07-20-2012, 10:10 AM | #1 |
39
Rep 269
Z4M Steering wheel inserts peeling
What are my options for the steering wheel inserts (the plastic bits on the arms) peeling off? It looks like there is nice shiny black plastic underneath the "soft" coating that comes off.
07-20-2012, 12:21 PM | #2 | |
127
Rep 1,772
Drives: 2007 Z4M Coupe
But seriously, I have heard of a member who used plastidip. Might want to give that a try
Gruppe M CAI / Euro Headers / Rogue Engineering X-pipe / RE Diablo Exhaust |
ShawnPaul109.50 |
07-20-2012, 01:09 PM | #3 |
111
Rep 1,351
Drives: in Anger.
Or buy new ones as they are pretty cheap.................
Gone (2006 STI, 2008 EVO MR, 1968 Mustang)
AFE Intake/Euro Cats/CSL Headers/Sportline CSL/H&R Springs 1217/1815 !!! BOILER UP !!! |
07-22-2012, 09:23 PM | #4 |
39
Rep 269
Unless I'm looking at the wrong thing, RealOEM suggests it is part #32348035326, and they are $200:
http://parts.bmwofsouthatlanta.com/p...348035326.html Doesn't exactly seem "pretty cheap" to me, especially if it is going to happen again. |
07-23-2012, 10:28 AM | #6 |
113
Rep 855
Id really like to see how plastidip would hold up. Try you should try it! Mine are a little worn once they get bad I will plastidip mine just for shits and giggles
2014 335i M Sport
2010 328i M Sport 2007 Z4MC #1019/1815 (Sold) 1997 M3 (Sold) 1991 325i |
07-23-2012, 11:44 AM | #7 |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
+1 on plastidip or any spray paint
OEM replacements are expensive and will result in the same fate over time. Although I may actually retrofit the non-M silver trim like this |
07-23-2012, 01:20 PM | #8 | |
111
Rep 1,351
Drives: in Anger.
You can also look into getting the silver ones for the non M cars. Seem to be much more durable.
07-23-2012, 01:29 PM | #9 |
39
Rep 269
Thanks guys. I may try to pop them off and sand/spray them. I've also seen some nice "carbon fiber" 3M film that I think would look great, but may be a bitch trying to apply.
I've read that this is doable without removing the steering wheel, I will try to give that a go. I replaced the steering wheel on my E46 330i a few years ago; relatively easy, but would prefer to avoid it if possible; unless someone chimes in to the contrary. |
07-23-2012, 02:37 PM | #10 |
59
Rep 862
Plasti-dipped mine!
Very close to OEM, maybe 90% - 95%. In fact, I only did one side and you can't really notice any difference at all. Very easy to take off and redo if they do start peeling. My only advice is to use a new can of Plastidip for the final coat since if the can is low, air bubbles start to come out. |
09-16-2012, 10:56 PM | #11 | |
11
Rep 178
09-17-2012, 01:31 AM | #12 | |
73
Rep 820
Drives: 2007 Z4MR silver grey
John |
09-17-2012, 07:53 AM | #13 |
145
Rep 409
Ask AndyM to leather cover them for you.
Jon Maddux
coupenut.blogspot.com x5nut.blogspot.com 16 X5d | 08 M3 Sedan | 06 M Coupe | 01 M coupe | 99 M coupe |
09-17-2012, 08:10 AM | #14 |
39
Rep 269
I haven't got around to doing anything about this, I kind of stopped noticing it .... I may take them off when I store my car for the winter and do something then.
antennahead; where did you get the silver ones? I don't think I want to invest too much in this fix. Can anyone confirm if it is possible to remove the trim pieces (sides+bottom) without taking off the whole wheel? Last edited by ncnmra; 09-17-2012 at 08:17 AM.. |
09-17-2012, 04:45 PM | #15 |
80
Rep 1,663
Any pics? If it looks good it might be a good permanent solution.
09-17-2012, 11:08 PM | #16 | |
73
Rep 820
This includes the radio/bluetooth controls, so I think that is why it's a little more expensive that just the spokes. Sides come off very easy and is an easy replacement. The bottom spokes come off easy enough, but can be a bit tricky to replace. I was able to replace mine without removing the wheel or the airbag section. I will admit the back piece of the bottom spoke was a bear to get on. You have to work the top of it under the airbag trim and twist it a bit. It can be done however. If you look closely also, the front of the bottom piece is longer than the rubber coated one, and extends further down on the wheel. I am fine with that. I think it looks good and accents the brushed aluminum trim well. The actual color of this trim is called "graphite", as opposed to the "chrome" versions. I like the graphite better. It matches the door handles well and is slightly less shiny. I also replaced my roll bar covers with the silver grey ones, which are pretty much a perfect match also. John |
09-20-2012, 03:39 AM | #17 |
Marksdesigns
Rep 42
After the coating wore off and after numerous paint coverings wore off, then after a set of rather cheap looking 'graphite' covers, i decided to CF mine... see pics below, expensive but now i LOVE looking at the wheel!
THE CORPORATION
3GFX722.50 |
09-20-2012, 11:23 AM | #19 |
Dog Listener
704
Rep 7,850
Looks great, so does the CF dash and trim around the shift boot.
09-20-2012, 02:37 PM | #20 |
Marksdesigns
Rep 42
Thanks guys, yes the dash, console, rear console, door handles, elec window switches, sills, corner sills etc etc are all real carbon fibre, (cf laminated with 2x2 weave) the steering wheel is a little expensive but then so are those damn switch surrounds! I'm thinking I need to post more pics showing the other CF parts I've got done?!
THE CORPORATION
09-20-2012, 04:13 PM | #21 |
21
Rep 507
I'm thinking that too haha
SOLD: 2008 M Coupe
09-20-2012, 11:05 PM | #22 |
73
Rep 820
Styling and color are rather subjective, but I don't think the graphite spokes are cheap looking.
