07-28-2012, 06:01 PM | #1 |
12
Rep 134
Green o-rings? Possibly OEM wheel spacers? Help plz
I had to have a rim resurfaced for my lease return a couple of days ago. I brought my winter rim and tires so i wouldnt have to leave my car. After putting on the winter tires, i was given 4 circular green rings that i am assuming are OEM spacers. Bear in mind i do have the M sport.
My car has been shaking very badly at around 50mph and sliding all over the place in the rain. Now, my tread depth is approx 4/32nd and tire pressure is 36psi all around. Can these rings be contributing to the problem? Does any1 know what they are used for? Thanks in advance.
2009 135i coupe | 6MT | Montego | M sport | Nav| Split Second Turbo Tuner
2014 335i | 6MT | M Sport | M sport brakes | Nav | Harmon Kardon | 19in factory performance rims | JB4 | K40 radar detector and laser jammer |
07-28-2012, 06:40 PM | #2 |
European Editor
10596
Rep 22,992
BMW alloy wheels do not require any shims or spacers to be hub centric. What kind of "winter wheels" do you have?
Also... your probably ruining your snow tires driving iin such warm/hot summer weather. Not to mention that its pretty dangerous drivng in the summer with winter tires. Very long braking and poor handling. Sounds like you have some cheap aftermarket wheels that are not hub centric - and that is what is causing your vibration.
07-28-2012, 07:08 PM | #3 | |
12
Rep 134
I have no issue keeping the speeds below 50mph but the owner was VERY rude and asked why he was changing all 4 of my tires when I had 4 "spares" in my car (referring to my snow tires). He said he would be charging $40 to change all four instead of putting on just 1 winter rim/tire for free. After leaving, i thought to myself that my winter tires are 17's and the stocks are 18's...Plus riding around 4 days w/ 1 different rim/tire didnt sound right to me. I have ASA Sport edition rims with Blizzak bridgestone tires. I had them on for 2 seasons ago without a problem. The rings are PURPLE not green. My mistake With that said, I would still like to know what these rings are used for.
07-28-2012, 07:20 PM | #4 |
European Editor
10596
Rep 22,992
Those purple rings fist go onto your hubs and then the wheel mounts or gets centered onto those rings. Its a bad way to make wheels fit a car. IF your running around without those rings installed... THAT would cause a massive vibration, since your wheels are no centered onto your hubs.
Sounds like you made your "guy" do some extra work he wasn't prepared to do. It is one thing to mount ONE tire for free for a customer. But you had him change/swap/mount your four winters onto your car for free. That was why he was grumbling. Most shops would charge an half hour's labor rate to install four wheels(winter to summer or vise versa).
07-28-2012, 07:36 PM | #5 |
12
Rep 134
Thank you for your help. The vibration is very bad and dangerous.
He gave me a quote for $150 at first, i said fine but i would like him to swap the rims and he said okay. After he had one of his mechanics that barely spoke english work on my car, he then said "why am i changing 4 rims?" when he clearly saw all 4 and went on to say he would have to charge if i wanted to swap them. He was very rude! and when i asked for a receipt that he had all four my wheels at the end of our conversation, he pretty much threw it at me. He himself did not know that the rings were not installed as only that 1 mechanic was working on it. either way, it is very negligent on the mechanics part, no matter how much the charge. If anything does happen, he would have a nice law suit to deal with instead of 4 plastic rings. Do you happen to know the name of these things?
07-28-2012, 07:40 PM | #6 | |
480
Rep 4,155
Drives: 1/18 Monte Carlo Blue E92 M3
07-28-2012, 11:07 PM | #7 |
12
Rep 134
how could you possibly expect the lay person to know what that is? I didn't even know where they came from in the first place. Now i do appreciate the answer.
07-28-2012, 11:09 PM | #8 |
12
Rep 134
oh okay i see the confusion. I forgot to mention that the mechanic had handed me the 4 rings and said i dont need them, or at least i think thats what he said. they must have been sort of stuck with the winter tires which explains why i thought they were stock. thanks for the clear up
2014 335i | 6MT | M Sport | M sport brakes | Nav | Harmon Kardon | 19in factory performance rims | JB4 | K40 radar detector and laser jammer Last edited by aaron529; 07-28-2012 at 11:21 PM.. |
07-28-2012, 11:37 PM | #9 |
12
Rep 134
and i did some reading on tire rack. The mechanic didn't put it on lift or a jack stand which is exactly why he couldn't torque them properly.
http://www.tirerack.com/wheels/tech/...&affiliate=TX4
07-29-2012, 06:04 AM | #10 |
37
Rep 2,084
You're not ruining your snow tires by using them in summer. That's exactly what you should do after the tread gets below 6/32".
Some winter tires have two sets of wear bars, at 6/32" and 2/32" to indicate when they can't be used for snow anymore and when they can't be used at all. |
07-29-2012, 07:31 PM | #11 |
Vrooom :)
315
Rep 2,602
those look like centering rings. I thought their purpose was to prevent vibrating? For example, my OZ ultraleggera came with centering rings. Guys from tirerack told me if you tried to put the wheels on without centering rings then you can get bad vibrations as they do not fit correctly.
2014 C7 Corvette Stringray - Laguna Blue - NPP Exhaust - Competition Seats
