BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
Mporium BMW
      10-07-2012, 09:06 PM   #1
bigjae1976
bigjae1976's Avatar
1571
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
Pagids vrs Performance Friction
Looking at either the Pagid Yellows or the PF01s for my ST60 BBK that I will install shortly.
I've had a lot of experience with the PF01s and do like them. I do wonder if the Pagid yellows provide the same bite and heat capacity as the PF01s while minimizing the noise.
I've found that my rotors will be unservicable from heat cracking long before I reach min thickness. So I don't think accelerated wear from daily driving on a track pad will matter much.
Opinions?
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      10-07-2012, 09:55 PM   #2
Porschefile
Porschefile's Avatar
59
Drives: E92 M3
I believe that the yellows will have less bite than 01's (prob the same or similar amount to
08/06 PFC). I like PFC a lot and stick with them because they've always done well for me.
Yellows are an endurance compound like 06/08. I think Pagid makes Orange/Black pads that are more similar to 01.
      10-08-2012, 12:23 AM   #3
RickyBobby
RickyBobby's Avatar
108
Drives: M3
The st60's have ridiculous stopping power so don't be so quick to jump to a pfc01. I run the pfc06's in mine and they still have too much bite in my opinion.
I've never done any back to back comparisons of the pads you mentioned so can't comment on the torque or heat capacity but can venture a guess that they will all squeal like pigs on the street.
      10-08-2012, 09:41 AM   #4
bigjae1976
bigjae1976's Avatar
1571
2004 BMW M3  [4.50]
Hmm...good point. Luckily I just invested in a HANS!
I guess I've heard and seen mixed reviews with the Pagid yellows as far as noise. I've seen and heard some with the garbage truck sound...others seem pretty quiet.
      10-08-2012, 10:00 AM   #5
adc
Drives: 2018 F80 M3 ED
Mine can squeal pretty loud after they get some heat into them in daily driving. I left mine on from end of August to beginning of October between 2 track events and it was borderline ok. Some days better, some days worse. Not sure how much it matters, but I am on stock brakes so the pads have the OEM-style clips and I am pretty generous with the anti-squeak compound paste.
Rotor wear is minimal so that's not an issue, but personally could not use the yellows for long term daily driving.
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
      10-08-2012, 10:05 AM   #6
adc
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
      10-08-2012, 10:09 AM   #7
adc
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
      10-08-2012, 01:42 PM   #8
besiktas
Ultimate Driver for the Ultimate Driving Machine
Drives: BMW M3 E92
I use the PF-08s all around. put them on in Aug for VIR, they have been on the car since then. they squeak like crazy, very embarrassing on the street. they squeak at the track as well but once you hit them hard couple times the squeak goes away. I used them last weekend on Summit Point, and will keep them on until i finish the November 12-13 VIR event. The stopping power is amazing but if you want to keep them on the street, you could use a set of earplugs
BMW M3 E92 - Silverstone II
BPM Sport Stage II Tune + Test Pipes, GTS DCT Tune
      10-08-2012, 04:42 PM   #9
MaxL
69
Drives: E90 M3, Cayenne T, 991 GT3
Pagid yellows in BBK here - silent for the first 4 months and 5,000 miles and over a dozen of track days. Now they make slight noise. I can only hear them with windows down though. I think re-applying the anti-squeal compound would silence them again, but I'm too lazy to try.
      10-08-2012, 07:15 PM   #10
ThunderMoose
746
Drives: PY E46 M3 and SG E46 M3
I run pagid yellows. I think they're pretty quiet and brake very well.
      10-08-2012, 07:17 PM   #11
turbo8765
61
Drives: very fast
I've run the PFC01 and the RS19 and couldn't discern a difference in noise.
Very similar pads all around.
      10-08-2012, 10:55 PM   #12
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
I think the 01 is more like a sprint pad with med-high braking torque (more of a RS 14 black), where as Pagid RS 19/29 yellows are endurance pads with medium braking torque.
      10-12-2012, 07:43 AM   #13
bigjae1976
bigjae1976's Avatar
1571
2004 BMW M3  [4.50]
OK...I think I'll stick with the 01s or 06s. They've served me well so far, why change? I just need to stop being lazy and swap pads.
      10-12-2012, 03:21 PM   #14
ortho281
ortho281's Avatar
Drives: 2011 E92 M3 6MT
I hate swapping pads (OEM calipers) but hate squealing even more. I had the 06's on track/street for almost a month and the squealing was louder than I could bear. I then switched to Hawk HPS but they only lasted 3 track days before the fronts gave up. I'm now running PFC Z-rated pads and found that they held up quite well on the track and are also quiet on the street. If you don't mind swapping pads, then that's the best of both worlds.
Akra GT4 / MS Stage 2 / MS UDP / BPM Tune / KW CS / H&R Sways / TMS Delrin / ST 380/355 BBK / Cantrell 2.5" Ducts / SR34 Pads / Apex Arc-8 / Hoosier R7's / Mode GT4 Splitter / GT4 Canards / APR GT-250 Wing / Cantrell Half Cage / Recaro Pro Racer / Schroth Profi II-6 / BMW Alcantera Wheel / Cool Shirt / ESS Fire Supp / Solo DL
      10-12-2012, 03:44 PM   #15
bigjae1976
bigjae1976's Avatar
1571
2004 BMW M3  [4.50]
I've tried the stoptech pads (similar to the Z-rated) and they just don't cut it. So I'm will continue to swap pads...in fact I have to swap my pads tonight and I'm feeling pretty lazy right now. I'm thinking, "my street pads should be OK...maybe?".
      10-12-2012, 06:51 PM   #16
paradocs98
paradocs98's Avatar
Drives: M2C
12+ trackdays is good longevity from Pagids. I've been running RS29s (yellow endurance) all around in my StopTech ST60/ST40 setup, both on the track and the street. I put them in last April at the start of track season, and the rears still have life left, but I had to change the fronts after about 8 trackdays.
Overall they've been great and have certainly held up better than the StopTech Street Performance pads that shipped with the kit. I'll put a set of the Street Perf pads back in for wintertime.
Noise when cold is there, but not absolutely horrible. It's most pronounced when backing up and then braking, such as in a parking lot. You know--when you're going the slowest and people can really glare at you...
Past: E46 330Ci, E60 545i, E60 M5, E90 M3
Present: 2020 M2 Competition, 2022 GT3
m3post
