ZPOST
Go Back   ZPOST > Marketplace > Classifieds : For Sale / Wanted / Group Buys
  TireRack
      07-12-2007, 11:28 AM   #1
highgrade00
Drives: 2007 BMW Z4M Coupe
StopTech Brake Kit - BMW Z4 3.0i
None
This Kit for the BMW Z4 3.0i is BRAND NEW & IN BOX. This has NEVER BEEN INSTALLED. This kit sells new for $689.00 + shipping at retailers. I've been on the fence with this for months now... If I can't get a decent amount back, I'm just going to install them. I'm looking for $489 + shipping. That's $200 less than what I purchased these for.
Includes:
* StopTech's SportStop drilled rotors
* StopTech stainless steel brake lines
* Street performance pads
* 3 bottles of Motul RBF600 brake fluid
**Rotors, lines and pads are for front and rear. This kit fits stock calipers.
Benefits:
Drilled rotors prevent glazing of the pads, add bite and improve wet and dry braking performance. StopTech's SportStop rotors have a durable black coating on the non-swept areas of the rotor to prevent unsightly corrosion, and quality is assured as the rotors are manufactured to meet or exceed all OE specifications. Stainless steel brake lines improve pedal feel and reduce the amount of time between applied pedal pressure and actual deceleration by preventing expansion, which stock rubber flex lines allow. High performance street pads provide you with higher resistance to fade, higher maximum operating temperature, and better initial bite to allow consistent deep braking into corners. Motul RBF600 brake fluid increases both wet and dry boiling points and prevents boiling even under the most severe operating conditions.
StopTech Part #: 86.133.06225
      08-16-2007, 10:24 AM   #2
highgrade00
sold
zpost
