BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
EXXEL Distributions
      09-23-2012, 11:23 AM   #1
VictorH
433
Drives: '09 M3
Report from Mid-Ohio O'Fest
Just back from the O’Fest at Mid-Ohio. Event was well run as usual, weather however, was not quite as cooperative. I arrived Thursday PM and ran the track on Friday and Saturday. Was nice to see friends again and catch up. It seems perhaps this year attendance might have been down a bit, but I can’t say for sure. The run groups were certainly packed on Friday, but perhaps only ½ the cars on Saturday. The track is really quite fun and challenging. I would describe it as a better version of Barber. If you like blind corners, apexes at the crest of hills, off camber corners (really just a problem if you happen to get outside of the corner and then it can be dangerous) and carosels then you will like Mid-Ohio. It’s described as a “technical course.” I always thought that “technical” tracks where what people called tracks that just had a whole bunch of turns and not much speed. At Mid-Ohio you come to learn that technical means that you better make darn sure that you have the car set-up and placement at corner entry just right otherwise you are liable to get in big trouble. So it’s more challenging in that regard, and so it demands some precision on the front end and in return you will get a nice rhythm and flow through the corners.
The weather was the other issue. On Friday even though there was a 70% chance of rain, it was dry all day and the track had fantastic grip (it’s pretty smooth too). On Friday evening after the awards banquet a number of cars were damaged by a micro-burst thunderstorm. A tent used for a covered car display, at the conference hotel, got blown over and the cars underneath were damaged and the guy who parked next to me (at the next day’s track event) had part of the tarp and one tent pole land on his 26,000 mile E46 M3 scuffing up the paint on his hood as well as scratching the paint on his mirror and door. He was parked near the tent, not under it.
On Saturday everyone’s first session was on a cold and really wet track even though it wasn’t raining at the time. I like driving in the rain, but the morning session was not that much better than driving on ice. The track maintenance people used a lot of asphalt sealer in the corners which give tremendous grip in the dry but makes it an ice rink in the wet. Everything had to be very gentle and deliberate, ran the course two gears higher than in the dry and just drove like I was driving on raw eggs. The track dried out for the second morning session but it started raining again just as my final session of Saturday started. Amazingly, grip was really quite good for a damp track (I’ll talk about tires below). Overall, a really nice time and a nice track. If you get a chance I think this track is worth a visit.
Now some comments on parts and pieces:
1) Schroth R55 Mini harnesses- Yes, this is a non-approved application but this was now my second track event with them. For those of you used to running your cars with just the standard seat belt you will understand what I mean when I say I completed two days with no knee bruises . What is amazing is that with a good harness you can actually use the steering wheel for just that, steering. No more holding/bracing yourself with the steering wheel while trying to turn. No big surprise but you can actually place the car better when you only need the wheel for steering. I have a head restraint as well and boy are you really locked down when everything is cinched up, makes closing a fully open door impossible and checking for cross traffic is really a challenge. Super easy to install and remove, takes longer to put the belts back in the box than hooking up in the car.
2) Bridgestone RE-11 tires. I’m running 255/35/19 Front and 285/35/19 Rear. 275s were not available so I went with 285s, which I got last Fall. Even with the bigger rear tires, the car’s bias is toward oversteer which is fine with me. The grip of these tires is really phenomenal for a street tire. I’m down to 4/32” in the rears and a touch more in front, but I drove this set from Columbia, SC to Chicago (rained the whole way, and yes I did hydroplane in larger puddles, so best to avoid standing water) and then to Columbus, OH to O’Fest and home, total mileage 2,200. The last three instructors I’ve had (Road America, Road Atlanta and Mid-Ohio) have all commented without any prompting, at how good the grip and handling of car is. A major part of this is the tires. Dry grip is fantastic, for a street tire, I’m not saying they are R-comp like at all, but relative to PS-2 or Sport Contact 3s (I’ve had both) they are in a whole other league. The other thing that was impressive was that on a damp track, that is the track was dry and during the session it’s raining the whole time, that grip was incredible. I couldn’t believe how hard I could push and the grip was predictable and stayed there throughout the session even though the track was getting wetter and wetter. I’m really temped to get another set but I’ve heard good things about the AD-08 as well, which I’m temped to get just for comparison.
3) Ground Control Adjustable Street camber plates – I’ve had these for a year now. I have a “track alignment” with -2.5 degrees of camber up front. The plates have completely eliminated the outside edge tire wear I used to get. Front end grip is improved and I never have any understeer now (though some of the complaints of under-steer are driver technique related and in my case probably too). The plates have been trouble free and noiseless. Again, a good addition for my car and usage.
4) Cantrell motorsports front brake cooling ducts – I am running these for the last 3 track events with Pagid RS-19 front and RS-29 rear pads. I think they help, but I do know that at Road Atlanta if you have no traffic and run 3 consecutive laps hard, you will get brake fade with this set up. The fade is moderate and as soon as you get into some traffic it gets “cured.” I’ve just learned to move the braking point back a bit and understand that it might be possible to get total brake failure if you don’t make some adjustment. Was not an issue at Mid-Ohio and VIR has been fine too.
5) E90 BMW M3, with EDC and DCT other than items noted above, all stock. It’s not the fastest accelerating car, it’s not the best handling car, it doesn’t generate the highest cornering forces, it’s not the most nimble car and it’s not the best looking either, but boy as an overall package it’s the best car I’ve ever owned. As noted above each of the last three instructors I’ve had have all said that they were amazed at how well the car handles, and how much grip it generates. It’s easy to drive, very forgiving and the handling balance is fantastic. Even though my car is 3 going on 4 years old (I’m at 45,000 miles) I still like it as much or more than when I first got it. Super reliable, burns no oil at all, will run 130-150mph at most any track (not Barber or CMP, well probably a bunch others too) and for a car that gets driven everywhere it just plain stomps.
For those of you thinking about O’Fest next year, BMW CCA is seriously evaluating running the next event at Laguna Seca to be timed just after the “Historics.” This would be potentially a very memorable event. They are also looking into doing auto hauler car transportation by region for those who want to drive Laguna Seca but don’t want to drive all the way cross-country. Keep your eyes open for more information coming from BMW CCA.
      09-23-2012, 01:12 PM   #2
bigjae1976
bigjae1976's Avatar
1571
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
Great report! I'm moving to WI soon and now they move Oktoberfest to the west coast. I can't win! A Laguna Seca event would be phenomonal!
I think when you say technical, you have to consider corners AND elevation changes. I think elevation changes really adds the challenge. It sounds like Mid-Ohio has plenty of both!
Understeer. Your assessment matches what I've experienced. A lot of people bitch about how the E9X M3 has lost its soul and blah, blah, blah. I'll say this...if the E30 M3 defines what an M3 is because it was neutral and high revving then the E9X is the closest thing because it is the highest revving AND the only recent BMW that doesn't go into terminal understeer in stock form when pushed.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      09-23-2012, 02:55 PM   #3
CBS
CBS's Avatar
Drives: F10535, E90M3, E30M3, E28M5
2017 Alpina B6 GC  [0.00]
2014 535xi M Sport  [0.00]
2014 X3 3.5 M Sport  [0.00]
2011 M3 E90  [9.74]
2007 Z4 M Coupe  [7.00]
1990 M3  [9.50]
1988 M5  [10.00]
Thanks for the report - sounds like it was a good time and a track I need to put on my radar.
If BMW CCA organizes an AutoHauler for Laguna Seca next year, I would be interested.
ESS VT-1 550 | M24 Oil Cooler | Fall Line Half Cage | RaceTech 4009W | 6 pt Harness | Lifeline Zero 360 Fire Suppression | Rear Seat Delete | Motion Control DA Dampers w/remote reservoirs | 900/650 Hyperco Springs | RD Sport Sway Bars | Brembo 380 BBK | GC Camber Plates | Hoosier R7 | Eisenmann Sport | Stack Gauges | Painted Challenge Front Lip | Painted ZCP Rear Spoiler | Xpel Ultimate Film | LuxAngelEyes
      09-23-2012, 08:38 PM   #4
klammer
97
Drives: 11 spc gry m3 e90, 19 X5
Great write up and Mid-Ohio is definitely on the list. Waited to long to sign up and missed it, but an epic drive to Laguna may be in the cards for next year. Loved the report on the harness (can't imagine coming home without the dreaded bruised left knee) and wonder how much better/faster one can drive while strapped in? Great report and love to see some pics or a vid.
mods: track ready stuff
      09-24-2012, 12:58 AM   #5
LittleBlueBMW
Drives: 2010 E90 M3, 2002 M coupe
1999 E36 M3  [0.00]
2010 E90 M3  [0.00]
Well at least it did not snow Often the Frost on the Pumpkin driving school gets snow at Mid_o
"M3 drivers have no friends." -Jezza
m3post
