ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      10-03-2012, 05:34 PM   #1
WAMz4
WAMz4's Avatar
Drives: 2006 Z4 3.0si Roady
Roof slams down hard. Any adjustments I can make?
My roof started slamming down when it gets within 5 or so inches of the windshield. It used to close smooth all the way into the latches, now it gets within a few inches, then SLAM's home. I'm afraid its going to get worse and crack the windshield or bend something. I don't know if its the motor or some strut in the folding roof itself. Has anyone seen this before? Would it be covered by warranty?
The Internet said it. I believe it. That settles it!
      10-03-2012, 05:53 PM   #2
Huz-Z
Huz-Z's Avatar
851
Drives: Z4 3.0si, 328 XDrive, X5 35i
Unless you removed your power top assembly to replace the motor recently, and perhaps inadvertently misaligned it upon reinstallation,i would say it's just an adjustment made necessary after a period of normal use. just my guess!!
I dunno if I would trust that to an Indy shop. I would want someone who really knows what he is doing to make that kind of adjustment.
Huz-Z
BMW Z4 3.0si Roadster. Montego Blue Metallic. Premium and Sport Package.
      10-03-2012, 06:41 PM   #3
Shipkiller
Shipkiller's Avatar
Drives: Me
It's not the motor. The motor is just an electro-hydraulic unit that just pumps hydraulic fluid.
The simplest is that the top is binding somewhere close to the end of it's travel and releases quickly. Try lubricating all the joints.
As for a mechanical failure....
It could be the Gas Pressurized springs, no. 13
http://www.realoem.com/bmw/showparts...12&hg=54&fg=10
or one of the tensioning ropes, no. 5 or 7
http://www.realoem.com/bmw/showparts...11&hg=54&fg=10
      10-03-2012, 08:09 PM   #4
que4523
Recalc that...
Drives: Z4MR
There is a BMW bulletin on this...go to the stealership and get the ten dollar part...it's a strap that installs in the forward facing plastic compartment in the the softtop.
      10-03-2012, 11:34 PM   #5
StickMon
My other car is on Mars
StickMon's Avatar
Drives: 2006 MR
Mine's done that since I bought it used nearly 2 years ago.
I thought it was supposed to do that, but I reach up and ease it down by hand.
I don't like things to slam.
Looks like they made a change in the TENSION ROPE 07/2007.
If anyone figures out the details, and applicable years, please post.
      10-03-2012, 11:56 PM   #6
beta
80
Drives: 2006 M Roadster
Any more details?
      10-04-2012, 12:38 AM   #7
WAMz4
WAMz4's Avatar
Thanks forum. Good info. Ill be checking out that tension rope issue at the stealer next oil change.
      10-09-2012, 01:35 PM   #8
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
Can anyone shed any more light on this issue? I have the same five inch drop, never realized it was something I could fix.
      10-09-2012, 01:51 PM   #9
RhoXS
16
Drives: 2002 Z3 3.0i + 2016 X3 28i
There are elastic straips called bow straps that loose their elasticity over time (at least on Z3s and most probably on all convertable tops). There is no adjustment but they need to be replaced. This is just a predicatble wear item when one has a ragtop. Your Z4 is over eight years old so the bow straps probably have little or no elasticity left in them. These straps, I learned, play a big role in both preventing the top from closing too quickly and in helping the top open.
I discovered it is good practice to replace these straps whenever the top canvas is replaced. Not all trim shops will tell you this and reinstall the old worn straps. I learned about this three years ago when I took my Z3 with a top that operated perfectly to a local trim shop to have the worn canvas replaced. I got the car back with good canvass but a top that no longer worked properly. It slammed shut and needed a manual push to break the "knuckle" when opening. The much stiffer new canvas just overwhelmed the no longer elastic bow straps. It would have been relatively cheap to replace them when the top was replaced but I did not know about them at the time.
      10-09-2012, 03:16 PM   #10
beta
80
Is it part 17 tension rope? Or 15 tension belt?
http://realoem.com/bmw/showparts.do?...10&hg=54&fg=10
Has anyone replaced it? Mine slams a bit, also thought it was normal.
      10-10-2012, 11:34 PM   #11
StickMon
StickMon's Avatar
Drives: 2006 MR
I started looking into this, too, and came up with 2 related questions on 17:
How can one tell if you have Folding top or EH Folding top?
Part 17 shows a change as of 07/2007:
Up to 07/2007:
Left: 54347123027 Right: 54347123028
After 07/2007:
Left: 54347079587 Right: 54347079588
(I had to use BMW of South Atlanta to get this straight. Their diagrams are more accurate and up to date then RealOEM, but harder to navigate.)
I wonder if the post 2007 part will fit on a 2006?
Maybe it's been improved, and is backward compatible?
ECS says the old parts are superseded by the new, so I think the answer is Yes.
      10-11-2012, 12:05 AM   #12
TCZ4
11
Drives: 2015 428i Convertible
Subscribing. Is this hard to replace on your own?
      10-11-2012, 12:17 AM   #13
StickMon
StickMon's Avatar
Drives: 2006 MR
Fiddna find out. After about an hour of research on RealOEM and BMW of South Atlanta, I'm about to pull the trigger on this set:
Left Tension Belt 54317043909
Right Tension Belt 54317043910
Tension Belt Mounting Parts 54347119643
Left Tension Rope 54347079587
Right Tension Rope 54347079588
Tension Rope Mounting Parts 54347119628
Fastening Kit 61 (aka 66) 54347110761
Fastening Kit 62 (aka 22) 54347110762
Front Fastening Set 54317127044
If anybody has been in there before, maybe you can suggest other things to replace while at it, or other spare hardware to get.
      10-11-2012, 08:00 AM   #14
Walkurie
Walkurie's Avatar
Drives: 06 M Roadster / 99 Jaguar XK8
Yes, very interested to hear answers to this post.
Vibra Technics engine mounts / Rogue trans mounts / Stoptech brakes / original owner
      10-11-2012, 11:10 AM   #15
ncnmra
ncnmra's Avatar
39
Subscribed as well. Please keep us in the loop on progress. Mine isn't "bad" yet, but I suspect it is going to get worse.
      10-11-2012, 12:22 PM   #16
strokeoluck
23
Drives: 2007 BMW Z4 M roadster
Ditto. I have the same "problem." Though I never knew it was a problem before.
      10-11-2012, 11:55 PM   #17
StickMon
StickMon's Avatar
Drives: 2006 MR
I'm glad for once that I'm not the only one that thought it was supposed to do that.
Like "I thought the vanos was supposed to make that noise." No, 3 of your bolts are sheared off.
      10-12-2012, 12:18 AM   #18
WestCDA
7
Drives: 2006 Z4R 3.0si
The 'EH' I would imagine stands for the Electrical-Hydraulic (power) top. Notice that item 16 on the EH top is for an emergency release tool.
      10-12-2012, 12:24 AM   #19
StickMon
StickMon's Avatar
Drives: 2006 MR
Ohhhhh. I knew the EH was Electro-Hydraulic, but I didn't realize the non-EH was completely manual.
      10-13-2012, 05:33 AM   #20
Newff
Newff's Avatar
20
Drives: 2008 BMW Z4 3.0si
Location: Fort Mcmurray, Alberta/ Hare Bay, Newfoundland
Same problem here. I thought it was nromal although it seemed weird.
      10-13-2012, 12:03 PM   #21
G80indy
Save the Manuals
G80indy's Avatar
Drives: Z3, E46, G80
I think the hard drop is also from fabric shrinkage, with age of the canvas, UV exposure, etc.
I had this effect on an e36 vert.
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT
2000 Z3 Conforti, 5MT
      03-23-2013, 01:45 PM   #22
beta
80
Bump. We really need a resolution for this thread, which is the important "ten dollar part" that needs to get replaced, did anyone do it already, etc. etc.
zpost
