the cl, but it's just too much black in the cabin. And it is starting to wear out in some areas, afterall it is just pressed leather. For the aluminum, I may even explore doing a matte 3m ventureshield on it to preserve it from nicks and scratches. |
10-18-2012, 02:25 PM | #11 |
59
Rep 862
10-21-2012, 01:05 PM | #14 |
7
Rep 273
Yes, the bottom is embossed with the irregular shape needed for the button and it's keyways - it's not just a round hole. I used a very small drill and drilled a seried of pilot holes from the bottom around the circumference of the cutout. Then I drilled a larger hole in the center from the top, and used a dremel type tool with a small diameter cutter on it to 'connect the dots', and clean up the edges. Doing the finish work from the top won't tear out the aluminum top cover like it would from the bottom. Be careful to cut as little as possible and do frequent test fittings with the button - there isn't a lot of overlap on the button trim to cover mistakes.
