XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > X1 DIY (Do-It-Yourself) Discussions
Register FAQ Calendar Today's Posts
      09-11-2012, 06:50 AM   #1
mabrahams
75
Drives: X1 M-Sport 28i
DIY: Interior Trim Removal?
Anyone have a write up on how to remove the X1 interior trim?
      09-12-2012, 04:04 PM   #2
morski
Drives: X1 2.0D X Drive
all of it or any one in particular?
      09-13-2012, 02:38 AM   #3
mabrahams
75
Dash trim and door trim would be great.
      09-19-2012, 08:59 AM   #4
aznpxdd
China
9
Drives: 2009 Audi A4 2.0T, 2012 BMW X1
Location: Dongguan, China / Taipei, Taiwan / Los Angeles
You don't really need a guide to remove the dash and door trims. Just buy a generic trim removal tool online (there are quite a lot), and use it along with a piece of thin cloth to pry off the trims. Always start at the bigger end of the trims (so DON'T start at the AC side of the dash trim & handle side of the door trims), and just carefully pry them off. You need to unscrew 4 screws which attaches the AC unit to the dash. The angle is a bit weird, so you will need a longer screw driver to reach these.
I've removed mine a couple times to wrap in 3M CF vinyl. They are also very easy to put back, just line up the clips and pop them in.
On the other hand...I would love a guide to remove trims at the shifter. Looks a lot more complicated than removing the other trims.
Life's a bitch and then ya die, that's why we get high, cause you'll never know when you gonna go!
      06-30-2013, 06:43 PM   #5
OneQuest
Australia
Drives: X1
sorry to bring an old thread up
is there a way to remove the boot/trunk trims?
I would like to replace the rear speakers and have no idea how to get to it
Thanks
      05-11-2014, 10:04 PM   #6
Abbie
Drives: 2013 E84
is there a way to remove the CIC trim, so i can pull the CIC out?
      06-17-2018, 07:45 AM   #7
Geoken
Drives: BMW X1 E84 2013
Removing trim
There is a video on this link that show how its done
https://www.bimmer-tech.net/bmw-rear-view-cameras/
xbimmers
