10-07-2012, 08:47 AM | #1 |
3854
Rep 3,004
dead battery and then....
Dead battery when leaving for work; jumpered using my bride's 3 series; bmw dealer checked charging system - fine; battery was replaced 1.25 yrs ago and was checked - fine; car has been fine since this one instance.
i suspect that opening the top before starting the car, driving only 5 miles to the park n ride to take the bus, and then opening the top before starting the car upon returning to the park n ride in the eve and driving only 5 miles home did not allow enough time to charge the system. it's been nearly a month since this one-time instance and all is well.
Racerbruce
10-07-2012, 11:07 AM | #2 |
1136
Rep 2,867
Drives: Anything
Get a battery tender and use it once per week. Sounds like you ultra short commute isn't enough to recharge the battery.
Why not just start the car and then open the top? You would want to idle the car for ~15 seconds or so anyway for all the fluids to cycle through before driving off. Mind as well spent that time wisely |
10-07-2012, 06:30 PM | #4 |
60
Rep 932
I don't think open/close top drain too much battery. It takes lots of amp to crank the car over. 5 miles won't recharge your battery after starting the car. Your oil probably not up to temp with such a short trip. I always let my oil come to normal temp before turning engine off even if I have to drive around for awhile.
10-07-2012, 07:13 PM | #5 |
M = Midlife Crisis
65
Rep 2,006
2006 Z4MC - #LL93158
SS Race Cans, RE X Pipe, DKF Sec 1, Fabspeed Headers, OE STB, AS Shifter, Dave Z CDV, GC Coil Overs, Stoptech lines, Hawk DTC Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, Poly FCAB & RTAB, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM |
10-07-2012, 09:46 PM | #7 |
140
Rep 1,991
It MAY be AGM, but he said he had replaced it 1.25 yrs ago. Not stated if he went AGM, or not. I replaced my AGM with a standard battery due to cost savings. I don't think AGM vs LA will make any difference in the OP's case as they both have the similar specs and will discharge if not run enough.
10-08-2012, 01:34 AM | #8 | |
Save the Manuals
1714
Rep 2,937
I agree that driving around more than 5 miles is needed, but to also circulate and heat up those fluids. A battery tender is always a good idea for max life to any battery that doesn't see highway driving.
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT |
