BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 Marketplace > SPONSORS Classifieds/Groupbuys/Specials Area > Track / Autocross Related Parts
EXXEL Distributions
      10-03-2012, 03:08 PM   #1
ApexWheels
BimmerPost Supporting Vendor
ApexWheels's Avatar
1427
Drives: M3
► APEX | Stud Conversion Kits and Extended Lug Bolts/Free shipping to the U.S. 48!
APEX Wheel Hardware
Apex Stud Conversion kits
Try and find a BMW race car that hasn't converted to studs yet. They're stronger, safer, and improve pit stop times significantly. For non race cars, stud conversions make wheel install and removal much easier as you do not have to line up the holes in your wheels, spacers, and hubs before hand threading in a single lug bolt. Simply slide the wheel onto the studs, and let go. Your wheel will no longer spin around the hub, but will instead be lined up correctly.
APEX 75mm and 90mm Stud Kits with silver or black lug nuts
Extended length studs like these allow for a range of spacers to be used without any additional modification. You can easily use 3, 5, 10, 12mm with a 75mm kit or larger 15, 18, 20mm with the 90mm kit, or no spacer at all. When using lug bolts with spacers you are forced to purchase a different length lug for each width spacer. By remaining installed, the studs put less ware on the threads of your hubs. They guarantee there is enough thread engagement, as you can see how many threads were engaged during install. Wheel studs replace your OEM lug bolts by simply threading into your cars hub. Once installed they do not need to be removed when changing or removing wheels. Only the lug bolts are removed similar to many domestic vehicles.
  • APEX Wheel studs are 10.9 grade steel, and produced in Europe by a TUV approved OEM supplier
  • 75mm length allows for the use of spacers up to 12mm in thickness, or no spacer at all, without making any changes
  • 90mm length is recommended for spacers 15mm and larger
  • The studs have a bulletnose tip that makes lug nut install and removal easy, and prevents cross threading
  • The 75mm head has an integrated 5.5mm hex to make initial installation a breeze
  • The hardened studs are black zinc plated, while the nuts are available in both black and silver zinc plating
  • Studs and nuts are 12x1.5 thread with a 60 degree taper identical to OEM BMW hardware
  • These work on all 1, 3, Z series models, and every other BMW with a M12x1.5 lug. X5/X6, and newer 7 series use different sized hardware and cannot used this conversion
Available Sizes and Pricing:
Available Lug Nut Finishes
  • Black - +$10.00
  • Silver
Installation Kit Now Available! (Includes Red Threadlocker and 5.5mm Wrench)
Apex Extended Lug Bolts
Available in standard OEM length, and extended length version for use with 5, 12, 15, and 20mm spacers. APEX lug bolts can be purchased with either a silver or black zinc coating.
BMW extended lug bolts sold individually
Extended lugs are a must when using spacers, as the standard length lugs are not long enough to thread into the hub properly. If you want new lugs to go with your new wheels and spacers are not needed, then simply select "standard" length from the drop down menu above. If you are using spacers, then select the corresponding length extended lug bolts.
Lug Bolt Specifications:
  • M12x1.5
  • 17mm Hex head
  • 60 degree taper
  • 10.9 Grade
  • Black or Silver zinc finish
  • Made in Europe
Available Lug Bolt Finishes
Silver
Black - +$0.50
Ordering and Contact
  • Phone: Call (888) 499-9135 EXT. #1 for phone orders.
  • Payment: Credit and Debit Cards: Visa, Mastercard, AMEX, Discover, PayPal. Bank Wire Transfers are also available. Contact us to use a wire transfer for payment on your order.
  • Tax: California customers will be charged 8.75% CA sales tax.
  • Shipping: Free shipping only to domestic orders within the lower 48 states. Stud Kits will get free shipping. A full order of Extended Lug bolts with a quantity of 20x will also get free shipping.
  • APEX Hours:
    Monday thru Friday: 9AM to 6PM PST
    Saturday and Sunday: Closed
  • Warehouse and local pickup: The APEX warehouse is at 7888 Marathon Drive, Unit A, Livermore, CA, 94550 (Map It), (888) 499-9135 EXT. #2. This is where you pick up local orders.
  • Service and Installation: Apex Performance Services - Dublin: 6443 Golden Gate Drive, Dublin, CA 94568 (Map It), (888) 499-9135 EXT. #3
      10-05-2012, 02:22 PM   #2
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
Apex stud kits are in stock in 75mm and 90mm lengths. The stud kits make life much easier when installing wheels and tires!
      10-15-2012, 08:50 PM   #3
surlynkid
surlynkid's Avatar
115
Drives: 2013 E92 M3
Originally Posted by Joe@ApexRaceParts View Post
Life becomes much easier once a stud kit is installed on your car. No more worrying about lining up your lug bolts with the hub holes while fumbling holding a heavy wheel and tire!
Please call, email, or pm us with any questions you may have.
those stick out far too much for my tastes. how long are those, and is there a spacer. i want a set but want a reference picture for 75mm with no spacer.
      10-16-2012, 01:28 PM   #4
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
That would be a 90mm stud kit without spacers which is why there is so much stud protruding out. A 75mm stud kit without spacers will have much less stud sticking out of the wheel. The car below is using a 75mm stud kit without spacers.
      11-06-2012, 03:59 PM   #5
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
Apex stud kits are in stock with either Black or Silver lug nuts in 75mm and 90mm lengths!
Please call, pm, or email with any questions you may have.
      11-07-2012, 09:08 AM   #6
mapleridge
151
Drives: E90 N52 AT
ordered my 75mm kit on Monday. can't wait to get them on.
      01-14-2013, 01:40 PM   #7
E92M356789
El Jefe
E92M356789's Avatar
Venezuela
39
Drives: e30 325i
I have a question, I am looking to get these in 75mm, but with my current set up, I have spacers. Will I have any issues or should I get the 90mm instead?
      01-14-2013, 03:05 PM   #8
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
The APEX 75mm stud kit will accept up to a 12mm wheel spacer and the 90mm stud kit will accept up to a 20mm wheel spacer. We can also provide you with a split kit that would have 10x 75mm studs and 10x 90mm studs.
      01-15-2013, 05:31 AM   #9
E92M356789
El Jefe
E92M356789's Avatar
Venezuela
39
Drives: e30 325i
Cool I decided to go with the 75mm. I made the order last night. Thanks for your help.
      01-15-2013, 06:54 AM   #10
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
agreed. a very simple mod that is highly effective, adds strength and peace of mind. that being said is there any rule of thumb for replacement intervals for studs? number of track days, or time?
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs|
      04-07-2013, 05:34 PM   #11
FazerBoy
United Kingdom
49
Drives: BMW E92 M3
What is the length of the standard BMW OEM bolts on a 2012 E92 M3?
      04-08-2013, 01:48 PM   #12
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
Standard or OEM length lug bolts should have 28mm of thread length.
      07-09-2013, 06:10 PM   #13
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
Apex stud kits are in stock in 75 and 90mm lengths with either black or silver lug nuts! The kit pictured below is the 75mm kit with silver lug nuts.
Please call, pm, or email us with any questions you may have.
      07-17-2013, 06:37 PM   #14
Expert@ApexWheels
Expert@ApexWheels's Avatar
3522
Drives: M3
Need replacement lug bolts? Look no further, we've got them available in Black and Silver, in multiple sizes!
      08-03-2013, 10:37 AM   #15
beyondM
31
Drives: 2011 Silverstone II E90 ZCP
Currently running 220 wheels with 15/12 spacers. Probably will be getting a set of ec-7 square later in the year. Which set stud kit should I run?
      08-05-2013, 06:38 PM   #16
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
A 90mm stud kit will work with your 15mm spacers but a 75mm kit will not. The 90mm stud kit will also be compatible with your future EC-7 setup whether you plan to run spacers or not.
Please let us know if you have any other questions and we'd be happy to answer them for you.
      08-07-2013, 07:02 PM   #17
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
Make sure you purchase the correct length lug bolts for your spacers! These are available individually or at a discounted price when purchased along with a spacer kit!
Please let us know if you have any questions about our wheels or accessories and we'd be glad to help you out!
      08-09-2013, 05:21 PM   #18
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
Switch up the look of your wheel setup by changing the color of your lug nuts (for those with a stud conversion kit) or lug bolts. We sell these items individually for your convenience!
Please let us know if you have any questions and we'd be glad to help you out!
      08-14-2013, 06:04 PM   #19
Expert@ApexWheels
3522
Drives: M3
Tired of wasting time aligning the wheel to the hub? We have 75mm and 90mm stud conversion kits to eliminate that problem!
Feel free to contact us by phone, email, or PM and we'd love to help you out!
      08-15-2013, 06:34 PM   #20
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
Our BMW lug bolts come in standard lengths for cars without spacers as well as extended lengths for cars running up to a 20mm spacer. They're available in all sizes in black or silver:
Give us a call to order your set of lug bolts today!
      08-20-2013, 03:56 PM   #21
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
Our stud kits are available with a stud install kit. The install kit includes an allen wrench and red loctite to make installation that much quicker and easier for you.
      08-21-2013, 06:48 PM   #22
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
Life becomes much easier once a stud kit is installed on your car. No more worrying about lining up your lug bolts with the hub holes while switching from street to track wheels!
Here is how our 90mm studs look without any spacers on:
m3post
