09-09-2012, 06:05 PM | #1 |
83
Rep 954
Brake Pad Wear Indicator
Guys, who replace brake pads by yourself, how do you reset brake pad service indicator in i-Drive? I have a new set and it annoys me that it is telling me to go to service..
I have Bavarian Technic cable and for some reason I am getting error while trying to reset any of my Condition based service indicators. Thanks |
09-09-2012, 07:15 PM | #2 |
433
Rep 1,286
My understanding is that it can only be reset by replacing the wear sensor itself. It clears the pads worn and need replacing message, but I'm not sure what it does with the mileage until replacement amount.
09-09-2012, 08:06 PM | #3 |
776
Rep 1,718
Drives: 2011 M3 Jet Black:ZCP, ZCV, ZP
As long as the dash light for brake pad change has not been on, Then you can reset the service mileage through the dash, but if the wear sensor has been worn through then you have to replace the sensor to get the light to turn off.
09-10-2012, 08:53 AM | #5 |
21117
Rep 20,741
Drives: 2021 911 turbo
This is correct, as long as the pad sensor did not send a trigger to the ECU, you can reset the mileage countdown through the dash. Otherwise, you need to change the sensor.
BTW, I have given up on the sensors a long time ago. I simply took the connector end of the sensor, cut off most of the cable and welded/taped the two wires together. Changing pads is now much faster and cheeper . I kept a good set of sensors for when I will sell my car . |
12-26-2012, 02:27 AM | #6 | |
83
Rep 954
Ok. I decided to give up on the sensors too. All I need to do is to cut off the wire and twist 2 wires together?
12-26-2012, 06:43 AM | #7 |
21117
Rep 20,741
Yessir, that simple. I actually welded the two wires together to be extra safe, but I guess twisting them would be sufficient. I then wrapped the connection in electrical tape to isolate it from the elements. It has been like this for 3 years without any issues .
12-26-2012, 07:40 AM | #8 |
81
Rep 1,510
fyi: electrical tape for said purpose melts when placed near the rotors, ask me how I know
wire has since been tie-wrapped away from the front rotor with electrical tape over the sensor. The entire rear wire and sensor can be nicely tucked in the wheel liner. |
12-26-2012, 09:54 AM | #9 | |
1571
Rep 8,076
Drives: 11 E90 M3 Individual
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
12-26-2012, 12:28 PM | #11 | |
10
Rep 201
12-26-2012, 02:37 PM | #12 | |
21117
Rep 20,741
12-26-2012, 08:49 PM | #13 |
36
Rep 927
If your sensor is intact, you can just tie it back up on the strut or wheel well without messing with the wiring. When you want it back in place, just connect it into the pad...if you didn't lose that stupid spring clip.
Craig Brickner
Click to Join: BMWCCA # 366493 |
01-03-2013, 11:38 PM | #14 |
2751
Rep 6,759
And if you resort to tying the wires together, simply tuck them back into the Teflon sheath that covers the wires towards the end, it's melt-proof.
When the season starts, I think I'll tuck the sensors into the wheel well to keep them safe.
2018 F80 Santorini 2019 Z4 3.0i 2022 X2 M35i |
01-04-2013, 06:23 AM | #16 |
7
Rep 229
+1 All you have to do is remove the little metal clip and tie the entire sensor out of the way. I've been doing this since one of mine actually fell off and I found it dangling down inside the wheel (having never set off the wear alarm).
