10-17-2012, 08:18 PM | #1 |
Rep 55
Power Top
I am pretty sure the motor went out , and I have a new one on the way . I have ship killers write up to remove and replace .
Anyways , I have the shop manual for the Z4. I was reading thru replacing some cooling hoses, and thought what the heck maybe there is something in here in on power tops . I found some troubeshooting guidelines. It talks about sometimes a loss of fluid , or low fluid can cause the issue. It talks about how to access the motor from the trunk by removing the driver panel in the trunk to check and replace fluid . So it got me thinking do you really have to remove the whole top to replace the motor , or is there a hidden backdoor ? I am thinking if there was a way someone would have discovered it by now . However , I thought I would ask the question. It just seems like a huge design flaw they would make it this hard to replace a power top Hyd motor. Thanks |
10-17-2012, 09:39 PM | #2 |
5330
Rep 1,912
I remember reading on here at some point someone mention just that and they said they did it without removing the whole top. However I don't remember them every posting the details. My top has been dead for over 6 months now. I've just been operating it by hand.
10-19-2012, 08:25 AM | #4 | |
851
Rep 4,057
Huz-Z
BMW Z4 3.0si Roadster. Montego Blue Metallic. Premium and Sport Package. |
10-19-2012, 09:09 PM | #5 |
5330
Rep 1,912
Down is cake, I can do it while sitting in the car. Up takes a bit more effort as I have to lift it up then go back in the car to push the botton to lock it. However for $900 I can put up with quite a bit.
10-20-2012, 09:30 PM | #6 |
Rep 55
Well got it done , and saved $1100. The local BmW shop had wanted 1400. I got the part for $325 .
It took about 4 Hrs total with 2 people . We could probably cut that in half next time. Shipkiller write worked like a dream . The toughest part was getting the top back in the 2 clips. There is a way to get to the motor from the rear but it is a bi$ch. It is much easier to take off the top . I will post up some pics of my old motor . It was destroyed, and was sitting in about 4 inches of water I discovered. The hole drain hole was full . |
10-21-2012, 11:17 AM | #7 |
5330
Rep 1,912
Can you at least see the motor from the rear? Would help in identifying if its indeed the pump that is bad. Could you fill the fluid from there if that were the issue?
10-21-2012, 05:16 PM | #8 |
851
Rep 4,057
Thanks! It's nice to know that this is not the end of the world. A potentially big pain in the wallet though, it definitely is!!
Huz-Z
10-22-2012, 02:14 PM | #9 | |
Rep 55
It will be laying in the drain area hole. You can pull the motor up that is in the case , and remove the top of the housing. You will then be staring right at the fluid screw plug. You could observe it ,and if need be unscrew the plug with a torx bit and fill . To make it mush easier if you take the panel behind the seats completely out . Then have another person reach back there and hold the motor housing for you while you do this. We actually did this to put some additional silicone around the housing once in place . Some had rubbed off when we dropped the top back in. Since this is all sealed, if you we're low in fluid the million dollar question would be why. However , if you had a small leak this could get you by . David |
