BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
BPM
      09-03-2012, 02:20 AM   #1
bigjae1976
bigjae1976's Avatar
1571
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
Flat tire after an off.
Learning point. I went off sideways going pretty fast in the video below. Probably close to 100mph. That part of the track is odd because it's a long arc. I was working up to going flat out through that corner. The key is you have to stay in the throttle all the way through or you run wide. Sounds backwards but I've seen (and felt) it done. So I was running out of room because I let up. Tried to drop 2 wheels, keep the car straight, and slow the car. Don't wanna go straight off, there are trees out there. But I misjudged straight which caused the car to rotate. So I threw in the towel and locked it up as soon as the car started to go back across track.
Of course, I got black flagged...there was a large mushroom cloud of dust. I called it the session, checked everything and my tire was down to 20psi. I pulled it, check the tread, bead and wheel, no leaks.
Apparently, you can pull the tire off the bead for a split second and cause a loss of tire pressure. I knew the it happens, didn't know that the tire can reseat itself. Refilled the tire and ran 2 more sessions, no problems. Still no issues a week later.
If you get sideways at speed, consider checking your tire PSI.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      09-03-2012, 07:22 AM   #2
leo95se
Drives: '09 e92 M3, '15 F15 X5d
I'd pull and get resealed. Even if it just popped there could be debris in it.
      09-03-2012, 07:46 AM   #3
bigjae1976
bigjae1976's Avatar
1571
2004 BMW M3  [4.50]
Getting new tires on Wed anyway but good idea.
      09-03-2012, 09:01 AM   #4
klammer
97
Drives: 11 spc gry m3 e90, 19 X5
Thanks for the heads up. Have a few corners like that, better stay on the gas or the back will come get ya, thanks for sharing that
mods: track ready stuff
      09-03-2012, 10:28 AM   #5
Porschefile
Porschefile's Avatar
59
Drives: E92 M3
Thanks for sharing, that is scary. I wonder how much more force it would take to actually dismount the tire.
      09-03-2012, 01:46 PM   #6
M3 Esq
Automobilist
M3 Esq's Avatar
Drives: E70 X5, 911 GT3
Scary. Glad you came through it ok.
m3post
