10-03-2012, 03:15 PM | #1 |
1427
Rep 2,650
► APEX | Stud Conversion Kits and Extended Lug Bolts/Free shipping to the U.S. 48!
APEX Wheel Hardware
Apex Stud Conversion kits Try and find a BMW race car that hasn't converted to studs yet. They're stronger, safer, and improve pit stop times significantly. For non race cars, stud conversions make wheel install and removal much easier as you do not have to line up the holes in your wheels, spacers, and hubs before hand threading in a single lug bolt. Simply slide the wheel onto the studs, and let go. Your wheel will no longer spin around the hub, but will instead be lined up correctly. APEX 75mm and 90mm Stud Kits with silver or black lug nuts Extended length studs like these allow for a range of spacers to be used without any additional modification. You can easily use 3, 5, 10, 12mm with a 75mm kit or larger 15, 18, 20mm with the 90mm kit, or no spacer at all. When using lug bolts with spacers you are forced to purchase a different length lug for each width spacer. By remaining installed, the studs put less ware on the threads of your hubs. They guarantee there is enough thread engagement, as you can see how many threads were engaged during install. Wheel studs replace your OEM lug bolts by simply threading into your cars hub. Once installed they do not need to be removed when changing or removing wheels. Only the lug bolts are removed similar to many domestic vehicles. APEX 75mm and 90mm Stud Kits with silver or black lug nuts
Available Sizes and Pricing:
Available Lug Nut Finishes
Installation Kit Now Available! (Includes Red Threadlocker and 5.5mm Wrench) Apex Extended Lug Bolts Available in standard OEM length, and extended length version for use with 5, 12, 15, and 20mm spacers. APEX lug bolts can be purchased with either a silver or black zinc coating. BMW extended lug bolts sold individually Extended lugs are a must when using spacers, as the standard length lugs are not long enough to thread into the hub properly. If you want new lugs to go with your new wheels and spacers are not needed, then simply select "standard" length from the drop down menu above. If you are using spacers, then select the corresponding length extended lug bolts. Lug Bolt Specifications:
Available Lug Bolt Finishes Silver Black - +$0.50 Ordering and Contact
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
10-04-2012, 01:51 PM | #2 |
377
Rep 5,730
Drives: BMW i3 rex
Garage List 2018 I01 i3s | CURRENT [0.00]
2018 G01 X3 | CURRENT [0.00] 2017 I01 i3 | SOLD [0.00] 2017 F48 X1 | SOLD ... [0.00] 2016 I01 i3 | SOLD [0.00] 2017 F22 M240 | SOLD [8.00] 2016 F25 X3 diesel ... [0.00] 2006 E60 550 | SOLD [6.00] 2011 E90 335 | SOLD [8.66] 2012 E82 135 | SOLD [5.50] 2011 E82 1M | SOLD [7.94] 2007 E85 Z4M| SOLD [4.50] 2003 E53 X5 4.6is S ... [9.00] 2008 E92 328 | SOLD [0.00] 2008 E82 135 | SOLD [0.00] 2008 E90 335 | SOLD [0.00] 2003 E46 M3 | SOLD [7.50] 2006 E90 330 | SOLD [10.00] 2003 E46 330ZHP | SOLD [0.00] |
thanx Joe. ordered!
10-05-2012, 02:25 PM | #3 |
1427
Rep 2,650
Thank you and good luck with the car at that next event
10-05-2012, 02:39 PM | #4 |
377
Rep 5,730
Drives: BMW i3 rex
10-24-2012, 06:00 PM | #5 |
1427
Rep 2,650
Apex Stud Kits are in stock and ready to ship!
Please call, email, or pm us with any questions you may have.
11-06-2012, 04:05 PM | #6 |
377
Rep 5,730
Drives: BMW i3 rex
i love my set
11-12-2012, 06:04 PM | #7 |
1427
Rep 2,650
Thanks for posting EINSER M! It was great to see your car at SEMA repping our studs!
07-10-2013, 12:13 AM | #8 |
377
Rep 5,730
Drives: BMW i3 rex
07-10-2013, 02:15 AM | #9 |
171
Rep 2,682
Did you get the 75mm Einser? Also, are you running spacers?
I've been thinking about getting these but I'm not too sure I want them sticking out. I wouldn't mind getting the shorter ones but I might possibly need to run some spacers on my fronts in the future and don't want to get stuck with a set which won't fit. Also (to Apex), would it be possible to run non-hubcentric wheels without the hub centric ring with these studs? |
07-10-2013, 09:18 AM | #10 | |
377
Rep 5,730
Drives: BMW i3 rex
07-10-2013, 03:23 PM | #11 | |
3523
Rep 6,703
07-10-2013, 05:12 PM | #12 | ||
171
Rep 2,682
I have a set of Forgestar F14s which have a 74.1 centre bore. Picked them up because someone was selling them locally and for cheap otherwise I'm sure I'd have some Arc-8s right now. I'm using the supplied 72.6 to 74.1 aluminium hubcentric rings but they're pretty much 'welded' to the rings and I can't take them off... Also trying to take the wheels off is a huuuuge bitch to do because the fitment is so tight. That's why I'm considering just getting the rings cut off and trying to run without the rings. I'm hoping that with some careful tightening of the nuts I might be able to properly centre the wheel. If not then maybe I'll get some plastic hub centric rings which wont get stuck on the hub so easily. I just hope they won't melt at the track... |
07-17-2013, 06:31 PM | #13 |
3523
Rep 6,703
Need replacement lug bolts? Look no further, we've got them available in Black and Silver, in multiple sizes!
08-02-2013, 06:31 PM | #14 |
1427
Rep 2,650
Stud kits make changing wheels much quicker and can give your 1M that race-inspired look that it deserves. We have 75mm and 90mm kits available with lug nuts and an optional install kit! Feel free to contact us and we'd love to help you out.
08-07-2013, 07:03 PM | #15 |
1427
Rep 2,650
Make sure you purchase the correct length lug bolts for your spacers! These are available individually or at a discounted price when purchased along with a spacer kit!
Please let us know if you have any questions about our wheels or accessories and we'd be glad to help you out!
08-09-2013, 05:22 PM | #16 |
1427
Rep 2,650
Switch up the look of your wheel setup by changing the color of your lug nuts (for those with a stud conversion kit) or lug bolts. We sell these items individually for your convenience!
Please let us know if you have any questions and we'd be glad to help you out!
08-14-2013, 06:13 PM | #17 |
3523
Rep 6,703
Tired of wasting time aligning the wheel to the hub? We have 75mm and 90mm stud conversion kits to eliminate that problem!
Feel free to contact us by phone, email, or PM and we'd love to help you out!
08-15-2013, 06:36 PM | #18 |
1427
Rep 2,650
Our BMW lug bolts come in standard lengths for cars without spacers as well as extended lengths for cars running up to a 20mm spacer. They're available in all sizes in black or silver:
Give us a call to order your set of lug bolts today!
08-20-2013, 03:55 PM | #20 |
1427
Rep 2,650
Our stud kits are available with a stud install kit. The install kit includes an allen wrench and red loctite to make installation that much quicker and easier for you.
08-22-2013, 07:48 PM | #21 |
1427
Rep 2,650
Life becomes much easier once a stud kit is installed on your car. No more worrying about lining up your lug bolts with the hub holes while switching from street to track wheels!
Here is how our 90mm studs look without any spacers on: Please call, email, or pm us with any questions you may have.
08-26-2013, 05:18 PM | #22 |
1427
Rep 2,650
