09-07-2012, 07:07 PM | #1 |
44
Rep 313
6mt trans oil
For every post i find, i find a different type of fluid. I see ATF then i see 75w/85. Can some one please tell me how much and what type of fluid to use. I really appreciate the education guys. Since we are on fluids what do we use for clutch fluid. Thanks in advance. You guys kick a$$.
09-07-2012, 07:28 PM | #2 |
Pablo
39
Rep 263
Go to the DIY section and you will find
BMW PPK V2, M3 26mm sway bar, M3 front control arm kit, M3 steering wheel, BMW 313 wheels w Michelin PSS
09-07-2012, 07:40 PM | #3 |
13
Rep 58
Drives: 2016 BMW 228i M-Sport
I used 2 Litres of the Redline D4 Fluid. Some people use D6 I think, but according to the redline website I used D4.
09-07-2012, 08:06 PM | #4 | |
44
Rep 313
09-09-2012, 01:16 AM | #6 |
13
Rep 58
When I go into the application guide and put in my 2009 128i N51, it says D4
09-09-2012, 01:25 AM | #7 |
European Editor
10589
Rep 22,992
You need a little over two liters of trans fluid for a six speed manual.
Factory fill is MTF-LT-3. Then it went to MTF-LT-4. It might even be now LT-5 like the 1M and N55's use. I used Red Line's at ATF-D4 in my manual trans and I really like it. The shifter seems smoother to me now.
09-09-2012, 06:22 PM | #10 |
368
Rep 3,547
As I said in the DIY, I used Redline MTL. It is a bit thicker than automatic transmission fluid but much thinner than rear end fluid. I live in a warm climate and garage my bimmer so I don't think it is too thick.
Jim
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09 |
01-14-2013, 09:16 PM | #12 | |
247
Rep 1,585
Drives: 2011 VO 1M
Garage List 2010 Porsche 911 GT3 [10.00]
2021 BMW X5 SD40i [0.00] 2023 Toyota TRD Pro [0.00] 2011 BMW 1M [9.83] 2014 Ford Raptor [0.00] 2005 Ariel Atom 2 [0.00] 2008 135i SOLD [10.00] |
What about Motul sauce? http://www.motul.com/us/en-US/produc...%5Brange%5D=25
///1M #643 of #740
01-15-2013, 08:12 AM | #13 | |
105
Rep 2,696
Faster, faster, faster, until the thrill of speed overcomes the fear of death… – Hunter Thompson
01-15-2013, 11:34 AM | #14 | |
85
Rep 2,438
Is it possible to buy not from the dealer? |
01-15-2013, 11:43 AM | #15 | |
85
Rep 2,438
01-15-2013, 12:07 PM | #16 | |
European Editor
10589
Rep 22,992
I am not sure who makes it. I think it is made by: Pentosin But I found this ZF document(bellow) and it looks like Castrol does make it as well. But also Pentosin does so too. So I am not sure. I know for MTF-LT-5 (the fluid used in the 1M and also 135is w/N55 trans), you can use the Porsche DKG (DCT) fluid made by Pentosin. So I think maybe Pentosin makes it for Castrol ? Or maybe they both make equivalent fluids. ? http://www.profitoleje.pl/files/pent...ENTOSIN_ZF.pdf You can find some places online that sell the MTF fluids... but it seems like all of them just buy it from BMW AG so why not just save yourself the markup and buy it direct! Some dealers sell it by the 500ml and some only in a 5L jug. My dealer sold it to me by the 500ml and put it in a 5L trans jug for me. You will need 2.1L for the manual trans fluid change. But really, I would use Red Line's AFT-D4 or D6(thinner than D4) in your manual trans. My trans shifts so much smoother with the Red Line ATF. I forgot how much I paid per 500ml for the MTF-LT4 fluid from my bmw dealer. It wasn't cheap! I think close to 75 euros for the 2.5L I bought from them. Buy the Red Line for $15 per liter! I bought my Castrol SAF-XJ 75w140 GL5, diff oil from an OEM German parts store. 9 euros per 500ml. The 135i diff holds 1.2L.
01-15-2013, 02:29 PM | #17 | |
85
Rep 2,438
Also I saw Redline Diff fluid 80w140 |
01-15-2013, 03:37 PM | #18 | |
European Editor
10589
Rep 22,992
IF your car sits outside... I would use the Redline ATF-D6 since its thinner (than the D4) and should be better at super low outside temps. For the diff fluid... you could also use Redline's 75/90 GL5 gear oil.
01-15-2013, 03:54 PM | #19 |
1Addict
3233
Rep 7,894
Hm, interesting. So for warmer climates say 50-100 degrees, the redline ATF-D4 would be ideal?
Strongly considering switching from this lifetime fluid. I had full control over all the fluids in my last car (did ALL maintenance and service myself) and have been lazy with the free maintenance with the 1er, but I absolutely do not trust that tranny fluid is good for the life of the car. No way. Bullshit. Are there any color differences with the fluids from the BMW MTF and the Redline?
01-15-2013, 07:54 PM | #20 |
247
Rep 1,585
Drives: 2011 VO 1M
who has experience using Motul fluid for there tranny or diff? I am switching to there engine oil as it seems to get good reviews. I know a lot of racers that use it. Would like to see some supporting data that it is > than Redline.
01-15-2013, 08:21 PM | #21 | |
247
Rep 1,585
Drives: 2011 VO 1M
Some good info here thanks to big-D http://www.1addicts.com/forums/showthread.php?t=712533
///1M #643 of #740
01-15-2013, 09:07 PM | #22 |
1Addict
3233
Rep 7,894
WOW. Even worse than the Honda MTF that I was used to working with. I wonder of its worth changing the diff fluid as well. That will be a PITA with no drain hole.
